aussievintage 3,579 Posted October 26, 2020 Share Posted October 26, 2020 How important is the speed control to you? You could just get a new pulley made at the right size. It's a 600 rpm motor, so you can calculate the ratio needed from the platter diameter. Running the existing motor from a step-down, presuming it works. Probably the cheapest option. It'd be like many other fixed speed turntables, but of course using quality parts. 2 Quote Link to post Share on other sites
klackto 301 Posted October 27, 2020 Share Posted October 27, 2020 Even if it is a 115v motor it is still quite possible that (seeing that turntable was found in Australia) the pulley may already have been changed for the correct 50Hz one. Best way would be to replace the motor and using the existing pulley check the speed. In any case you'd only need to change the one pulley on the motor (not the other two) and a machine shop could easily make a new one from delrin or similar material. 4 Quote Link to post Share on other sites
xlr8or 618 Posted October 27, 2020 Share Posted October 27, 2020 4 hours ago, Telecine said: You could spend a lot of time and money trying to track down the missing parts second-hand. Spot on. 👍👍👍 I'm going through this myself and 3 years later I still have no functional turntable. Finding the elephant feet and suspension inserts used are a killer for me. I have the Mk 3 spring inserts and full TNT Jr 4 x corner post/feet set. Also, I have the full tri-pulley system. Stillpoints Ultra 5'S work for the feet but the spring inserts are less than ideal for the suspension system but great for levelling the table. Dave's TT also requires an armboard. He can ditch the tri-pulley for the moment. 2 Quote Link to post Share on other sites
Bisguittin 1,844 Posted October 27, 2020 Share Posted October 27, 2020 35 minutes ago, xlr8or said: Dave's TT also requires an armboard. He can ditch the tri-pulley for the moment. Can we laser-cut an armboard? 1 Quote Link to post Share on other sites
russell66 220 Posted October 27, 2020 Share Posted October 27, 2020 You should do it in a few stages, get it going first, it's going to be awesome anyway, platter bearing and motor are the critical parts, Feet suspension are just icing on the cake. You can make an arm board easily (i can show you some basic woodwork skills to get you going😀) You can easily get the feet that are there supported and make it look good. I've got arms and cartridges here not being used that would work well, and a phono stage you can borrow. Someone else said you can bypass the 3 pulley system so do that till they turn up second hand. Find a suitable belt, i have a couple you could try, looking at the pulley they look like the flat design. I have a step down transformer you can use to try the speed. There is an app on the phone that will check it's accuracy. You could be spinning vinyl in a few hours and enjoying it while you take your time to locate all the other bits. Let me know if you need to borrow a few things or need a hand with anything. 6 Quote Link to post Share on other sites
xlr8or 618 Posted October 27, 2020 Share Posted October 27, 2020 (edited) 5 hours ago, Bisguittin said: Can we laser-cut an armboard? Yes - great suggestion. The only thing is the armboard internal cut-out is also dependent on the type of tonearm that will be used with the TT. VPI offered 3 types of armboards: 1) VPI JMW; 2) Graham Eng; and 3) SME tonearms. I can share a few images of TNT armboards sold in the past in the hope they can be CAD drawn and laser cut. Otherwise, we can wait for any second hand ones that come up. None on hifishark at the moment. Edited October 27, 2020 by xlr8or Quote Link to post Share on other sites
xlr8or 618 Posted October 27, 2020 Share Posted October 27, 2020 (edited) @Pops110 Can you confirm if the long levelling screws are still positioned inside the corner posts in the small centre holes looking from the top - they should have an Allen key head? Edited October 27, 2020 by xlr8or Quote Link to post Share on other sites
