nowallet 40 Posted September 23, 2020 Share Posted September 23, 2020 Dear folks, I'm in a fortunate position to be able to upgrade soon from my Raspberry Pi/Volumio streamer to a better and more family-friendly setup (kinda). I'm tossing up between the CXN V2 or node 2i+external DAC (that roughly equates to a $1k budget for the external DAC). Pros of CXN: Chromecast built-in, single box solution Pros of 2i+DAC: potentially better sound quality and MQA What are your thoughts on this pleasant conundrum? What would you do? Would the sound quality gain be substantial going with the node 2i+extDAC? I will be feeding the successful candidate into a Cambridge CXA60 integrated amp playing through Dynaudio Emit M20 speakers. Any first-hand experience with the above components or ways you would think about this upgrade are greatly appreciated Thanks! Link to post Share on other sites
lebowski 706 Posted September 23, 2020 Share Posted September 23, 2020 (edited) I’m running a Node 2i into a RME ADI 2 FS DAC and think it sounds excellent. If you are wanting family friendly then the BlueOS interface ticks that box, user friendly and intuitive to use. The Node 2i has a huge feature set, you certainly get a lot for your money and from the reviews I’ve read it is worthy of a place in a high end system despite it’s low end price. I’ve thought about upgrading to a streamer with more audiophile credibility however not convinced spending more will result in significantly better sound, particularly when feeding the RME. have a read - https://www.13thnote.net/2020/08/26/bluesound-node-2i-punches-well-above-its-weight/ Edited September 23, 2020 by lebowski 4 Link to post Share on other sites
nowallet 40 Posted September 23, 2020 Author Share Posted September 23, 2020 Thanks @lebowski! That DAC seems to be above $2k at the moment. Is that right? I will definitely check out the link - thanks a tonne 1 Link to post Share on other sites
lebowski 706 Posted September 23, 2020 Share Posted September 23, 2020 Just now, nowallet said: Thanks @lebowski! That DAC seems to be above $2k at the moment. Is that right? I will definitely check out the link - thanks a tonne Yes, they are around $2,200 local, and a few hundred less if you import. The internal DAC of the Node 2i is actually pretty good and you could always start off with that and add a DAC later. With $1k budget for a DAC you have plenty of choice and can get something good quality particularly if you buy secondhand. 1 1 Link to post Share on other sites
2Dculture 31 Posted September 23, 2020 Share Posted September 23, 2020 I don't have your speakers but in my opinion is yes. They all have different sound quality. I've a bluesound2i and CXA81. Through this forum, met a fellow suburb who has an external dac but wanted hear the bluesound coz wanted to minimise the system and have multiroom streaming. So we swapped one afternoon. So I streamed and ran 1) Bluesound to CXA via RCA. So Bluesound is both streamer and DAC, CXA is power amp 2) Bluesound to CXA via digital coax. So bluesound is streamer and CXA is both DAC and power amp 3) Bluesound to external DAC via digital coax, external DAC to CXA via RCA. All component separate. Based on the above, sound quality and experience are good to better to best in the above order, i.e. 1, 2 and 3. I'm guessing the more revealing your speakers, the better the effect. I'm rather conservative and would go for the bluesound first. See if you appreciate the difference between the Bluesound DAC and CXA DAC. Once you know what is lacking and desire it, then find the DAC. Seems like there are a lot of good options for DAC around $1k to $1.5k. So you'd be spoilt for choice but you'd be looking for sonic characteristics by then *fingers crossed*. 1 Link to post Share on other sites
lebowski 706 Posted September 23, 2020 Share Posted September 23, 2020 @nowallet this DAC would be high on my list if not #1 with a budget around $1K. 6 Link to post Share on other sites
