Ok, so my Xiaomi WEMAX One Pro ended up stuck in an firmware update loop and trying to stop that I factory reset it which totally borked the projector. Completely unusable.
I believe the software issue is because it was a Chinese domestic product which the vendor hacked to add English,  a few other features + root access.  I was never able to install apps on it so used HDMI only.  I guess it was defective from the get go. On the upside it was all inside of 12 months so Amazon will be accepting a return for refund.
I'm now looking at the JmGO S3 as that appears to natively support English as it's an international version. It's slightly more than the WEMAX A300 though unlike the WEMAX it's not a domestic Chinese product through rather a proper international product. The software interface looks far better, and it's slightly brighter. The only downside I can see is it doesn't have 8 point positioning though it does have some adjustments.
Considering how much I enjoyed the WEMAX at only 1080p, I expect 4K should be stunning.
Does anyone here have experience with the JmGO S3?
Edited by MattyW
Nobody? Perhaps I'm better off asking which of two projectors you would personally buy.
In the running is:
JmGO S3 - 3000 ANSI Lumens - $4,305
Fengmi 4k - 2000 ANSI Lumens - $2,938
Would the JmGO be worth the added expense. Help me decide guys. I'm sitting on the fence with this one, sometimes leaning towards one, then the other.  The interface of the JmGO certainly seems nicer and auto connection to active HDMI inputs is a definite plus. I believe some of the Fengmi units exhibit coil whine as well? Really the only reason the Fengmi is in the running is price. Both are 4k projectors.
Edited by MattyW
yep.. none of those listed.. get a real pj for Ht room . if wanting a tv replacement get something you can test.
looks chinese domestic to me.. not that it means its no good being chinese. just not real HT imaging.
Edited by hopefullguy
The JmGO S3 has an international version, there's also a domestic Chinese version. I think I'll be giving it a crack. Just need to sell off a few things first. Chinese ultra short throws are the only ones within reach price wise these days and not needing professional installation is a massive plus for me.
Edited by MattyW
2 minutes ago, oztheatre said:
Just don't pay that much, they are $550 us on amazon..
The S3? Do you have a link?
I've been looking at the S3 international version: https://www.banggood.com/International-VersionJMGO-S3-Ultra-Short-Throw-4K-Laser-Projector-3000-ANSI-Lumens-3840x2160-Resolution-Android-2GB+16GB-Beamer-2_4GHz+5GHz-WiFi-Bluetooth4_0-3D-Home-Theater-Prejector-p-1659272.html?rmmds=detail-top-buytogether-auto&cur_warehouse=HK
Edited by MattyW
7 minutes ago, oztheatre said:
No it was the other one for 549.
Yeah, not considering that projector hey. I'm sticking with ultra short throw and want true 4K  :)
Hey, I just encountered exactly the same problem with the WEMAX one pro and can't figure out how to fix it. How were you able to get a return for refund? Mine is also within 12 months, however I can't find any return policy saying that I will be able to do so. So frustrating not having realised that the product was already hacked! Which vendor did you buy from on Amazon?
I dropped it off to the post office on Saturday.  Amazon has said they'll give a full refund once it's recieved back in good condition. It's in its original packaging so there should be no issues there.
I'll need to look up the seller from my desktop PC. My phone has issues signing into Amazon unfortunately.
I simply opened up my old order and opened an online chat with Amazon support.  They sorted things out promptly.  I was really interested in a replacement though they advised since they don't know the sellers stock levels they could only arrange a return for full refund. Now I get to upgrade to a better projector. Naturally I looked at the WEMAX A300 though my experience with this one has turned me off it. That and an owner has found issues with yellow and white spots developing with the A300.
The JmGO S3 is about $500 more on BangGood so I'm going to grab that. Videos show a much more user friendly interface with easily selectable languages which I now recognize as a pretty big deal.