Alphason 23 Posted October 27, 2020 Share Posted October 27, 2020 I had a new acrylic armboard made up for my TNT-2 and it looks like it came out of the factory. It can be drilled for whatever tonearm you like. I made one up out of craftwood first and trial fitted it since the original dimensions would have been imperial and I calculated it with metric measurements. If it is the same as mine, which the photo suggests, yours will be Width 100mm x Length 278mm x Thickness 14mm, is this correct? I was told that trying to polish black acrylic would end in tears, it seems that perhaps others have had a different positive experience in this respect. Any suggestions as to how? (I'll experiment with the brasso suggestion) There should be a circuit in the motor housing, if it has a 500 ohm resistor in there it may have been used for 240 volts with the existing motor. There is sure to be someone with more expertise than I to explain clearly how that can be the case. A speed controller is the way to go. The VPI SDS has 240 volts input but the output for the motor is 115 volts, so the motor you have would be fine if using an SDS. 2 Quote Link to post Share on other sites
Pops110 3,243 Posted October 27, 2020 Author Share Posted October 27, 2020 4 hours ago, russell66 said: You should do it in a few stages, get it going first, it's going to be awesome anyway, platter bearing and motor are the critical parts, Feet suspension are just icing on the cake. You can make an arm board easily (i can show you some basic woodwork skills to get you going😀) You can easily get the feet that are there supported and make it look good. I've got arms and cartridges here not being used that would work well, and a phono stage you can borrow. Someone else said you can bypass the 3 pulley system so do that till they turn up second hand. Find a suitable belt, i have a couple you could try, looking at the pulley they look like the flat design. I have a step down transformer you can use to try the speed. There is an app on the phone that will check it's accuracy. You could be spinning vinyl in a few hours and enjoying it while you take your time to locate all the other bits. Let me know if you need to borrow a few things or need a hand with anything. Thanks mate, that’s a really good offer and I may take you up on it. I will get the motor sorted first then go from there. Quote Link to post Share on other sites
Pops110 3,243 Posted October 27, 2020 Author Share Posted October 27, 2020 2 hours ago, xlr8or said: Yes - great suggestion. The only thing is the armboard internal cut-out is also dependent on the type of tonearm that will be used with the TT. VPI offered 3 types of armboards: 1) VPI JMW; 2) Graham Eng; and 3) SME tonearms. I can share a few images of TNT armboards sold in the past in the hope they can be CAD drawn and laser cut. Otherwise, we can wait for any second hand ones that come up. None on hifishark at the moment. 1 hour ago, xlr8or said: @Pops110 Can you confirm if the long levelling screws are still positioned inside the corner posts in the small centre holes looking from the top - they should have an Allen key head? 15 minutes ago, Alphason said: I had a new acrylic armboard made up for my TNT-2 and it looks like it came out of the factory. It can be drilled for whatever tonearm you like. I made one up out of craftwood first and trial fitted it since the original dimensions would have been imperial and I calculated it with metric measurements. If it is the same as mine, which the photo suggests, yours will be Width 100mm x Length 278mm x Thickness 14mm, is this correct? I was told that trying to polish black acrylic would end in tears, it seems that perhaps others have had a different positive experience in this respect. Any suggestions as to how? (I'll experiment with the brasso suggestion) There should be a circuit in the motor housing, if it has a 500 ohm resistor in there it may have been used for 240 volts with the existing motor. There is sure to be someone with more expertise than I to explain clearly how that can be the case. A speed controller is the way to go. The VPI SDS has 240 volts input but the output for the motor is 115 volts, so the motor you have would be fine if using an SDS. It would be really great to get a tonearm board laser cut from acrylic. Cost effective and could get a couple made at the same time. I would imagin that I will have to settle for a cheaper tonearm to begin with due to budget constraints. A few pics and more info would be great, I’ll measure the cutout tomorrow. I will pull the bottom off the motor housing tomorrow and have a look. I think trying to track down an SDS would be the best option. 2 Quote Link to post Share on other sites
