FS: Boney M Best Rasputin Atlantic P-10619A Japan Obi Vinyl Lp
Item Condition: E-
Suburb or Town: Turramurra
State: New South Wales
Payment Method: PayPal, Cash on pickup
Reason for selling: NLR
Further information: Japanese Press with OBI and Insert
PLEASE READ
    • By peppy
      Item Condition: Near New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Castle Hill, NSW 2154 State: NSW Payment Method: Cash, Paypal Reason for selling: Not Needed Changed Direction Further information:
      Yamaha WXA-50 wt Receipt + Warranty
      Purchased - 28-Aug-2020 from a local store.
      Comes with box remote , everything (never used remote still packed)
      PLEASE READ
    • By BlueOceanBoy
      Item Condition: Used = Excellent Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Teneriffe State: QLD Payment Method: Paypal Cash Reason for selling: NLR - going different direction For sale is this wonderfully musical and smooth headphone amplifier from ALO. Truly a king in its class. I got this from a fellow SNA member and he had lovingly cared for it and amassed a great collection of vintage tubes (described below) to roll for different signatures. The amp is in full working order. The output from each headphone socket is the same and you can run all four at the same time to easily A-B. There are three RCA inputs also, so this is a fantastically neutral tube amp to do comparison testing on. Every store should have one!
      FREE AUS Shipping - this thing weighs a ton!
      ALO Audio Studio Six SET Vacuum Tube Headphone Amplifier
      Description
      The Studio Six is a Class-A Single-Ended Triode (SET) circuit design. Zero-Feedback and 100% Tube Amplification.
      Built For Life
      Uncompromising quality in build and design. Conservative part ratings and circuit design. Translates into effortless, under-stressed operation, extended tube life and long-term amplifier reliability. An obsolescence-proof piece of audio equipment, A timeless design built to last a lifetime.
      Reference Amplification
      Class-A Single-Ended Triode (SET) circuit design with zero-feedback and 100% tube amplification. Designed for resolution of fine musical details, expansion soundstage presentation, and lush tonal quality.
      Totally Tubes
      Only vacuum tubes with established reputations for sonic virtue are in this design. Selecting tubes that are now and will continue to be available in the global audio marketplace.
      Pure Power
      The power supply is a “Virtual Dual Mono Block” design. Featuring vacuum tube rectification. Filtering for the left and right input stages, including two glow discharge regulator tubes. And separate multi-stage filtering for each left and right channel output tube.
      Designed For Headphones
      A proprietary output stage accommodates a wide range of headphone impedance from 8 to 600 ohms, with ease. The Studio Six drives many pairs of headphones with no sacrifice to fidelity. The ideal amp for shared listening sessions.
      Colour    Black
      Headphone impedance compatibility range    8 Ohms to 600 Ohms
      Maximum rated output power    1,000 milliwatts into 8 to 32 Ohms
      Amplifier input impedance    95k-Ohms
      Amplifier input Voltage for full-rated output voltage into various headphone impedances    1.00V RMS input for 4.0V RMS output into 16 Ohms
      1.30V RMS input for 5.7V RMS output into 32 Ohms
      1.70V RMS input for 7.5V RMS output into 75 Ohms
      1.85V RMS input for 8.3V RMS output into 150 Ohms
      1.70V RMS input for 8.2V RMS output into 300 Ohms
      1.65V RMS input for 8.1V RMS output into 600 Ohms
      THD+N (1kHz input) at 1V RMS output into stated load impedances    32 Ohms 0.26%
      150 Ohms 0.12%
      THD+N (1kHz input) at 250 milliwatts output into stated impedances    32 Ohms 1.0%
      150 Ohms 2.0%
      Frequency Response -3dB (Referenced to 1kHz, 250 milliwatts output) into stated impedances    32 Ohms 6.0Hz to 39kHz
      150 Ohms 16.5Hz to 36kHz
      Frequency Response -1dB at full-rated (2.83V RMS) 1,000 milliwatt output into 8 Ohms    15Hz to 20kHz
      S/N Ratio    78dB (unweighted) below full 2.83V RMS output into 8 Ohms
      Fuses    100/110/120 = 1.25 Amp / 250 Volt
      220 / 240 = 6.30 Amp / 250 Volt
      http://headphone.guru/alo-audio-studio-six-and-phono-stage-heirloom-quality-audio/
      http://www.tonepublications.com/MAGPDF/TA_057.pdf page 89
      The tubes are:-
      Drivers
      Sylvania 6SN7W metal base (Bought new for 175 pounds and not used much) - great tube!