Snoopy8 3,344 Posted September 23, 2020 Share Posted September 23, 2020 (edited) 1 hour ago, nowallet said: I'm in a fortunate position to be able to upgrade soon from my Raspberry Pi/Volumio streamer to a better and more family-friendly setup (kinda). I'm tossing up between the CXN V2 or node 2i+external DAC (that roughly equates to a $1k budget for the external DAC). Pros of CXN: Chromecast built-in, single box solution Pros of 2i+DAC: potentially better sound quality and MQA BluOS on 2i is much better than the CXN app, certainy more family friendly. The 2i + Gieseler Kompakt DAC will beat the CXN for sound quality. But if you want a single box solution, go NAD C658. It costs a little more but comes with BluOS, a better DAC than 2i, CXN and Dirac Live. Edited September 23, 2020 by Snoopy8 Typo 5 Link to post Share on other sites
nowallet 40 Posted September 23, 2020 Author Share Posted September 23, 2020 Wow this community is great - thanks for all of the advice! I was hoping someone would just say stick with the CXN so I can match it to my existing CA gear But this is a good dilemma. I like the possibilities with the external DAC and didn't really consider the C658 (the design is a bit of a turn off IMO). I'd love to hear of other DACs so I can compare them to the Kompakt. Thanks all 1 Link to post Share on other sites
nowallet 40 Posted September 23, 2020 Author Share Posted September 23, 2020 30 minutes ago, 2Dculture said: ... I'm rather conservative and would go for the bluesound first. See if you appreciate the difference between the Bluesound DAC and CXA DAC. Once you know what is lacking and desire it, then find the DAC. ... A lot of wisdom here I must admit. Food for thought Link to post Share on other sites
Al.M 1,306 Posted September 23, 2020 Share Posted September 23, 2020 Depends how you are using them. The app on the Bluesound is better and includes excellent functions but if you are streaming at distance the range isn’t that good and drops out often. Also, the USB on it is designed to match with a USB stick and you may need to reformat things to get it to work. For example, it won’t read files from a simple USB drive. I would google Bluesound Node problems and see what the reports are. If your using direct Ethernet or modem is close it should be more reliable. I found my old CA NP30 setup and connection way easier, sounded way better, never drops out, reliable and reads USB drives with no problems. Based on my CA experience I would be going for another CA streamer. 1 Link to post Share on other sites
lebowski 706 Posted September 23, 2020 Share Posted September 23, 2020 10 minutes ago, Al.M said: Depends how you are using them. The app on the Bluesound is better and includes excellent functions but if you are streaming at distance the range isn’t that good and drops out often. Also, the USB on it is designed to match with a USB stick and you may need to reformat things to get it to work. For example, it won’t read files from a simple USB drive. I would google Bluesound Node problems and see what the reports are. If your using direct Ethernet or modem is close it should be more reliable. I found my old CA NP30 setup and connection way easier, sounded way better, never drops out, reliable and reads USB drives with no problems. Based on my CA experience I would be going for another CA streamer. you do need to format the external hard drive for the Node2i to read it and then you will have no issues whatsoever. I have a 4 Terabyte Portable Hard Drive connected to my Node 2i and it reads all 2,500 uncompressed albums no problem. The BlueOS App loads albums and cover art fast and is very responsive. I also have patchy wifi and rarely have any issues with mine, and it’s located at the far end of our house furthest away from the modem. 2 Link to post Share on other sites
Snoopy8 3,344 Posted September 23, 2020 Share Posted September 23, 2020 49 minutes ago, nowallet said: I'd love to hear of other DACs so I can compare them to the Kompakt. The Kompakt just came out but there should be some feedback from owners soon. According to Clay (designer & manufacturer), it may be his best DAC yet, To give you an idea on why Gieseler Dacs are held in high regard, have a look at this (and I will update when Kompakt impressions are posted) 3 Link to post Share on other sites