Pops110 3,243 Posted October 27, 2020 Author Share Posted October 27, 2020 9 hours ago, klackto said: Even if it is a 115v motor it is still quite possible that (seeing that turntable was found in Australia) the pulley may already have been changed for the correct 50Hz one. Best way would be to replace the motor and using the existing pulley check the speed. In any case you'd only need to change the one pulley on the motor (not the other two) and a machine shop could easily make a new one from delrin or similar material. The pulley looks different from others I’ve seen online so you may be correct. Quote Link to post Share on other sites
Pops110 3,243 Posted October 27, 2020 Author Share Posted October 27, 2020 14 hours ago, Telecine said: You are going to need a speed controller. VPI options sold over time were the PLC speed controller, SDS speed controller or the new ADS speed controller. A step down transformer may work. There are a few third party options available but that is probably a different discussion. Yeah I see there are some other options like SOTA I think but probably would prefer to use the original motor housin so then I would need the PLC or SDS. Just need to find one. Quote Link to post Share on other sites
Pops110 3,243 Posted October 31, 2020 Author Share Posted October 31, 2020 What would be everyone’s thoughts on using a Jelco 12inch tonearm? I’m trying to keep the costs down so I can actually get it up and going again. As I was told yesterday, it may have been a great find but not so good a project. The cost to get it up and running could outweigh the actual value of the deck. I do have a few leads on some of the parts I need. 🤞 1 Quote Link to post Share on other sites
Telecine 3,906 Posted October 31, 2020 Share Posted October 31, 2020 (edited) 20 hours ago, Pops110 said: What would be everyone’s thoughts on using a Jelco 12inch tonearm? I’m trying to keep the costs down so I can actually get it up and going again. As I was told yesterday, it may have been a great find but not so good a project. The cost to get it up and running could outweigh the actual value of the deck. I do have a few leads on some of the parts I need. 🤞 I tend to agree with that assessment. I'm not sure that you would fit a 12 inch Jelco arm on that deck. Edited November 1, 2020 by Telecine 1 Quote Link to post Share on other sites
Pops110 3,243 Posted November 1, 2020 Author Share Posted November 1, 2020 I was recommended to get a 12 inch arm. I really don’t know, is there an arm you can recommend that’s not going to break the bank. Quote Link to post Share on other sites
aussievintage 3,579 Posted November 1, 2020 Share Posted November 1, 2020 11 minutes ago, Pops110 said: I was recommended to get a 12 inch arm. I really don’t know, is there an arm you can recommend that’s not going to break the bank. I am on an even cheaper budget, but still wanted a 12" arm. Haven't found one. I am still using a vintage B&O 9" arm, but it is performing well 1 Quote Link to post Share on other sites
Juzbear 562 Posted November 1, 2020 Share Posted November 1, 2020 The jello arms are excellent products, and there’s not much point wondering about the ones in the stratosphere, price wise, when you are living down on earth. Whilst they are no longer made, they are still available online from a few places. 1 Quote Link to post Share on other sites
crtexcnndrm99 547 Posted November 1, 2020 Share Posted November 1, 2020 Might be outclassed on your deck @Pops110 but I’m really enjoying the Fidelity Research offerings (specifically, FR-24mk2). Quality vintage Japanese engineering and slightly cheaper than the Jelco again (!) 1 Quote Link to post Share on other sites
Pops110 3,243 Posted November 1, 2020 Author Share Posted November 1, 2020 (edited) 10 minutes ago, Juzbear said: The jello arms are excellent products, and there’s not much point wondering about the ones in the stratosphere, price wise, when you are living down on earth. Whilst they are no longer made, they are still available online from a few places. Would the jello arms be a little floppy. 😁 I think you’re probably right there mate, get what I can afford for now. Edited November 1, 2020 by Pops110 2 2 Quote Link to post Share on other sites
Alphason 23 Posted November 2, 2020 Share Posted November 2, 2020 There is an SDS on ebay, they don't come up very often. The price is a bit less then I have seen them advertised for before. Here's the link: https://www.ebay.com.au/sch/i.html?_nkw=vpi+turntable&_sop=12 The armboard would have to be extended at the rear to accomodate a 12" arm, I think it could be done though. I fitted a 9" VPI memorial arm to mine, a 10" arm would fit equally well. Here is a photo of mine with the 9" arm and the armboard that I had made. The armboard is held by cap bolts from underneath. I think that it is a worthwhile project. Quote Link to post Share on other sites
