Gieseler Audio 2,472 Posted September 17, 2020 Share Posted September 17, 2020 (edited) Hi Guys, Well after many months of designing, testing, prototyping & listening we have two new products, the Kompakt DAC (releasing next week) and the Kraftwerk II (releasing the week after). We are doing things a bit differently with these products in that we have significantly improved the presentation with fully custom imported cases from Japan as well as standardized soft foam packaging to help give you a better unboxing experience and shipping safety. The case is formed with a clam shell design out of 2.5mm solid aluminium, with a robust black powder coated finish to add robustness to marks, and full metal aluminium silk screen printed front and back panels. Both units still feature Express Post Australia-wide shipping and a two year parts and labour warranty as standard. Kompakt DAC - $1200 https://www.gieseler.com.au/product-page/kompakt The Kompakt DAC uses a straightforward and efficient design using the AK4493EQ in hardware mode (PCM only) for coax, optical & USB inputs with the first upgrade being a new S/PDIF input stage based on the premium AKM AK4118A chip. This is considered the best device out there for this job and I have to admit it is a big improvement from the Wolfston chip used in previous models. Not only does it sound better but it is rock solid in terms of digital lock on & auto muting. Next up is the big 500mH choke in the all important on-board main pre-regulated power supply. The power supply has a big effect on sound quality & adding in a large choke produces a clear improvement in audio quality. Another addition is ten separate regulators so that there is no sharing of power sources for the DAC, S/PDIF and USB sections, which I think has added a lot in terms of separation and imaging. The other technical jump is the switch to a four layer printed circuit board, which provide a full unbroken ground plane, as well as a few other improvements, to really help performance with a digital device. Bottom line – how does it sound? Well unavoidably I am biased but in my opinion, this is my best sounding DAC I have produced to date. This is to be expected as the circuit is basically an improved iteration to the Fein DAC II design with enhancements in the power supply, extra regulators & the engineering improvements from the four layer printed circuit board. Kraftwerk II - $650 https://www.gieseler.com.au/product-page/kraftwerk-ii The Kraftwerk II is a new flexible design with adjustable output of 12v, 15v, 16v, and 18v all at 3A via a selector switch on the back. I will have a similar lower voltage version in a couple of weeks with outputs of 5v, 7v, 9v and 12v all at 3A. The big improvement with the Kraftwerk II is the incorporation of a large high quality choke and an high efficiency active mosfet bridge rectifier. The elegant new design features an automatic pre-regulator which helps evenly disperse the regulator heat emission at lower voltages, letting the PSU run cooler and more efficiently. The final regulator is a premium Linear Technology unit with emitter follower output topology, which rivals discrete designs. Main filter capacitors are premium Nichicon Gold Tune and final filtering using Nichicon MUSE caps. It is powered by a large high quality Australian approved Tortech 5A external transformer. The addition of extra very high quality parts has bumped the price up but in my (albeit biased) opinion performance is a step up from all my previous designs. PS. Both products are visible on our website but will be set as out of stock until they release over the coming weeks (I'll keep you posted). All the best, Clay Hey just to make this clear you do not need the Kraftwerk II to to power Kompakt DAC. It comes with its own external 9 V transformer and that is all that is required to run it Edited September 17, 2020 by Gieseler Audio More info 19 2 Link to post Share on other sites
naggots 283 Posted September 17, 2020 Share Posted September 17, 2020 Sign me up 1 Link to post Share on other sites
