Tuck Posted September 25, 2020 Share Posted September 25, 2020 I have recently purchased an ELAC Discovery Server DS-S101-G on SNA. I am having difficult getting the Discovery App to communicate with the server. Does anyone have any experience with this Server? Link to comment Share on other sites More sharing options...
Guest thathifiguy Posted September 25, 2020 Share Posted September 25, 2020 The Discovery app? Do you mean the Roon Essentials app? Link to comment Share on other sites More sharing options...
Tuck Posted September 25, 2020 Author Share Posted September 25, 2020 Thanks Tarkan. Sorry , yes the Roon Essentials App. Hope you can assist. Geoff Link to comment Share on other sites More sharing options...
BrownMagic Posted September 25, 2020 Share Posted September 25, 2020 What is the error that you are getting? I use the Elac Discovery. Link to comment Share on other sites More sharing options...
Skasey Posted September 25, 2020 Share Posted September 25, 2020 I use one of these units and had no issues with connection. First check would be to ensure that your LAN and WiFi are on the same network. I have several networks at home and must ensure that my phone or iPad for the Roon App is on the same network for connection. Second check is that you are using the Roon Essentials App, not the full Roon App as there is a difference. Link to comment Share on other sites More sharing options...
Tuck Posted September 26, 2020 Author Share Posted September 26, 2020 Thanks Skasey. I was trying to load on my iPad and someone suggested using my iPhone instead. Using the iPhone and Essentials App I have been able to get to the stage of signing in and being asked to "add a music service". I am trying Tidal for a month and can login okay, but then I get "Safari cannot open the page because the address is invalid" Tidal is loaded on my iPad and recognises my smart TV, and Apple TV in another room, but so far not the Elac. Hope you can assist this dinosaur further, Geoff Link to comment Share on other sites More sharing options...
Tuck Posted September 26, 2020 Author Share Posted September 26, 2020 19 hours ago, BrownMagic said: What is the error that you are getting? I use the Elac Discovery. Thanks BrownMagic see current dilemma in post Link to comment Share on other sites More sharing options...
Tuck Posted September 26, 2020 Author Share Posted September 26, 2020 2 hours ago, gtee said: Thanks BrownMagic see current dilemma in post Suddenly working like a charm (more luck than good judgement). Thanks to all. Link to comment Share on other sites More sharing options...
BrownMagic Posted September 26, 2020 Share Posted September 26, 2020 You have to ignore the safari error. Glad that you are able to use it now. Make sure you are updated to the latest version both on the app as well as the roon core. Cheers. Link to comment Share on other sites More sharing options...
NoPork Posted December 9, 2020 Share Posted December 9, 2020 Putting hand up here if you decide to sell Link to comment Share on other sites More sharing options...
BrownMagic Posted December 9, 2020 Share Posted December 9, 2020 Anyone here using an external DAC with the Disco? Link to comment Share on other sites More sharing options...
Skasey Posted December 11, 2020 Share Posted December 11, 2020 I have been running both Analogue and Digital out from the Discovery into my Vitus Integrated amp with onboard DAC. Frankly, I cant hear much difference between the Discovery and the Vitus DACs. 1 Link to comment Share on other sites More sharing options...
NoPork Posted December 11, 2020 Share Posted December 11, 2020 52 minutes ago, Skasey said: I have been running both Analogue and Digital out from the Discovery into my Vitus Integrated amp with onboard DAC. Frankly, I cant hear much difference between the Discovery and the Vitus DACs. What RCA interconnects for analogue are you using or recommend from Discovery to amplifier? Link to comment Share on other sites More sharing options...
Skasey Posted December 11, 2020 Share Posted December 11, 2020 I am just using QED silver RCAs and Tara Labs digital cable, only because they were available when hooking up. Have not tried substituting cables to determine if there is any difference. Link to comment Share on other sites More sharing options...
BrownMagic Posted December 11, 2020 Share Posted December 11, 2020 24 minutes ago, NoPork said: What RCA interconnects for analogue are you using or recommend from Discovery to amplifier? I am using Tellurium Q Black 2 RCA. I chose this after trying a few. Do not get a warm cable. Neutral or slightly forward will help. Link to comment Share on other sites More sharing options...