Not bad Amazon! I also ordered from the same vendor. I was in a full blasted panic. I ended up doing a hard factory reset (after the failed soft factory reset)- found via youtube for a different model. It actually worked and just stripped the Android and other bloatware right back to the original Chinese software. Used Google image translate to navigate - and found that there actually was an English setting. I don't use the Android at all so wasn't fussed - but on further research some people have developed Android launchers to download and install so I might have eventually been able to restore that functionality.
The original is actually much cleaner and I prefer it to be honest! I use everything else through the PS4 so it's just a pure viewer for me.
Heard good things about the JmGO S3! But I'm hoping by the time I upgrade...I'll have the money for the new Samsung 4K short throw, depending on how it turns out. Huge Samsung fan.
On a side note - I've heard really bad things about Banggood. Damaged goods turning up and them refusing refunds etc. Tread carefully and best of luck!
Thanks the way for taking the time to outline how you got the refund - I'll keep it in mind for the future! Amazon must just not advertise that they will do this type of refund.
  • Thanks 1
Ah bugger..... With Amazon everything is out of stock..... It's available on eBay for a further $200. eBay will be great for the initial order though unfortunately after that I'll be on my own. If only I could order on Amazon though even the WEMAX A300 is out of stock on there let alone the JmGO. I guess I could consider the VAVA 4K though for that cost I could look at the WEMAX D30 :(
I guess I'll buy from eBay and turn off automatic updates just in case.
I don't need anything other than easily selectable HDMI inputs. I'll be pairing with an nVidia Shield for the 4K AI upscaling  :D
Edited by MattyW
Due to crazy pricing on eBay and no availability of pretty much any thing but the VAVA 4K for $5,500 I've taken a gamble on ordering the JmGO S3 via Banggood. Hopefully it works out alright. While I do feel uneasy with your feedback on Banggood, $5,500 for the VAVA 4K on Amazon or the the JmGO S3 on eBay seems a bit extortionate. With some luck it arrives undamaged. I paid via PayPal so I'll still have some recourse either way.  :)
Edited by MattyW
Ah the VAVA 4k ❤️ Tried to stretch my budget hard for it but no go - had to buy and install a better screen as well (converted to short throw).  I'll cross my fingers for you - I'm sure plenty of people have been lucky and had good experiences. Definitely good to have PayPal backup! And 100% no updates haha - I've learnt that lesson.
Also - "I'll be pairing with an nVidia Shield for the 4K AI upscaling" awesome!
  • Love 1
Yeah, fingers crossed. The VAVA was just too exxy for me. I'm only running a very cheap 150" screen that set me back $180 myself. Seems fantastic at night time.
Most of the feedback I've read on Reddit is that most of the users who stated they never received their goods did actually end up receiving it. It's simply the long wait and lack of updates that get to people.
@HLaurens don't forget to update your product review of your projector on Amazon. It really is a problem and in my case I was never able to select a HDMI input again once factory reset. Made it completely unusable to me. The JmGO looks pretty fantastic in terms of the user interface which really does draw me to it, as well as native 4K. A shame it only has 2x HDMI inputs though I can work around that.
Very nice,  the projector is now marked as shipped. Now for the long wait. I don't expect tracking information will be updated,  and probably anywhere up to or even a little over a month till delivery.  I imagine BangGood is the same with Aliexpress in this respect. I've had overall rather good experiences with Aliexpress.
Hot damn! The projector is showing as in Sydney,  being sorted for delivery.  Can't be long now. This is far faster than I ever expected  :)
Ah great,  been reading some terrible things about Fastway/Aramex. Seems it will be a very long time until I recieve the projector after all.... I just hope they don't damage it or lose it is all.
Things are all over the place currently as everyone knows, but I just received a posted item from QLD today that was sent only two days ago!
So live in despair tempered with a dash of hope ! 😉
  • Love 1
I just hope it arrives soon. :)
I jumped all in and ordered a 100" ALR PET Crystal UST screen too. Better than my current 110" white PVC screen I'm sure.
