By
JayBee
Item Condition: Near New
Suburb or Town: Adelaide
State: SA
Payment Method: EFT, Cash on Pickup
Reason for selling: Upgrade
Further information:
Selling my Ayon Audio NW-T/DSD Vacuum Tube Network Transport (RRP $8395). I am the first owner and bought this unit in January 2020. The NW-T is the only vacuum tube based, Pure CLASS A Network Player in production anywhere. It has a warm analog tube sound, it is perfect for any digital file listening. It has the DSD upgrade Kit fitted. The unit has a small scratch on the RH, the rest is perfect.
The NW-T network playe is a new outstanding design which includes a Network-Transport with its “tube buffered digital output stage” and an Analog/Digital converter (ADC). The Network-Transport can be connected with any external DAC or CD-player with a digital input (DAC section). Furthermore its built-in ADC can be used to convert analog signals (e.g. of a phono-stage) into digital signals or into FLAC files respectively and to store them afterwards in an NAS. Special attention was paid to the tube-power supply and the digital output signal, because this digital interface is significantly involved to achieve "analog-magic" sound properties in the external DAC to a large extent. The NW-T was designed to maintain all advantages of a tube (in the power supply as well as in the digital output stage) in combination with streaming. The NW-T uniquely unifies both and offers a new dimension of sound far above its class.
Features & Specifications
User interface on QVGA 3.5” TFT display
Internet radio (vTuner)
UPnP streaming from PC via 100base-T Ethernet /
Streaming audio from USB HS (mass storage device)
WAV (lpcm) - up to 192khz/24bit
FLAC - up to 192khz/24bit
AIFF - up to 192khz/24bit
AAC, HE-AAC (up to 24bit 96 kHz)
LPCM (up to 24bit 192 kHz on wired LAN and up to 24bit 96 kHz on wireless LAN)
NetAPI with Ayon app for iPad, iPhone/iPod and Android
Logical sequenced soft-start power up for extended tube life
Warm up function
Ultra short signal path
Simplest direct circuit path for purest musical sound and high reliability
Minimal discrete wiring for optimum signal propagation
No DC servo that degrades the signal
High quality parts throughout
6H14 tube (digital output - signal buffer)
Upsampling 24bit/192kHz and on/off switchable
Ethernet ( RJ45 )
WIFI
ADC input - S/PDIF (RCA), 24/192kHz
2 x USB type “A” inputs for Memory stick or USB drives
Digital output - S/PDIF (RCA), AES/EBU (XLR), TosLink, BNC and I2S
Digital volume control
Separate Display for Network-Player and Volume/ ADC input
Power Supply
The power supplies have been further refined with new components and enhanced AC line noise filtration. Separate power transformer windings and filters provide total isolation between the input and output stage which makes this a pure power source and it is a critical attribute for a 6H30 output stage. We also use electrolytic capacitors with much larger storage capacity to make up for the loss in filtering when using resistors in lieu of inductors.
Dual R-Core / Low noise – insulated power transformers for digital & vacuum tube separated
Innovative power supply provides a high speed energy delivery on transients
Separate and isolated power supplies over each stage of amplification
AC power line filter to avoid noise and hash from entering into the unit.
Tube rectification for tube buffered digital output stage
8 separate voltage regulators
Components
The type of parts used therefore must have a synergistic relationship to the circuit they are placed in. It is this relationship of which type of part to use where, that ranks our products apart from the mass.
Selected, premium quality passive components used in all applications
High speed & high quality audiophile grade capacitors
High quality special tube sockets with gold pins
High quality – RCA, BNC & XLR jack
Gold-plated industrial grade PCB
Mechanical Construction
The high grade aluminum chassis impart a richer, more lustrous tonality with a cleaner back-ground and less hash and grain. All brushed anodized anti-vibration-resonance and non-magnetic chassis’s are fully hand assembled to insure the highest level of craftsmanship.
AC phase polarity control indicator
The aluminium feet are resonance absorbing types
Metal remote commander
Chassis finish: black / chrome
Specifications
Digital/Analog Converter
Ayon NW-T
Conversion rate
192kHz / 24 bit
Tube complement
6H14 & 6Z4
Dynamic range
> 120dB
Analog input / ADC
S/PDIF (RCA )24/192kHz
Digital output
S/PDIF, BNC, I2S, TosLink, AES/EBU
Network digital inputs
RP-SMA plug Wifi Aerial input (“wireless” network connection) 802.11b/g
UTP RJ45 10/100Mbps socket (“wired” network connection)
Digital inputs
Front mounted USB type ‘A’ socket for USB “pen”/hard disk drive
Rear mounted USB type ‘A’ socket for USB “pen”/hard disk drive
S/N ratio
> 120 dB
Frequency response
10Hz – 50kHz +/- 0.3dB
Total harmonic distortion @ 1kHz
< 0.002%
Remote control
Yes
Dimension (Wide x Deep – incl. terminals x High – incl. feet) cm
48 x 36 x 12 cm
Weight, unit only
10 kg
PLEASE READ
If you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved
If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item
If you don't include photographs of the actual item being sold, your ad will not be approved
You understand that a reasonable donation for selling fees is expected upon successful sale of your item
- if you have previously sold items and not made a donation, your advertisement may not be approved.