Pops110 3,243 Posted November 2, 2020 Author Share Posted November 2, 2020 1 hour ago, Alphason said: There is an SDS on ebay, they don't come up very often. The price is a bit less then I have seen them advertised for before. Here's the link: https://www.ebay.com.au/sch/i.html?_nkw=vpi+turntable&_sop=12 The armboard would have to be extended at the rear to accomodate a 12" arm, I think it could be done though. I fitted a 9" VPI memorial arm to mine, a 10" arm would fit equally well. Here is a photo of mine with the 9" arm and the armboard that I had made. The armboard is held by cap bolts from underneath. I think that it is a worthwhile project. I have seen that one, cheers. I’m talking to somebody else about one, they might also have a few other bits and pieces as well. I was told that preferably a 12 inch arm would be best for this deck and would have no problems fitting. Soon find out I suppose. 😃 Quote Link to post Share on other sites
plato8010 46 Posted November 2, 2020 Share Posted November 2, 2020 A little diy project. TNT V, HW19 SDS SAMA Corian top, densified resin ply bottom, sandwiched between stainless steel. Note. Your spindle isn't the TNT V stainless steel type. 4 Quote Link to post Share on other sites
klackto 301 Posted November 3, 2020 Share Posted November 3, 2020 14 hours ago, Pops110 said: I have seen that one, cheers. I’m talking to somebody else about one, they might also have a few other bits and pieces as well. I was told that preferably a 12 inch arm would be best for this deck and would have no problems fitting. Soon find out I suppose. 😃 Be careful with 12" tonearms ..... most won't fit on that turntable. The VPI 12" arms are different as the pivot is on an outrigger of sorts so while the arm length is 12" the mounting distance is less. 1 Quote Link to post Share on other sites
Rocketfrogs 2,935 Posted November 3, 2020 Share Posted November 3, 2020 On 25/10/2020 at 8:56 PM, Pops110 said: It was found at the rubbish tip believe it or not. One of my mates from work was dropping a load of rubbish off and came across it. He went through everything and this was all that was there. I have recurring dreams of such a thing happening to me. Alas no luck so far.... 1 1 Quote Link to post Share on other sites
Pops110 3,243 Posted November 3, 2020 Author Share Posted November 3, 2020 6 hours ago, klackto said: Be careful with 12" tonearms ..... most won't fit on that turntable. The VPI 12" arms are different as the pivot is on an outrigger of sorts so while the arm length is 12" the mounting distance is less. Yep just measured now and the 12 inch Jelco won’t work. Quote Link to post Share on other sites
Pops110 3,243 Posted November 3, 2020 Author Share Posted November 3, 2020 On 01/11/2020 at 7:54 AM, Telecine said: I tend to agree with that assessment. I'm not sure that you would fit a 12 inch Jelco arm on that deck. 23 hours ago, Alphason said: There is an SDS on ebay, they don't come up very often. The price is a bit less then I have seen them advertised for before. Here's the link: https://www.ebay.com.au/sch/i.html?_nkw=vpi+turntable&_sop=12 The armboard would have to be extended at the rear to accomodate a 12" arm, I think it could be done though. I fitted a 9" VPI memorial arm to mine, a 10" arm would fit equally well. Here is a photo of mine with the 9" arm and the armboard that I had made. The armboard is held by cap bolts from underneath. I think that it is a worthwhile project. Yep the Jelco definitely won’t fit. I will wait till it gets here and see if it’s possible to fabricate a plate and armboard to make it work. The JMW arms are out of budget unfortunately, has anyone had any experience with the Helius designs tonearm? 1 Quote Link to post Share on other sites
Cardiiiii 1,465 Posted November 6, 2020 Share Posted November 6, 2020 Why not go with a Rega until you can afford something that will match the table? 1 Quote Link to post Share on other sites