gillmaverick 713 Posted September 23, 2020 Share Posted September 23, 2020 1 hour ago, nowallet said: Wow this community is great - thanks for all of the advice! I was hoping someone would just say stick with the CXN so I can match it to my existing CA gear But this is a good dilemma. I like the possibilities with the external DAC and didn't really consider the C658 (the design is a bit of a turn off IMO). I'd love to hear of other DACs so I can compare them to the Kompakt. Thanks all Hi Mate , I use NAD C-658 and I am happy with it. I have had a naim nac172 and have used Chord Qutest in my]system. Nad has been the best sound so far in my system and that is due to Dirac Live. If you have a treated room than go with Node + external dac. Cheers 3 Link to post Share on other sites
nowallet 40 Posted September 23, 2020 Author Share Posted September 23, 2020 21 minutes ago, gillmaverick said: Hi Mate , I use NAD C-658 and I am happy with it. I have had a naim nac172 and have used Chord Qutest in my]system. Nad has been the best sound so far in my system and that is due to Dirac Live. If you have a treated room than go with Node + external dac. Cheers That's great to hear and that's a top point about Dirac. I forgot that was a part if the feature set. No treated room here so this js something I'll consider more seriously. 1 Link to post Share on other sites
nowallet 40 Posted September 23, 2020 Author Share Posted September 23, 2020 55 minutes ago, lebowski said: you do need to format the external hard drive for the Node2i to read it and then you will have no issues whatsoever. I have a 4 Terabyte Portable Hard Drive connected to my Node 2i and it reads all 2,500 uncompressed albums no problem. The BlueOS App loads albums and cover art fast and is very responsive. I also have patchy wifi and rarely have any issues with mine, and it’s located at the far end of our house furthest away from the modem. Thank you. More great info. I will be connecting via ethernet so expect a solid network connection for whichever unit I purchase. Link to post Share on other sites
Bunno77 1,372 Posted September 23, 2020 Share Posted September 23, 2020 For family friendly Chromecast/bluetooth/airplay can't be beaten. Also allows you to use your native apps and more of them. 1 Link to post Share on other sites
Luciano Milioli 21 Posted September 24, 2020 Share Posted September 24, 2020 I run a Node 2 digital coneection to a Chord QuteHD DAC and was a big step up from the (not bad) DAC of the Node 2 itself. The NAD C 658 looks like a good option to keep using BlueOS, that is great, and adding DIRAC, that should help a lot in small and not acousticaly treated rooms like mine. But from other NAD DACs I tend to find them very detailed but a little analytical and Chord DACs more musical. I will try to hear the C658 to confirm. 2 Link to post Share on other sites
Hi-Fi Whipped 1,138 Posted September 24, 2020 Share Posted September 24, 2020 Im now a C658 convert, for the money theres nothing that comes close to it for features. And once you've had Dirac you can't go back its that simple, music just sounds lifeless without it. BluOS is a big reason to jump into the either the 2i or the C658, IMO the best GUI using a free app out there, I find it much better than the Cambridge streaming app which I occasionally use on my CXR200. Also if you are even considering adding subs to your 2ch listening the sub integration of Dirac is awesome, seamlessly integrates the subs and front speakers and produces a wall of sound like nothing else I've heard, seamless from bottom to top. Is it pretty? No but its not ugly either, looks understated and a touch classy in my unit IMO but don't let the looks be a decider, we all know its about the sound! 6 Link to post Share on other sites
Balvenie 7 Posted September 25, 2020 Share Posted September 25, 2020 Been really happy with my CXN, easy to use and sounds great......my 2c. Link to post Share on other sites
nowallet 40 Posted September 27, 2020 Author Share Posted September 27, 2020 On 26/09/2020 at 9:33 AM, Balvenie said: Been really happy with my CXN, easy to use and sounds great......my 2c. @Balvenie Is it your first streaming system? What did you have before and how does it compare to that? Link to post Share on other sites
