My big Kenwood deck is putting out a lot of Electronic  noise , I suppose it could be described as a wiring sound. I have swapped phono stages and cartridges without any change
i have also applied deoxit. When the cartridge is half way in it is quieter, but of course that’s not much use
i am hoping someone can shed some light here
Sorry, Steve ... but what you say below ... doesn't make all that much sense  - well, to me, anyway!:
What on earth do you mean by 'wiring' sound?
And I presume this sound is coming from the Kenwood itself - not from your spkrs?
Quote
So you have plugged your arm cable into different phono stages - and used different carts in the arm - to no avail?
Quote
What did you apply Deoxit to?
And what do you mean by "When the cartridge is half way in it is quieter "?  Half way into what?
Edited by andyr
Describe "Electronic noise"?  Reassembling fridge, hair drier, washing machine, tram, electric car or rail gun ?
Halfway into playing the record mate.
What model turntable is it?
3 hours ago, Alpine Electrocats said:
... I suppose it could be described as a wiring sound.
I take it you mean whirring sound, and not something to do with a wire?
1 minute ago, Alpine Electrocats said:
Yes, sorry for the confusion
Sorry if I appeared to be somewhat of a pedant, but in this instance, I think it's an important distinction.
A lot of things to reply to.. yes sorry it’s a “wirring ” sound thru the speakers- my phone keeps changing it , just realised that. Yes I connected the deck to a phono stage with the wires that came from the tonearm and go to the phono stage, not sure what else I could have used :)
the Noise is continual , but If I remove  the head shell Then the noise stops About half way out, then resumes when I remove the head shell completely.
i used deoxit on the ends of The plugs
Try another headshell.
35 minutes ago, Alpine Electrocats said:
Yes a likely suspect, although it makes the noise when it’s not playing too
Yes and as you move the tonearm to the centre, does it start to go quieter?
I think you're clutching at straws, W.  :)
The OP said:
1 hour ago, Alpine Electrocats said:
the Noise is continual , but If I remove  the head shell then the noise stops about half way out, then resumes when I remove the head shell completely.
So nothing to do with the arm tracking across the groove annulus.
Not sure that this means the arm wiring is the problem - but, sure, it's hard to see what else it might me.
And the 'whirring ' sound is totally bizarro!  :huh:
10 hours ago, Alpine Electrocats said:
No it doesn’t need to be on the record to make the noise
This might be a stupid question, but does the amplifier have an earth for the phono input and is it still hooked up?  Long black thin wire usually coming out the back of the turntable with the RCA plugs or a threaded fitting you put a wire on between your amp and the turntable.
I don't know exactly what turntable you are referring to (you still haven't provided that info), but is it possible that a motor supression capacitor or similar has failed and you're getting some sort of interference from the turntable drive motor? Or perhaps some other issue with the turntable's power supply that is generating a noise signal that is being picked up by the cartridge/tonearm wiring?
On ‎17‎/‎09‎/‎2020 at 4:28 PM, Alpine Electrocats said:
My big Kenwood deck is putting out a lot of Electronic  noise.
 When the cartridge is half way in it is quieter....
Is it a P-mount? xD
Edited by stevoz
Hi Steve have you solved the noise problem?
Firstly which make & model turntable & amplifier do you have?
Have you used this turntable/amp set up for a while and then the noise started for no reason or did you move things around recently?
Maybe if you gave more specific details we could offer a better solution. 🙂
If your amplifier has a PHONO INPUT then you can not connect a PHONO STAGE (that is a Phono Preamp) into the Phono Input into your amplifier this could/will make "noise" all the time.
When using a Phono Stage/Preamp it should be connected into, for example, the AUX input....not Phono...if you amp has a Phono Input this is already an internal phono stage/preamp.
@monaro8 This is a good point.
When using the Phono Input on an amp & turntable, is it normal to have to pump up the volume more than you would for other line-level inputs such as CD, etc?
I have a Yamaha RX--V685 which has Phono Input to which I have connected my turntable (pre-amp bypassed), but I find I have to bump up the amp volume significantly as opposed to other inputs.
Does this sound right? Given the signal coming from (effectively) the cartridge is very small, I guess it makes sense, but just wondering if you/others can advise?
Cartridges do have a range of output levels, some higher, some lower. There are also two types (in common hifi use), moving magnet, and moving coil. So an amp maker might set the sensitivity of the phono stage to match a mid-level output, and you may have a low output cartridge.
Here is some info from wikipedia: (MM = Moving Magnet, MC = Moving Coil)
"MM cartridges generally have output of 3-6mV, compatible with the MM inputs of preamplifiers. MC cartridges come in two varieties, low output (usually < 1.0mV) and high output (more than 1.5mV); there are also some with very low output (0.3mV or less). High output MC cartridges are a concession to compatibility with older preamp MM inputs; low output MC cartridges may generate excessive noise or have insufficient preamp gain to drive amplifiers to their rated output if used on MM inputs. Most solid state preamplifiers have separate high gain, low noise MC inputs to accommodate these. Cartridges with very low output need a separate pre-phono amplification stage before input to an MC or MM preamplifier stage."