Edited by MattyW
$5500 for a chinese made no name projector... mind blown... sorry. I think you're crazy.
Sorry. $4000 on 'banggood' whatever that is. 40% off 😲
Native 4k means nothing if it doesn't have good optics.. And it wont, I'd bet good money on that.
It's not native 4K anyway, it's a 2K DLP chipset with fast moving mirrors. cheating, but faster than what the human eye can pick up. But not native 4k at all. dont fall for the marketing bs.
Don't think it even does p3 colour? You could have got the newest Epson LS500 for the similar money...
And this is woeful Warranty: 30-day refund or replacement - that is a complete lack of confidence in their product. 30 days... wow..
https://www.banggood.com/JmGO-S3-4K-Laser-Projector-TV-3000-LM-Full-HD-1080P-Support-3D-100-300-Inch-Smart-Home-Theatre-Projector-Chinese-Version-p-1433607.html?akmClientCountry=America&utm_source=google&utm_medium=cpc_ods&utm_campaign=arvin-led-sds-view-led-content&utm_content=arvin&gclid=CjwKCAjw5p_8BRBUEiwAPpJO61vzL1-vvNkhAdY0bk48xl6Ys3ovtCeqKQIHh02oiIfenQWu_73Y2hoCchEQAvD_BwE&cur_warehouse=CN
Features:
● Amlogic T968 quad-core chip for stable performance
● 2GB DDR3 + 16GB eMMC for smooth running and data storing
● High transparency coated lens for clear image projection
● 45 degree horizontal and vertical keystone for casual placement and clear image
● 100Mbps Ethernet for fast network connection
● 2.4GHz + 5GHz dual-band WiFi for convenient network accession
● Create your own smart home theater
● Enjoy unbelievable HiFi sound quality
● Higher brightness and free eyes harm
● A chance to have a reunion with your family
● Remote control is powered by two AAA batteries ( not included )
Are there any features that actually matter there?
A chance to have a reunion with your family. Yep cheap chinese projectors always make that happen 🤣
Sorry for sounding harsh.. but this is really needed here. I really do think this will end up as a very expensive paper weight in the end.
$7.500 is not similar money. It's 43% more. I already stretched the budget past what I should be spending to get this so there's just no point touting more expensive projectors to someone who can't afford it.
Besides you've incorrectly linked the Chinese version. I've the International version coming: https://www.banggood.com/International-VersionJMGO-S3-Ultra-Short-Throw-4K-Laser-Projector-3000-ANSI-Lumens-3840x2160-Resolution-Android-2GB+16GB-Beamer-2_4GHz+5GHz-WiFi-Bluetooth4_0-3D-Home-Theater-Prejector-p-1659272.html?rmmds=search&cur_warehouse=HK
Frankly I haven't even looked at the warranty. When buying Chinese it's not even a consideration unless they've a presence here in Australia.
Once set up this projector will not be connected to a network. No updates to bork it like the last one. Learned my lesson on that last time. I gnerally find the quality of the hardware good with plenty of Chinese gear, it's the software you have to worry about. Minimize that and there's fewer issues.
I'll have my nVidia Shield going direct into one input and my AVR into the other. Fibre back to the AVR for sound from the shield (I only run 5.1).
My only real concerns are around Aramex/Fastway delivering it. Still no updates since Monday  :(
Edited by MattyW
It's 5400 RRP mate, not 7500. and you get 3 years local warranty and support and can be had for less too.. Anyway, good luck, I think you may need it. Just hate to see people regretting purchases like this that's all.
The specs are the same.. And you still get A chance to have a reunion with your family :D
@MattyW I got 2 different prices when i looked, one was that $7500 or close and another was $6800 or there about.
Edited by muon*
Yup, even the lower price is more than I will spend.  The JmGO S3 is still the best choice for me. Significantly less money.
4 hours ago, MattyW said:
First price came up when I searched was $7500. Can't say I've looked further seeing as I've already something on order
RRP with a 120 inch ALR screen is 7199.