nowallet 40 Posted September 27, 2020 Author Share Posted September 27, 2020 On 24/09/2020 at 2:21 PM, Hi-Fi Whipped said: Im now a C658 convert, for the money theres nothing that comes close to it for features. And once you've had Dirac you can't go back its that simple, music just sounds lifeless without it. BluOS is a big reason to jump into the either the 2i or the C658, IMO the best GUI using a free app out there, I find it much better than the Cambridge streaming app which I occasionally use on my CXR200. Also if you are even considering adding subs to your 2ch listening the sub integration of Dirac is awesome, seamlessly integrates the subs and front speakers and produces a wall of sound like nothing else I've heard, seamless from bottom to top. Is it pretty? No but its not ugly either, looks understated and a touch classy in my unit IMO but don't let the looks be a decider, we all know its about the sound! @Hi-Fi Whipped Thanks for all the info. If it wasn't for the looks, I'd be there... I think the looks are terrible enough that I can't consider it. I currently have a white/silver system too, so it would be jarring as much as I agree that sound quality trumps. Link to post Share on other sites
blakey72 1,370 Posted September 27, 2020 Share Posted September 27, 2020 @nowallet I have a CA CXN V1 and it's quite easy to use. I haven't had any experience with the node but have some Dynaudio DM3/7's which I sometimes use with the CXN.It has Burr Brown dual Dacs from memory and I find them to be a little on the bright side at times. The sound is clear but can become wearing after hours of listening I find. I use a Plinius 9200 amp (very neutral) to power my speakers. The other thing that I don't particularly like about the CXN is that you can't play tidal masters through it (may have changed in V2?). Otherwise it's a good unit as a starting point for a streamer IMO, I however do plan on either upgrading it or running it through an external dac in the future. Link to post Share on other sites
Hi-Fi Whipped 1,138 Posted September 27, 2020 Share Posted September 27, 2020 2 hours ago, nowallet said: @Hi-Fi Whipped Thanks for all the info. If it wasn't for the looks, I'd be there... I think the looks are terrible enough that I can't consider it. I currently have a white/silver system too, so it would be jarring as much as I agree that sound quality trumps. Yeh I hear you, all my boxes are black so it fits fine. So which way are you leaning? Given looks are a major factor the CXN looks like the go, the sound is very good and will fit nicely with what you have. If you can grab one second hand you may even have surplus for more power in your system which again would improve the sound. Link to post Share on other sites
nowallet 40 Posted September 27, 2020 Author Share Posted September 27, 2020 (edited) 27 minutes ago, Hi-Fi Whipped said: Yeh I hear you, all my boxes are black so it fits fine. So which way are you leaning? Given looks are a major factor the CXN looks like the go, the sound is very good and will fit nicely with what you have. If you can grab one second hand you may even have surplus for more power in your system which again would improve the sound. The CXN v2 is tempting but then I haven't explored separate components so a Node 2i and an external DAC has me curious. The latter is likely the path I'll choose. I don't even know if the sound quality difference will be noticeable with the CXA60 amp and Dynaudio M20s I own. Edited September 27, 2020 by nowallet Link to post Share on other sites
Balvenie 7 Posted September 29, 2020 Share Posted September 29, 2020 On 27/09/2020 at 7:49 PM, nowallet said: @Balvenie Is it your first streaming system? What did you have before and how does it compare to that? Yep, first venture into streaming but did try a Cocktail Audio unit before purchasing the CXN 1 Link to post Share on other sites
nowallet 40 Posted September 29, 2020 Author Share Posted September 29, 2020 A Bluesound Node 2i is on the way! I will get to know it well and then consider purchasing an external DAC to feed the Node and my CD transport through it. Thanks for everyone's advice 2 Link to post Share on other sites
Wood 64 Posted September 29, 2020 Share Posted September 29, 2020 I’m really happy with the Node 2i, but I really want to try Dirac. If there is a deal on the 658 this November I think it’ll be too hard to resist. I’m seeing a lot of positive comments about BluOS. Maybe I’m doing something wrong, but I haven’t opened the app since setting up my Node. I spend all my time in the Spotify app when streaming. Link to post Share on other sites
