Item Condition: Excellent for age
Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost.
Suburb or Town: Central Coast
State: New South Wales
Payment Method: Paypal, EFT, Cash on pickup.
Reason for selling: NLR
Further information:
Has the upgraded USB board, recently installed by Kimil electronics.
Original RRP $12k
excellent cosmetic condition
fully functional with no problems or issues
Remote control included
Original owners manual, windows driver cd (windows 7)
Factory shipping carton for safe transport
Smoke free, pet free home
Buyer to pay PayPal fees if applicable
Local pickup available or shipping at buyers expense
What Hifi 5 Star rating
"The pricey DAC 8 is one of the most organic-sounding digital products we've
heard"
"Wonderfully big, authoritative, refined presentation; mighty bass; top
class refinement; solid build"
-accept signals up to high-resolution 24Bit/192kHz level
-inputs optical, coaxial and USB are here, accompanied by the rarer BNC and
AES/EBU alternatives.
-outputs include RCA and balanced
From the Audio Research Website:
We are pleased to introduce the new DAC8 digital to analog converter.
Although physically similar to its predecessor, the DAC8 represents new
engineering that advances the state of the art in high resolution USB audio
and S/PDIF audio.
Audio Research has maximized the USB capability of the DAC8 by incorporating
USB 2.0 HS (High Speed) which runs at 480Mbps. USB 2.0 HS has a lower jitter
specification than USB 2.0 FS (Full Speed 12mbps), consequently the DAC8 is
capable of reproducing music at higher definition/resolution (up to 24/192)
than products communicating at USB 2.0 FS speeds (24/96).
In addition, the DAC8 employs a low jitter Dual Master Oscillator design
that will provide superior digital to analog conversion via its USB 2.0 HS
input as well as via the more traditional S/PDIF (RCA, BNC, Toslink and
AES/EBU) inputs that are also included on the DAC8. Our USB 2.0 HS audio
interface is optimized for all six sample- rates currently in popular use;
44.1, 48, 88.2, 96, 176.4 and 192kHz.
In the past, S/PDIF was the default interface mode for High Resolution music
files at 176.4 and 192kHz. Now, with Audio Research's Dual Master
Oscillator, USB 2.0 HS interface, and our Quad D/A converter design, USB
audio is finally elevated to the status once dominated by S/PDIF.
Consequently, regardless of whichever digital input you select, the Audio
Research DAC8 promises to provide a superior listening experience.
In addition to the High Performance USB design, the DAC8 features:
"DAC8 HD Audio Device" software drivers, which allow listening to your music
in its native sample rate as well as assuring BIT PERFECT, low jitter, data
transfer from the computer to your DAC8. Because PC and Mac operating
systems do not adequately support sample rates over 96kHz, Audio Research
has developed ASIO drivers to make the USB audio experience sonically
transparent at all sample rates. Sample Rate measuring function: Measures
and displays the correct digital sample rate being sent to the DAC8. This
works in USB as well as S/PDIF mode. Consequently, at a glance, you always
know exactly which sample rate is being decoded. The DAC8 employs four
24-bit D/A converters. Each channel uses dual 24-bit D/A converters running
in mono mode to lower the noise floor and increase the dynamic range. Dual
Master Oscillators: When the time base of any DAC is not an integer multiple
of the digital music sample rate, decoding and quantization errors occur.
Consequently, the DAC8 uses two low jitter Master Oscillators; one for 44.1,
88.2 & 176.4kHz sample rates and the other for 48, 96 & 192 kHz sample
rates. The DAC8 automatically selects the correct Master Oscillator the
instant digital music is detected at the selected input. All inputs are
galvanically isolated from the source to reduce or eliminate noise and/or
jitter from entering the DAC8. The Analog amplifiers in the DAC8 have
received the same attention to detail as the digital section. Each channel
of the DAC8 uses a true direct-coupled differential amplifier with a
bandwidth in excess of 90kHz. The DAC8's USB and S/PDIF inputs are designed
to accept signals from an HRx, 176.4kHz, 24-bit, High-Resolution music
server system playing HRx's DVD-R recordings. See
www.referencerecordings.com/HRxSETUPS.asp for recommended music server
setups. By virtue of all of the above points and our proprietary software
drivers, intrinsic jitter has been reduced to less than 10ps.
DAC8 HD AUDIO DEVICE SOFTWARE DRIVERS:
The DAC8's USB driver software provides your computer with special
high-speed audio drivers not supplied by MS Windows or Mac OS. The Audio
Research USB drivers are specially designed to assure low jitter BIT PERFECT
data transfer between the server/computer and the DAC8 at all sample rates.
Our drivers setup the USB interface to guarantee bandwidth, independent of
active bulk transfers from the hard drive.
From the ARC icon in your computer's input tray you can set the DAC8 to any
sample rate from 44.1 to 192kHz and allow the music server/management
software to up or down convert your music to the selected sample rate.