Benjet 671 Posted September 17, 2020 Share Posted September 17, 2020 Finally something great happened in 2020. This could be the turning point! Fantastic gear, looks and feels top notch. Looking forward to sitting down and having a decent listen to these. 4 Link to post Share on other sites
lemarquis 572 Posted September 17, 2020 Share Posted September 17, 2020 Great news Clay. 1200 for your best sounding DAC? Bargain as usual and I do like the old school look too. 2 Link to post Share on other sites
Gieseler Audio 2,472 Posted September 17, 2020 Author Share Posted September 17, 2020 (edited) Hi guys thought you might like an internal shot as well - first without Amanero & you can see the new S/PDIF section Edited September 17, 2020 by Gieseler Audio More info 5 Link to post Share on other sites
pete_mac 3,988 Posted September 17, 2020 Share Posted September 17, 2020 1 minute ago, Gieseler Audio said: Hi guys thought you might like an internal shot as well Oh Clay, you know I love a nudie!! 2 Link to post Share on other sites
lenticularis 526 Posted September 17, 2020 Share Posted September 17, 2020 Looking really great Clay. I hope to be the first customer for the Kompakt! Congratulations on more fine products! cheers, Dave 1 Link to post Share on other sites
HelloYellowVolvo 17 Posted September 17, 2020 Share Posted September 17, 2020 (edited) Yum. Count me in for the Kompakt!! Can I place an order? Put myself on a waiting list? Cheers Rob Edited September 17, 2020 by HelloYellowVolvo 2 Link to post Share on other sites
Gieseler Audio 2,472 Posted September 17, 2020 Author Share Posted September 17, 2020 Hi Rob, thanks for the vote of confidence. I will be all good to ship on Tuesday 22nd Sep & the website will show in stock then. PM me if you want to place an order now. Cheers Clay 1 Link to post Share on other sites
Tarzan 111 Posted September 17, 2020 Share Posted September 17, 2020 Wow looks great Mr Clay, just wondering are you going to use the same case for a new headphone amp with VU meters? Super stack? 1 Link to post Share on other sites
Gieseler Audio 2,472 Posted September 17, 2020 Author Share Posted September 17, 2020 Hi Tarzan, hey you will get a chance to hear the new DAC on Sunday at the headfi club meeting. Sorry no plans at the moment on a new headphone amp 2 Link to post Share on other sites
Cardiiiii 1,465 Posted September 17, 2020 Share Posted September 17, 2020 Love the new premium look. Very sleek! 2 Link to post Share on other sites
crtexcnndrm99 553 Posted September 17, 2020 Share Posted September 17, 2020 Oh you make a difficult case against my analog only system... Look forward to hearing everyone’s experiences 1 Link to post Share on other sites
Snoopy8 3,354 Posted September 17, 2020 Share Posted September 17, 2020 Clay, what are you doing selling a DAC that sounds better than your current best, and at half the price??? 😁 And no one mentioned the better foam packaging? You will need an unboxing video soon? 😛 Looking forward to the feedback from the Sunday headfi meet... 3 1 Link to post Share on other sites
Gieseler Audio 2,472 Posted September 17, 2020 Author Share Posted September 17, 2020 Hi Snoopy - yes some very valid points. It will certainly be a challenge to actually try & get the the next higher end model sounding any better than the Kompakt DAC. RE unboxing video. Maybe Lenticularis will volunteer as he is getting serial number 0001. 4 Link to post Share on other sites
Bunno77 1,376 Posted September 17, 2020 Share Posted September 17, 2020 Great to see someone bucking the audio trend. I am sure this will get you more sales and more profit. I will definitely make an effort to hear this one 1 Link to post Share on other sites
lenticularis 526 Posted September 17, 2020 Share Posted September 17, 2020 8 hours ago, Gieseler Audio said: Hi Snoopy - yes some very valid points. It will certainly be a challenge to actually try & get the the next higher end model sounding any better than the Kompakt DAC. RE unboxing video. Maybe Lenticularis will volunteer as he is getting serial number 0001. I'll see what I can do about an unboxing video. ...Such an action will highlight the fact that I've bought yet "another thing", so I can expect a trough in the WAF-curve 🙄 as in the far right (when i purchased a very ugly but good TT). If so my desktop Klein III may have to be sold, to increase WAF. Perhaps I need to start a GoFundMe project to save me from that eventuality, however that would be morally wrong when we are on the cusp of The Great Depression Mk.2 Anyway, enough 6am waffle ...I can do a video! 5 2 Link to post Share on other sites