Pops110 3,243 Posted November 6, 2020 Author Share Posted November 6, 2020 4 minutes ago, Cardiiiii said: Why not go with a Rega until you can afford something that will match the table? It’s an option for sure. I probably won’t have it up and running till after Christmas at least so there are a few options in the pipeline that will match with the VPI better. I have purchased an SDS and it’s on the way now. I have also purchased some TNT springs, unfortunately without the feet. I plan on fabricating some feet for it when they get here. Quote Link to post Share on other sites
Pops110 3,243 Posted November 8, 2020 Author Share Posted November 8, 2020 First real clean up and polish. I will remove the corner posts next to polish them properly. Has come up better than expected. 15 3 Quote Link to post Share on other sites
Telecine 3,906 Posted November 8, 2020 Share Posted November 8, 2020 1 hour ago, Pops110 said: First real clean up and polish. I will remove the corner posts next to polish them properly. Has come up better than expected. Unbelievable result. Great work. 2 2 Quote Link to post Share on other sites
Telecine 3,906 Posted November 8, 2020 Share Posted November 8, 2020 (edited) Some ideas for you in relation to replacement feet: http://www.vpiforum.com/viewtopic.php?f=9&t=6049 A very decent outcome: Edited November 8, 2020 by Telecine 3 Quote Link to post Share on other sites
Pops110 3,243 Posted November 8, 2020 Author Share Posted November 8, 2020 7 minutes ago, Telecine said: Some ideas for you in relation to replacement feet: http://www.vpiforum.com/viewtopic.php?f=9&t=6049 Thanks mate, I have had a look at that. Seems like a pretty decent option. I have got the springs and caps coming and some threaded rubber feet, I’m going to have a go at fabricating something to make it all work. 2 Quote Link to post Share on other sites
Telecine 3,906 Posted November 8, 2020 Share Posted November 8, 2020 7 minutes ago, Pops110 said: Thanks mate, I have had a look at that. Seems like a pretty decent option. I have got the springs and caps coming and some threaded rubber feet, I’m going to have a go at fabricating something to make it all work. I'd recommend that you just remove the pulley system from the deck. 1 Quote Link to post Share on other sites
Pops110 3,243 Posted November 8, 2020 Author Share Posted November 8, 2020 6 minutes ago, Telecine said: I'd recommend that you just remove the pulley system from the deck. Yep I think it’s the most viable option as the pulleys are unobtainable. I wish I could have got back to the tip because I’m sure that they would have been in the pile of rubbish somewhere. 1 Quote Link to post Share on other sites
Telecine 3,906 Posted November 8, 2020 Share Posted November 8, 2020 Just now, Pops110 said: Yep I think it’s the most viable option as the pulleys are unobtainable. I wish I could have got back to the tip because I’m sure that they would have been in the pile of rubbish somewhere. They are noise inducing anyway, you are better of without them. It would have been nice to find the feet and maybe the SDS speed controller though. 1 Quote Link to post Share on other sites
Pops110 3,243 Posted November 9, 2020 Author Share Posted November 9, 2020 1st corner post cleaned up and polished. Not perfect but 100% on what it was. 👍 3 2 Quote Link to post Share on other sites
unclemack 3,299 Posted November 9, 2020 Share Posted November 9, 2020 This is a beautiful thread. A spectacular find backed with superb support from the SNA crew. Hoping that you can get this back to its former glory. Very exciting stuff. 1 Quote Link to post Share on other sites
Pops110 3,243 Posted November 9, 2020 Author Share Posted November 9, 2020 4 minutes ago, unclemack said: This is a beautiful thread. A spectacular find backed with superb support from the SNA crew. Hoping that you can get this back to its former glory. Very exciting stuff. It is isn’t it, so many members have reached out with offers of help. Wont be quite back to it’s former glory, will have a few battle scars but it will make some noise again. 2 2 Quote Link to post Share on other sites
Cardiiiii 1,465 Posted November 11, 2020 Share Posted November 11, 2020 Can't wait to see the end result! 1 Quote Link to post Share on other sites
unclemack 3,299 Posted November 13, 2020 Share Posted November 13, 2020 On 09/11/2020 at 8:23 PM, Pops110 said: It is isn’t it, so many members have reached out with offers of help. Wont be quite back to it’s former glory, will have a few battle scars but it will make some noise again. Yeah. But that’s ok isn’t it? As long as it can still make beautiful music. The rest we’ll call “character”. Quote Link to post Share on other sites