nowallet 40 Posted September 29, 2020 Author Share Posted September 29, 2020 Just now, Wood said: I’m really happy with the Node 2i, but I really want to try Dirac. If there is a deal on the 658 this November I think it’ll be too hard to resist. I’m seeing a lot of positive comments about BluOS. Maybe I’m doing something wrong, but I haven’t opened the app since setting up my Node. I spend all my time in the Spotify app when streaming. Exciting! The Spotify app is fantastic I've heard. I would probably use it as a control if I had it; why use two apps? I don't know how BluOS compares to the native Spotify app though. If I had a black system setup I would've considered the C658 more closely due to Dirac. Link to post Share on other sites
nowallet 40 Posted October 12, 2020 Author Share Posted October 12, 2020 Anyone here got some thoughts on how to think about an external DAC purchase considering my current equipment? Sources: Bluesound Node 2i, Cambridge CXC CD transport Cambridge CXA60 amp Dynaudio Emit M20 bookshelf speakers I'm tossing up between a Denafrips Ares II and the new Gieseler Kompakt DAC. At this price point I really want to maximise my purchase and ensure it matches my components. It seems both have a warm quality with expansive soundstage - which is exactly what I'm after. Anyone here have the Ares II and any of the components I mentioned above? Link to post Share on other sites
08Boss302 1,308 Posted October 13, 2020 Share Posted October 13, 2020 I use it with my Denafrips Ares II and am very happy. I tried the pontus and it was also great but for me lacked a bit of warmth of the AresII and sounded closer to my Oppo 205. So I went with the Ares II have not once regretted it. I use the Oppo 205 a lot also but find that works really well for a different type of listening session. I'd love to try the Topping D90 one day too.. Geisler very popular but havent tried one myself but there is a lot members on the forum that have this as their go to. Schiit very well regarded too etc. 1 Link to post Share on other sites
lebowski 706 Posted October 13, 2020 Share Posted October 13, 2020 Don’t think you could go wrong with either of those DACS @nowallet Both highly regarded and if you wanted to move on they would be in high demand. 2 Link to post Share on other sites
nowallet 40 Posted October 13, 2020 Author Share Posted October 13, 2020 3 hours ago, 08Boss302 said: I use it with my Denafrips Ares II and am very happy. I tried the pontus and it was also great but for me lacked a bit of warmth of the AresII and sounded closer to my Oppo 205. So I went with the Ares II have not once regretted it. I use the Oppo 205 a lot also but find that works really well for a different type of listening session. I'd love to try the Topping D90 one day too.. Geisler very popular but havent tried one myself but there is a lot members on the forum that have this as their go to. Schiit very well regarded too etc. @08Boss302 Do you mean you use the Ares with the Node 2i? Tough choice between this and the local and formidable Gieseler DAC. Thanks for your comment! Link to post Share on other sites
08Boss302 1,308 Posted October 13, 2020 Share Posted October 13, 2020 1 minute ago, nowallet said: @08Boss302 Do you mean you use the Ares with the Node 2i? Tough choice between this and the local and formidable Gieseler DAC. Thanks for your comment! That's correct mate, I use the Ares II with the node 2i as well as the the Oppo 205 with the node 2i. Haven't had the chance to listen to the geisler units but it's a DAC that also rarely receives negative comments especially on these forums. The owner is also a top person, when I was looking at DACs I had a great conversation with him about his units my oppo and what I was looking at. I think between the denafrips, geisler, schïit and the list goes on if you are in the same comparative price range alot of subjectivity on what's best etc will creep in. Try audition a few if you can... Link to post Share on other sites