      Mullard ECC33 (Bought new locally for AUD$250 and not used much) - great tube!
      Ken Rad 6SN7GT black glass (Very good condition) - like the Ken Rad for bass.
      Brimar 6SN7GT black glass (Used)
      GE 6SN7GTB (stock)
      Power tubes:-
      Philips JAN 6V6GT blue letterings
      Philips JAN 6V6GT green letterings
      Brimar 511/6V6GT brown base black glass
      RCA 6V6GT smoke glass
      Rectifiers
      1 Mullard GZ34 Blackburn factory - both bought new from a local seller.
      1 JJ Electronics GZ34 (stock tube)
      OB2
      4 pairs of Raytheon
      1 pair of Mullard
      You will have more than enough tubes. No need to hunt for more tubes. 🙂
      Rolling 6SN7, 6V6 and rectifier makes the most difference.... in that order. There are Raytheon and Mullard OB2 and you'll not find much difference between them.
      You'll have 2 very good drivers and they are very pricey. The Sylvania 6SN7W metal base and Mullard ECC33. Besides there are Ken Rad 6SN7G black glass and Brimar 6SN7GT black glass. They give different tones that can be easily heard.
      Sylvania 6SN7W metal base - Very clear, good soundstage and a pretty tight fisted bass.
      Mullard ECC33 - More spread out, more refined and subdue but astonishingly clear. It's a typical British kind of tone.
      Ken Rad 6SN7GT - One of the best bass. Warmer.
      Brimar 6SN7GT - A lighter version of the Ken Rad but a nice variation.
      Amongst the 6V6GT that are included:-
      RCA 6V6GT smoke glass - Typical RCA smoke glass that actually sounded similar to the RCA 6SN7GT smoke glass. Warmer, lusher.
      Brimar 511 / 6V6GT - Like the Brimar 6sn7gt, these are much clearer than the RCA. You'll like these.
      Philips JAN 6V6GT blue letterings - You'll like these too. Seems to be the variation in between the RCA and Brimar.
      Philips JAN 6V6GT green letterings - Quite similar to the blue lettering. Difference is slight.
      Rectifiers
      People have used Cossor 53ku wide glass, GEC U52 and Mullard GZ34. Cossor has the most bass impact. GEC U52 is very clear and a very good rectifier but so expensive. Tom's recommendation is to stick with the recommended GZ34 and you'll find the Mullard GZ34 blackburn factory ones very good and at a price much less than the Cossor and GEC.
      It's a wonderful journey with the Studio Six.
    • By Minimalfi
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Wollongong State: NSW Payment Method: EFT, PayPal plus 3% Reason for selling: No longer required Further information:
      Really well made cables with a great sound. I was impressed with bass and high end detail.
      Q2’s inner Long-Grain Copper (LGC) conductor is surrounded by an outer spiral of 11 strands of LGC. The result is AQ’s new flexible Solid+ Concentric Conductor, with sound quality even closer to that of an ideal solid conductor and yet big enough to make a great cable with only two conductors. The two conductors (+ and -) are spiraled for minimum inductance (inductance makes sound seem out of focus), and maximum clarity and dynamics. This ideal cable is then given a sexy, square, deep black outer jacket.
      Nice review here
      PS Audio
    • By hugo_wilco
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Melbourne State: VIC Payment Method: PayPal EFT Cash on pickup Reason for selling: NLR Further information:
      Practically brand new! mint in box. Used once to make sure it works. Came with NDX2 which is sold. Save on RRP.
    • By Kafunis
      Item Condition: NM Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: TARRAGINDI State: QLD Payment Method: CASH, Bank Transfer Reason for selling: NLR Further information:  Fatboy Slim-You've Come A Long Way, Baby VMP Exclusive 2 x Sky Blue w/ Coffee Splatter Vinyl , Only 2,000 worldwide includes booklet  and Exclusive Cover , in 99% shrink, just opened to access records- played once .
      Pick Up Tarragindi or can post, happy to combine with other Vinyl .
      PLEASE READ