Music lovers can use custom sample rate conversion algorithms or other file
formats provided by third party suppliers such as Windows Media Player,
iTunes, J Rivers Media Center, Media Monkey, FooBar, and many others to
optimize your music experience.
The DAC8 is a fully balanced, zero-feedback, solid-state design utilizing a
direct-coupled FET output stage with generous regulated power supplies and
seven stages of regulation. There are separate new digital and audio power
transformers, and the board material is the same as what we use in our
Reference products. Dynamic, forceful, immediate, and possessing remarkable
resolution and transparency, the DAC8 is a sonic knockout that is worthy of
the finest music systems.
With a choice of high-resolution 24/192 S/PDIF inputs (RCA, BNC, AES/EBU and
Toslink) in addition to the highest resolution 24/192 USB available, the
ability to adjust sample rates, the DAC8 provides the new standard in high
performance digital music playback.
Edited by Silver Audiophile
  • Like 4
  • Love 1
    • By Spinnergeoff
      Item Condition: used Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: baulkham hills State: NSW Payment Method: EFT, cash on pickup Reason for selling: surplus Further information:
      SW1S 8" passive subwoofer comes with the NHT MA-1 sub amplifier which has line level inputs and speaker level input/output, which means this set can be used with any stereo amplifier lacking sub-out or pre-out.
      Can pack and send at buyer's cost and risk.
      PLEASE READ
    • By smart
      Item Condition: good Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: PERTH State: WA Payment Method: CASH,EFT,Paypal Reason for selling: NLR Further information: Calibration Tapes 3 x SONY 1 x MRL
      see photos for info
      (plus about 4-5 misc calibration tapes)
      price for thr lot
      PLEASE READ
    • By Unsound
      Item Condition: Excellent - NLR Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Arthurs Seat State: VIC Payment Method: Cash, Bank Deposit, PayPal or Credit Card (plus 1.9%) Reason for selling: From my office - moved to home office - NLR Further information:
      Currently loaded with DD-WRT firmware - reset takes it back to LINKSYS STANDARD FIRMWARE.
      Wi-Fi Technology:
      AC1900 Dual-band Gigabit, 600+1300 Mbps  Network Standards: 802.11b  802.11a/g  802.11n  802.11ac Wi-Fi Speed:
      AC1900 (N600 + AC1300)  Wi-Fi Bands:
      2.4 GHz and 5 GHz (simultaneous dual band)  Wi-Fi Range:
      Very large homes  Number of Ports:
      1x USB 3.0 port, 1x USB 2.0 port, 1x eSATA port  Number of Ethernet Ports: 1x Gigabit WAN port  4x Gigabit LAN ports Antennas:
      4x external, dual-band, detachable antennas  Processor:
      1.6 GHz dual-core ARM-based  Memory:
      128MB Flash; 512MB DDR3 RAM  LEDs:
      Power, Internet, 2.4 GHz, 5 GHz, LAN 1–4 (10/100Mbps or 1Gbps), USB 3.0, USB 2.0, eSATA, Wi-Fi Protected Setup™  Wireless Encryption:
      64/128-bit WEP, WPA2 Personal, WPA2 Enterprise  VPN Support:
      PPTP Pass-Through  Operation Modes: Wireless Router  Access Point  Wired Bridge  Wireless Bridge Storage File System Support: FAT  NTFS  HFS+ Easy Setup: Browser-based Setup  Linksys Smart Wi-Fi Setup Certified Operating Systems:
      MacOS (10.X or higher), Windows 7, Windows 8.1, Windows 10  Minimum System Requirements: Internet Explorer® 8  Safari® 5  Firefox® 8  Google Chrome™ Dimensions (LxWxH):
      121 x 75 x 26 mm (4.76 x 2.95 x 1.02 in.)  Weight:
      722.2 grams (28.43 oz)  Security Features: WPA/WPA2  128 bit AES link encryption Regulatory Compliance:
      FCC class B  Other Certifications: DNLA Certified  Wi-Fi Alliance  WPS Setup Power Supply:
      Input: 100-240V ~ 50-60Hz; Output: 12V/2.5A
      PLEASE READ
    • By Unsound
      Item Condition: Very good - operates perfectly Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Arthurs Seat State: VIC Payment Method: Cash, Bank Deposit, PayPal or Credit Card (plus 1.9%) Reason for selling: From my office - moved to home office - NLR Further information:
      Rack mountable.
      This is a professional quality 48 port switch.
