Ericcklau 266 Posted September 15, 2020 Share Posted September 15, 2020 hi all I am wondering if I want to use oppo 103 as an transport and decode to qutest, the only output I can use is hdmi out to qutest usb in right? Link to post Share on other sites
danrey 36 Posted September 15, 2020 Share Posted September 15, 2020 HDMI to usb won't work. Seems you can do optical output on the 103, then input into the optical input on the qutest. Just need an Toslink optical cable. 1 Link to post Share on other sites
Snoopy8 3,563 Posted September 15, 2020 Share Posted September 15, 2020 You can use either the Coax no.4 or optical no. 5 output from Oppo to feed the Qutest 1 Link to post Share on other sites
Ericcklau 266 Posted September 15, 2020 Author Share Posted September 15, 2020 1 minute ago, danrey said: HDMI to usb won't work. Seems you can do optical output on the 103, then input into the optical input on the qutest. Just need an Toslink optical cable. 2 minutes ago, Snoopy8 said: You can use either the Coax no.4 or optical no. 5 output from Oppo to feed the Qutest I am using coaxial have no sound but qutest show white light decoding dsd signal. Link to post Share on other sites
Snoopy8 3,563 Posted September 15, 2020 Share Posted September 15, 2020 1 minute ago, Ericcklau said: I am using coaxial have no sound but qutest show white light decoding dsd signal. Cannot send DSD over coax. Need to get Oppo to convert to PCM first. 1 Link to post Share on other sites
Ericcklau 266 Posted September 15, 2020 Author Share Posted September 15, 2020 Just now, Snoopy8 said: Cannot send DSD over coax. Need to get Oppo to convert to PCM first. Ok I see I try Link to post Share on other sites
Ericcklau 266 Posted September 15, 2020 Author Share Posted September 15, 2020 7 minutes ago, Snoopy8 said: Cannot send DSD over coax. Need to get Oppo to convert to PCM first. Even set PCM on oppo still no sound when playing Sacd. Link to post Share on other sites
Snoopy8 3,563 Posted September 15, 2020 Share Posted September 15, 2020 Try normal CD and also optical. If no sound, then something wrong in setting or maybe hardware problem?? Link to post Share on other sites
Ericcklau 266 Posted September 15, 2020 Author Share Posted September 15, 2020 10 minutes ago, Snoopy8 said: Try normal CD and also optical. If no sound, then something wrong in setting or maybe hardware problem?? Normal cd works, even dsd files via oppo works but play sacd not work. Link to post Share on other sites
Snoopy8 3,563 Posted September 15, 2020 Share Posted September 15, 2020 Please have a look at this thread. It appears that the Oppo does not allow SACDs to be played via coax, spdif You can either rip the SACD using the Oppo 103 or use a HDMI extractor that converts HDMI to coax/optical. 1 1 Link to post Share on other sites
Ericcklau 266 Posted September 15, 2020 Author Share Posted September 15, 2020 6 hours ago, Snoopy8 said: Please have a look at this thread. It appears that the Oppo does not allow SACDs to be played via coax, spdif You can either rip the SACD using the Oppo 103 or use a HDMI extractor that converts HDMI to coax/optical. thank you very much I fully understand now. Link to post Share on other sites
