Usr9742 3 Posted September 16, 2020 Share Posted September 16, 2020 Budget is max around 800aud. I'm looking for a pair of bookshelves preferably. Right now I I'm looking at these monitor audio bronze 100 speakers. They have 8inch drivers which should be good for bass. If anyone using them how do you like them. Won't be listening to loud music so looking for some speakers which will give very detailed, clean sound at not loud volumes. Tia Link to post Share on other sites
blakey72 1,375 Posted September 17, 2020 Share Posted September 17, 2020 These go very well with Yamaha. These will be very clear at low volumes but won't be great in the bass department. The bronze 100's may be a good call. 1 Link to post Share on other sites
wen 1,653 Posted September 17, 2020 Share Posted September 17, 2020 CAV have Monitor Audio monitor 200 for $899 reduced from $1349, should be a stunning speaker for the price, slim floorstanders take up as much room as bookshelf speakers on stands. These may survive a few amp changes as well 1 Link to post Share on other sites
Usr9742 3 Posted September 17, 2020 Author Share Posted September 17, 2020 That MA 200s seems like a good value but I actually ended up buying the bronze 100s. Let's see how im gonna end up liking them. Thanks for the replies all. Link to post Share on other sites
blakey72 1,375 Posted September 18, 2020 Share Posted September 18, 2020 11 hours ago, Usr9742 said: That MA 200s seems like a good value but I actually ended up buying the bronze 100s. Let's see how im gonna end up liking them. Thanks for the replies all. Yeah good call, congratulations on the purchase. If they sound a little bright try leaving the grills on or use less toe-in 1 Link to post Share on other sites