      Specs and features:
      Feature Value
      Interfaces
      48G (P01 - P48)
      Fiber Optic
      4 Mini-GBIC Combo (P45f - P48f)
      PoE
      N/A
      Flash Memory Size
      2MB
      SRAM Size and Type
      16MB DDR
      Table A-2. Switch Performance
      Feature Value
      Switching Capacity
      48 x 1Gbps
      Forwarding Method
      Store and Forward
      Packet Forwarding Rate
      10M:14,880 pps / 100M:148,809 pps / 1G:1,488,095 pps
      MAC addresses
      8K
      Packet RAM buffer capacity
      512K-bytes
      GS748T Smart Switch Features and Defaults
      Table A-3. Port Characteristics
      Feature Sets Supported Default
      Auto-Negotiation / Static Speed / Duplex
      48 (per-port)
      Auto-Negotiation
      Auto MDI/MDIX
      N/A
      Enabled
      802.3x flow control / Back Pressure
      48 (per-port)
      Enabled
      Port Mirroring
      1
      Disabled
      Port Trunking (Aggregation)
      10
      Disabled
      802.1D Spanning Tree
      1
      Disabled
      802.1w RSTP
      1
      Disabled
      IGMP Snooping
      1
      Disabled
      Static 802.1Q Tagging
      256
      VID = 1
      Member Ports = [1-48]
      Port Based Private VLAN
      48X1
      MemberPorts[1] = [1-48]
      Learning Process
      N/A
      N/A
      Table A-4. Quality Of Service
      Number of Queues
      N/A
      N/A
      Port Based
      48 (per port)
      Normal for all ports
      802.1p
      1
      Disabled
      DSCP
      1
      Disabled
      Table A-5. Security
      ACL
      10
      All IP addresses allowed
      Password Control Access
      1
      Login Time Out = 5 mins. Password = “password”
      Table A-5. Security (continued)
      Trust Matadors Filter
      256
      Disabled
      Port -MAC lock down
      48 (per port)
      Disabled
      Management VLAN
      1
      0
      Table A-6. Traffic Control
      Table A-7. System Setup
      Rate control
      48 (per port)
      Disabled
      Storm control
      1 (per switch)
      Disabled
      Jumbo frame
      48 (per port)
      Disabled
      DHCP\Manual IP
      1
      192.168.0.239
      System Name Configuration
      1
      NULL
      Configuration Save/Restore
      1
      N/A
      Firmware Upgrade
      1
      N/A
      Factory Reset
      1
      N/A
      Table A-8. Other Features
      Feature
      Static Multicast Entry Filter Multicast Control
      Table A-9. Management
      SNMPv1/V2c MIB Support
      Sets Supported
      64 1
      Default
      Disabled Disabled
      Disabled Disabled
      Feature
      Smartwizard Statistics
      Sets Supported
      N/A
      48 (per port)
      Default
      Enabled N/A
      PLEASE READ
    • By Red MacKay
      Item Condition: VG - EXC Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Box Hill South State: VIC Payment Method: Cash, DD, Paypal to Family/ Friends Reason for selling: NLR
      Relisted, due to sale not proceeding for covid related hassles.
      This was owned by a mate who purchased it new from Peter Q. at Audio Note in the UK in 1995.
      Purchase price back then was   GB5000 pounds.
      Manufactured in the UK, this is one of the very last VOYD turntables made.
      The VOYD utilizes a 3 motor drive system to overcome any dynamic instability in playback.
      The three motors provide fantastic torque and full speed is maintained in like a nano second from turn on.
      This unit features the REFERENCE bearing and the REFERENCE polycarbonate platter.
      It also has the original external power supply which is very substantial and not an after thought at over 3kgs.
      All three drive motors are the original Papst units.  None of these motors have ever had any issues whatsoever.
      This deck was serviced by Duc at Golden Age Audio around 6 years ago.  At the time Duc recommended a new top plate be CNC m/c from 316 stainless steel to the exact original specs, to replace the magnetic steel original.  This new plate was powder coated to a gloss piano black timber finish to match the base, and proved to be a great sonic improvement.
      The base, electrical controls and mechanicals are all in EXCELLENT condition.  The polycarbonate lid is the original and I rate that as very good except for a slightly relaxed spot about 40mm wide.  The lid does have minor imperfections here and there, but it still presents very nicely. With a polish it would come up awesome.  I have not touched it – that is for the new owner.  There is also a very small blemish in the paint on the RH side that almost cannot be seen, but I mention it for full disclosure.
      As per the pics, an SME armboard is fitted, but no arm is supplied.
      EXTRAS- lots of them!  Spare suspension springs, spare bearings for the motor spindle suspension, spare brass feet, spare spindle oil in a syringe.
      Original setup instructions are included and I am happy to assist here.
      This is a very well regarded turntable and they rarely come up for sale.  They have a very respected following in the UK.
      I have the original box, but the foam inserts are way past their best.  I expect new inserts can be made if shipping is required.
      Obviously a local sale is preferred, but I am willing to ship this unit, but only at the buyer’s risk.
      The buyer is to pay for shipping (and insurance if req'd) at cost.
      My packing is pretty good though and I had a Garrard 401 travel to Sydney with not a blemish three weeks ago, so have confidence here.
      Any inspection is welcome.