Bill125812 3,356 Posted September 17, 2020 Share Posted September 17, 2020 Undoubtedly another giant killer Clay. I’m looking forward to having a listen at the headfi meeting on Sunday. 5 Link to post Share on other sites
Gieseler Audio 2,472 Posted September 17, 2020 Author Share Posted September 17, 2020 Just to give you an idea of size here is the power supply with transformer 2 Link to post Share on other sites
Snoopy8 3,354 Posted September 17, 2020 Share Posted September 17, 2020 1 hour ago, lenticularis said: If so my desktop Klein III may have to be sold, to increase WAF. One problem solved ! 😁 https://www.stereo.net.au/forums/topic/323032-wtb-geiseler-audio-klein-iii-usb/?tab=comments#comment-4616167 1 1 1 Link to post Share on other sites
mcb 101 Posted September 18, 2020 Share Posted September 18, 2020 More quality products from a quality manufacturer/supplier. Clay’s pre-sale and post sale service is also top shelf👍 7 Link to post Share on other sites
lenticularis 526 Posted September 18, 2020 Share Posted September 18, 2020 (edited) 5 hours ago, Snoopy8 said: One problem solved ! 😁 https://www.stereo.net.au/forums/topic/323032-wtb-geiseler-audio-klein-iii-usb/?tab=comments#comment-4616167 In the words of Scotty from Star Trek: "Ah cannae do it Cap'n" I'm currently doing an A-B test on my desktop between the Klein III and another respected but very cheap DAC. Without hearing the Klein III I would be pleased with 'the other DAC' but unless I get major pushback I think I'm going to hang onto the first device in my Gieseler ausrichten. The second was an Enhanced Gold Tune Kraftwerk but that was sold in a moment of rationalism after changing my streamer which necessitates a DAC with S/PDIF input. Edited September 18, 2020 by lenticularis A-B test summarised 2 Link to post Share on other sites
RankStranger 3,579 Posted September 18, 2020 Share Posted September 18, 2020 18 minutes ago, lenticularis said: Without hearing the Klein III I would be pleased with 'the other DAC' If you send the Klein III to me, you won’t be able to hear it! Problem solved! 2 2 Link to post Share on other sites
lenticularis 526 Posted September 18, 2020 Share Posted September 18, 2020 (edited) 4 minutes ago, RankStranger said: If you send the Klein III to me, you won’t be able to hear it! Problem solved! That's very true! If I decide it's going you'll be contacted first... Incidentally, a fave album on Tidal is a live concert for Joni Mitchell's 75th birthday. Kris Kristofferson sings in a truly execrable way on this...so bad, it's still full of atmosphere: https://tidal.com/browse/track/105048398 Edited September 18, 2020 by lenticularis 2 Link to post Share on other sites
Tarzan 111 Posted September 18, 2020 Share Posted September 18, 2020 6 hours ago, mcb said: More quality products from a quality manufacturer/supplier. Clay’s pre-sale and post sale service is also top shelf👍 I couldn't agree more, and after being fortunate enough to meet the man, can I say a hell of a nice bloke. 4 Link to post Share on other sites
Mute-on 53 Posted September 18, 2020 Share Posted September 18, 2020 Sign me up for a Kompakt DAC J 1 Link to post Share on other sites
Raffinator 485 Posted September 21, 2020 Share Posted September 21, 2020 Hi Clay, Have you looked into an I2S input using a HDMI-sized input? Maybe for a future model that isn't a Kompakt? There are a lot of disc transports with this standard, and a few streamers as well. Most reviews seem to prefer it over SPDIF. 1 Link to post Share on other sites
Gieseler Audio 2,472 Posted September 22, 2020 Author Share Posted September 22, 2020 Hi John, yes that will certainly be an option on my new higher end model but it is a fair way off. Link to post Share on other sites