Thanks for that, @pwstereo. With the information from your answer, I have checked my Yamaha RX-V685 specs for the Phono Input - Input sensitivity/impedance - 3.5mV/47 kΩ - this seems to match up with what you have quoted for the MM cartridge.
I am getting my new turntable today which has an Ortofon 2M Red cartridge pre-installed. Looking at the specs, it fits with my amp as it has an output voltage of 5.5mV at 1000 Hz and a recommended load resistance of 47 kΩ. This cartridge is a big step up from the one on my existing turntable, so keeping my fingers crossed🤞
Thanks again for your assistance.
Gerry
    • By Doomguy
      I recently bought a new record on eBay that has a fair bit of surface noise and a repeated click across the majority of side A. I gave it a glue clean to no avail, it sounds identical, so it's fair to say that I'm very dissatisfied with it; particularly since the comments on discogs about this pressing were quite positive, a couple of people specifically mentioning it as being low noise. The thing is, it would pass as NM to a visual inspection, but I wouldn't feel confident grading it anything higher than VG in listening. Do I contact my eBay seller for a refund or replacement? I do buy a lot of CDs and records from them and this is the first time I think I've been dissatisfied with what I've received. Do I chase it up with the label instead, seeing as it's not really the seller's fault? Paying $36 for a new record only for it to sound crap isn't right. My only reservation is I don't have a way of demonstrating it.
    • By Soundscape
      I haven't started a thread in ages, probably because they are about as popular as a fart in the lift, and deservedly so. Whatever. So, on the back of one vote in the currently spinning thread, I am starting a noise (music) thread. I choose to start the thread,
      now
      Orchestra of Constant Distress
      2016 LP on 8mm Records
      Minimal musical content, maximal volume and distortion. This album is the first of three (so far) by this band that is 50% made up of the remains of Skull Defekts, a recently defunkt Scandinavian noise-rock band. This is really good shiz, so get it up ya, noisesters.
    • By zaphodis
      Hello all, just wondering if anyone might be able to shed some light on this issue. I have an older Samsung Plasma TV (PS-63P71FDX), and whenever I am running a device with its output set to 1080p, it shows this noise in the image on the panel.
      I've tested with a standalone blu-ray player, ps3, ps4 and a wdtv. Switching it back to 1080i solves the issue, but just wondering if anyone has any ideas what might be causing it?
      I've attached a video of the issue in action. I've also tried numerous different HDMI cables, connecting devices straight to the TV instead of through my receiver (Onkyo SR605) and still have the same issue.
      Cheers!
      http://www.youtube.com/watch?v=yH6W_XD5ZIQ
    • By Primare Knob
      I am planning the build of an HT room, w 3.4m x l 4.75m x h 2.5m. The front (viewing) wall is connected to the garage, the right wall is facing outside, the left wall is for the bigger part connected to the bathroom, has the door opening and is in a small part connected to a cupboard in the hallway, the back wall is connected to my kids bedroom. The walls are double brick with an air gap between them and will "absorb" -20dB on average. The roof is an exposed timber ceiling with a sheet metal roof and 100mm of insulation in between.
      I would like to soundproof/insulate the room for late night movie watching since this is the only time of day I have the time to do so, and after doing some research come up with a first plan.
      Wall coverage: 7mm of ply, 3mm of "acoustic" rubber, 10mm of plasterboard. Gluing studs to the brick wall with something like Green Glue, nailing the ply to these studs, staple the acoustic rubber to the play, screw the plasterboard into the studs.
      Back Wall coverage: The same as the above but with more space in between for some extra insulation bats for added soundproofing.
      Ceiling: Not sure. Could use the same system as the walls, but the question is how much sound would travel to other rooms via the ceiling?
      Floor: Thick carpet on concrete slab.
      Window: Heavy curtain
      Door: Solid door plus seals. Would a "second" door on top of that improve things more?
      With the "acoustic" rubber, I am very tempted to go with the timber floor underfloor type than with a pro version. The pro version is astonishing expensive, but a whole lot heavier as well.
      I prefer to glue the studs to the brick wall instead of using whisper clips, because it would make my life a whole lot easier.
      There is also a product on the market that is build up from 2 sheets of plasterboard with different thickness and decoupling layer of some kind which looks more like a foam/fury type than a rubber type of material.
      I plan to go for the heavier acoustic type of plasterboard instead of the regular one.
      How effective would something like this be, considering it would be air tight? Would this allow me to watch a movie at 65dB or more without waking the family.
      Love to hear your 2 cents or experience on this.