PJ by itself has an RRP of 5499.
6500 with a 100 ALR screen.
Yeah, a bit over $5,100 for the JmGO S3 with an ALR screen.  Not really worth debating at this point.  It's already on the way.
Well,  I recieved both my projector and ALR screen today.  I tried the projector with my old cheap white PVC screen and found the colours really pop compared to my previous Wemax One Pro despite being rated at 3000 ANSI lumens vs 7000 which leads me to think that they rate them differently somehow.
Picture quality absolutely destroys my 70" HiSense TV let alone the old projector.  Managed to get the new screen set up and briefly tested. It's even better again!
Setup of the projector was an absolute snap compared to the Wemax. A really easy to use interface and it defaults to English which is great.
I'll spend a bit more time with it tonight after my wife goes to bed and will report back some more details  :)
Edited by MattyW
Yep, absolutely mind blowing.  Brighter than a TV screen and smoother movement too. Very very impressed. :)
A shame my phone just can't capture what's there. Such is life.
Edited by MattyW
  • Like 3
  • 3 weeks later...
Hi, MattyW!
Thank you for detailed review!
I've purchased JmGO S3 as well - I'm very glad with quality and brightness of projector. Also input lag is minimal (I can't feel it at all) - so absolutely no problems playing video games (Guitar Hero for example).
But there are few issues:
- poor Smart TV functionality - the only app which works is Smart TV Youtube (but sometimes it hangs), all other apps are not working or not usable. I've bought Smart TV Stick, so that's not an issue, but just intersted - is it something wrong with my device, or is it common?
- top cover stopped closing on shutdown. If I manually close it - it opens on startup, so mechanism is working. I will try to reset to factory settings and won't update to most recent.
Mmm, not sure about the smart TV functions as I've used mine with an Nvidia Shield from the beginning. It automatically connects to HDMI1 on startup which I set in settings. Thankfully the lid is working on mine too.
I did have a brief play with the apps though decided they were not worth using. Android 6 is positively ancient and software makers just don't support it. Far better to use an nVidia Shield or Apple TV.
It's unfortunate your top cover has stopped working and to be honest it's something I was concerned with when purchasing mine also. That said I don't really understand why it's even necessary in the first place. No other makers bother with a top cover. Seems more about aesthetics than anything else and needlessly complicates an already excellent product.
Edited by MattyW
  • 2 weeks later...
On 11/11/2020 at 7:18 PM, DartVedro said:
Hi, MattyW!
Just an update:
Contacted "After-sales service" - they replied very fast (just few hours). They helped me to understand that I'm just accidentally turned off "Lens switch" option (which toggles lid on start/shutdown).
So everything is good now in terms of projector (smart TV still poor).
  • MattyW changed the title to JmGO S3 UST projector
    • By manbat
      Item Condition: Mint Shipping Options: Pickup available and you can audition. Suburb or Town: Melbourne State: VIC Payment Method: EFT Reason for selling: Renovations Further information:
      Professional series -  Sony VPLW520ES Projector Bundle (latest software upgrade.) White.
      Lamp time – 2200hrs (lap rated for 6000hrs) – Additional lamp also available
      This is the native 4K deal professional series – all glass Sony lenses made in Japan, excellent reviews.
      https://www.techspot.com/products/projectors/sony-vpl-vw520es.122529/
      https://www.avforums.com/reviews/sony-vpl-vw520es-4k-projector-review.12100
      What you get
      1.     Sony 4K VPLW520ES Projector
      2.     Screen Technics Tab Tension 110 inch screen (electric screen with remote)– I had this made to order with extra-long lead. Great screen - no striations. Mint condition.
      3.     Blue Stream - HDMI – over ethernet kit (HEX70B-KIT) Base and Transmitter set - https://www.blustream.com.au/
      4.     Projector mount comes from Screen Technics model PRGUNV.
      5.     Projector extender from Screen Technics.
      6.     Spare lamp (new – additional cost negotiable)
      7.     Remotes – mint condition
      Nearly three times the price to buy new as a kit. (4.5 years old)
      I am selling everything as a package. All items are mint. Pick up only.