nowallet 40 Posted October 13, 2020 Author Share Posted October 13, 2020 7 minutes ago, 08Boss302 said: That's correct mate, I use the Ares II with the node 2i as well as the the Oppo 205 with the node 2i. Haven't had the chance to listen to the geisler units but it's a DAC that also rarely receives negative comments especially on these forums. The owner is also a top person, when I was looking at DACs I had a great conversation with him about his units my oppo and what I was looking at. I think between the denafrips, geisler, schïit and the list goes on if you are in the same comparative price range alot of subjectivity on what's best etc will creep in. Try audition a few if you can... Thanks! Don't think an audition will happen anytime soon with this Melbourne lockdown so I will take a chance after digging into the sound of each one a little further. Cheers Link to post Share on other sites
08Boss302 1,308 Posted October 13, 2020 Share Posted October 13, 2020 (edited) 29 minutes ago, nowallet said: Thanks! Don't think an audition will happen anytime soon with this Melbourne lockdown so I will take a chance after digging into the sound of each one a little further. Cheers Haha, yep I'm in Melbourne too and know what you mean... Speak to @dacman for denafrips. Top guy and the Aust seller and he's in Melbourne Edited October 13, 2020 by 08Boss302 1 Link to post Share on other sites
MaxPlumage 101 Posted October 17, 2020 Share Posted October 17, 2020 On 13/10/2020 at 10:11 AM, nowallet said: Anyone here got some thoughts on how to think about an external DAC purchase considering my current equipment? Sources: Bluesound Node 2i, Cambridge CXC CD transport Cambridge CXA60 amp Dynaudio Emit M20 bookshelf speakers I'm tossing up between a Denafrips Ares II and the new Gieseler Kompakt DAC. At this price point I really want to maximise my purchase and ensure it matches my components. It seems both have a warm quality with expansive soundstage - which is exactly what I'm after. Anyone here have the Ares II and any of the components I mentioned above? Can't speak on the other devices, but I used to run a Node 2i with a Gieseler Klein III dac/kraftwerk psu. The sound quality improved big time. Just more of everything - sound stage, warmth/mids, vocals popped and the highs were so clear and detailed. Basically everything felt a tad more real. I would like to think that the Kompact takes this up a notch, being the latest. Only problem is finding stock Plenty of options re. dacs definitely try and audition first. Good luck! 2 Link to post Share on other sites
terrys999 2 Posted November 26, 2020 Share Posted November 26, 2020 (edited) On 27/09/2020 at 1:36 PM, nowallet said: The CXN v2 is tempting but then I haven't explored separate components so a Node 2i and an external DAC has me curious. The latter is likely the path I'll choose. I don't even know if the sound quality difference will be noticeable with the CXA60 amp and Dynaudio M20s I own. Does the CXA60 amp power they Dynaudio M20s ok? asking because the dynaudios are 4ohm 150w My CXA60 drives my ma bronze 6 just fine. How loud can you play without distortion? Edited November 26, 2020 by terrys999 More questions Link to post Share on other sites
Bunno77 1,372 Posted November 26, 2020 Share Posted November 26, 2020 6 hours ago, terrys999 said: Does the CXA60 amp power they Dynaudio M20s ok? asking because the dynaudios are 4ohm 150w My CXA60 drives my ma bronze 6 just fine. How loud can you play without distortion? The cxa60 does OK but when you jump up to the cxa80 you realise you were missing out a bit. The m20 will also improve a bit more if you move to a better amp than the cambridge units Link to post Share on other sites
dr_carl 196 Posted November 27, 2020 Share Posted November 27, 2020 I'm happy with my inexpensive DAC between my Node 2 and my tube amp feeding my speakers. A $180 bargain. To get me to spend more will require significant improvement in SQ. Except my SQ now is very good, so I'm not motivated. My library is on a HDD via USB into the Node. No format drama, nothing negative at all. Spotify you access via the Spotify app and also Tidal the same. Bluos for playing files. I was happy with no external DAC for a long time. Only bought the one I have as an experiment. Immediately sold all others this is so good. I am a firm believer in Chinese DAC tech now. I have heard others much more expensive that did not sound better to me, so I'm staying as is for now. Link to post Share on other sites