      Serious parties only - home demonstration available.
      Strongly suggest that if purchased you get professionals to remove and reinstall at your residence.
      No boxes available – instructions and remote for projector and screen present and correct in mint condition.
      Sony VPLVW520ES Reviews
      What Hi-Fi
      A pull-out-all-the-stops performer with future-proofing to its name
      Pros:Fantastic picture all-round, HDR support, Native 4K, Future-proofed, Solid, attractive design
      Cons:No 3D glasses, A pricey option
      Home Cinema Choice
      The selling point of the VW520ES is essentially this: it gives you both a native 4K resolution – something no other brand has yet been able/bothered to manage on a home cinema projector – together with high dynamic range (HDR) playback.
      Pros:4K pictures look amazing; HDR pictures look even more amazing; good setup flexibility; good price for what’s on offer
      Stuff TV
      A future-proofed projector with a license to thrill
      Pros:Startlingly good picture all-round, HDR and 4K, Dead simple set-up
      Cons:No 3D glasses, Still a pricey option
      https://www.avhub.com.au/product-reviews/sound-image/sony-vpl-vw520es-4k-av-projector-review-430128
      Screen - Electronic Tab Tension.
      Screen Technics
      https://screentechnics.com.au/products/roller-screens/motorised-screens/electricinema-side-tension-screen
      110 inch tab tension extra-long lead (allows to have the screen positioned lower than usual  – remote – excellent screen free of any striations.
      Blue Stream
      Projector mount comes from ScreenTecnics model PRGUNV.
      Projector extender
      PLEASE READ
    • By manbat
      What you get
      What Hi-Fi
      Home Cinema Choice
      Stuff TV
      Screen Technics
      Blue Stream
      Projector extender
      PLEASE READ
    • By robbyvikram
      Item Condition: As New Shipping Options: Pickup available but audition is not available. Suburb or Town: Bayswater North State: VIC Payment Method: Cash, PayPal Reason for selling: NLR Further information: As New rarely used
      PLEASE READ
    • By oneneo
      Hi all,
      I just got the BenQ TK800M from JB Hi Fi.
      Nice projector, easy to set up.  Image quality is awesome mostly, but, I am having some pain as follows:
      Playing through a Panasonic UB420 disc player:
      1) Youtube 4K/FHD materials look awesome!
      2) Netflix played through the app in the player - Everything looks awesome!
      3)  4K UHD discs like the BBC Planet Earth series documentaries, Dynasties, etc, all look awesome!
      4)  1080p Blu-ray discs, all look awesome!
      However, in all 4K UHD MOVIE  discs that I tested, the image is very flat during low contrast and dark scenes.   Bright and sunny scenes are somewhat fine, but they are not as nice as the above scenarios 1-4.  So, if I make an across the board changes to Brightness/Contrast/Colour, etc, it will apply to all scenes, which is not what I want to happen.
      I suspect this issue has something to do with HDR settings on either the player and/or the projector.
      Did anyone here have similar issues, and what did you have to do in terms of adjustments on the player or projector to solve this problem?
      Thanks for your help.
      P.S.  This thread in AVS forum sounds similar to mine but sadly none of the respondents provided any practical advice. https://www.avsforum.com/threads/hdr-worse-than-sdr.3168461/
    • By 943
      Item Condition: Good Shipping Options: Pickup available and you can audition. Suburb or Town: Kingston State: ACT Payment Method: Any Reason for selling: No longer required Further information:
       NEC LT280 projector in very good condition. 36% lamp life left.
      https://www.projectorcentral.com/NEC-LT280.htm
      Comes with long power cord (about 5m) and HDMI to VGA converter plus VGA cable.
      Local pickup or post at buyer’s expense
