dbastin 386 Posted September 13, 2020 Share Posted September 13, 2020 (edited) This thread is complimentry to others I created ... Ethernet switches for audio - Part A: List of switches, related info & experiences Ethernet cables for audio - Part C : use of fibre optical cables, SFPs, media convertors, etc This thread is where people can share their views about which routers give best performance for audio purposes. You will see there is posts claiming routers won't make much if any difference to audio. These are valid, however there may be possibilities to be explored to demonstrate otherwise, At page 6 I have suggested development of a specification for routers that would be optimal for audio purposes with the intent of breaking away from circular debates of weather or not routers make a difference. I suspect routers with SFP for fibre will arise because fibre provides good isolation and is low cost per metre to achieve an ethernet connection that doesnt collect noise en-route. Posts in this discussion may suggest or recommend particular routers, and discuss pro/cons of upgraded power supplies, power cables, grounding, optimised settings, tweaks, modifications, etc - but try not to raise ethernet switches or cables (there's other thread discussions about those). MIcrotik and Ubquiti are brands that have been suggested that offer low cost enterprise class performance and features. The Microtik range includes switches 'CRS' switches with router functionality. - their processors are relatively limited (compared to high capacity routers) however likely to be adequate for households. Ubiquiti offers Unifi and EdgeMAX. EdgeRouters offer some routers with a switching chip so switching does not affect CPU usage/Ioad. I created this thread (and others about ethernet for audio) with a hope to create resources for members to benefit, and improve their enjoyment. Ultimately, once we explorre routers, I have in mind creating a thread 'Ethernet Systems for Audio: Putting it all together' with a view to creating a resource to help understand what components to use where, to balance their impact and bang for buck. To help novices navigate this rabbit hole which is more of a rabbit warren (aka, network). Please be civil - so this doesn't go to the Great Debate, or shut down. Edited March 24 by dbastin Clarified scopeoc thread Link to post Share on other sites
dbastin 386 Posted September 13, 2020 Author Share Posted September 13, 2020 (edited) I'm going to kick off this thread with suggestions made recently on another thread by @rmpfyf. Namely these routers: CRS112-8G-4S-IN CRS305-1G-4S+IN (probably the pick of them, AUD$230 or so, can be DC powered in a range most LPS exist) CRS112-8P-4S-IN Here is some info about those routers. https://mikrotik.com/product/CRS106-1C-5S https://mikrotik.com/product/CRS112-8G-4S-IN https://mikrotik.com/product/CRS212-1G-10S-1SplusIN I am keen to use fibre as the backbone to my network. Edited October 10, 2020 by dbastin Link to post Share on other sites
PCOWandre 153 Posted September 13, 2020 Share Posted September 13, 2020 20 minutes ago, dbastin said: I'm a bit puzzled by those which are referred to as being both switch and router. They have a one or more switch chips, allowing ports to be configured as switches that don't traverse the CPU and have a bridge interface to the kernel. So you only get a CPU workload on routed packets, not switched frames. 1 Link to post Share on other sites
Guest rmpfyf Posted September 13, 2020 Share Posted September 13, 2020 (edited) 46 minutes ago, dbastin said: I'm going to kick off this thread with suggestions made recently on another thread by @rmpfyf. Namely these routers: And easy there Tigger, I mentioned in the same breath that these wouldn't be my last choice for an 'audio' rig (Before @recur and others rightly point out I should know better!) This said for $230 for something new with a warranty and support it's not a bad first step, not at all. They were even cheaper pre the dollar tanking a little. Edited September 13, 2020 by rmpfyf Link to post Share on other sites
BugPowderDust 479 Posted September 13, 2020 Share Posted September 13, 2020 @rmpfyf I’ve lost interest in discussions about Ethernet, cables, switches and routers around here. Please leave me out. There are way too many people on here with a deep seated belief that spending excessive money on something that has been standardised and tested to death (Ethernet, tcp/IP) in much more high pressure environments (Eg HFT, content delivery networks etc) will yield a better audio outcome. Most don’t understand that the delivery of the audio stream is asynchronous to the underlying transport, that buffers handle most of the transmission issues comfortably. All I hear is anecdotal evidence and confirmation bias. Spend your money but I’d wager 100:1 that if the same money was spent on room treatment you’d get a much better outcome. 5 Link to post Share on other sites
Stereophilus 1,197 Posted September 13, 2020 Share Posted September 13, 2020 I’m looking at getting a mesh wifi router for my house. Looking at something like this: https://www.asus.com/au/Networking/ZenWiFi-AX-XT8/ I chose this one as it has QoS. My question is, would this be any worse for audio, compared to say a purely Ethernet router, like a Ubiquiti Edge? I plan to use it connected directly to the NBN modem, and then using a ethernet from one of the LAN ports to the music room. The mesh wifi is for everything else in the house. Any thoughts? Link to post Share on other sites
PCOWandre 153 Posted September 13, 2020 Share Posted September 13, 2020 Leaving the audio story aside, mesh wifi should be a last resort if you can't run cable to dedicated access points. Link to post Share on other sites
Guest rmpfyf Posted September 13, 2020 Share Posted September 13, 2020 9 minutes ago, recur said: @rmpfyf I’ve lost interest in discussions about Ethernet, cables, switches and routers around here. Please leave me out. There are way too many people on here with a deep seated belief that spending excessive money on something that has been standardised and tested to death (Ethernet, tcp/IP) in much more high pressure environments (Eg HFT, content delivery networks etc) will yield a better audio outcome. Most don’t understand that the delivery of the audio stream is asynchronous to the underlying transport, that buffers handle most of the transmission issues comfortably. All I hear is anecdotal evidence and confirmation bias. Spend your money but I’d wager 100:1 that if the same money was spent on room treatment you’d get a much better outcome. I respect your position. When I've time I'll link back to your explanations on why carrier grade switchgear, which I think were spot on. I'll maintain that whilst all the above is correct there's an effect on (in a broad sense) OS jitter which may be palpable depending your playback though good design downstream can take care of this. This said standards again rule supreme here - AES67 implementing IEEE 1588 basically kills the jitter argument for good. Nanosecond perfect, if you want it, all over standard network cabling. As in that's the end of special cabling anything having any merit whatsoever. I think everyone here is well-intended though the amount of money spent in some cases is crazy for a problem that can be solved easily. Whilst (IEEE 1588) compliant switches are light on the ground they're growing in number and hopefully the audio community takes heed. AES67 is an excellent standard. Link to post Share on other sites
Guest rmpfyf Posted September 13, 2020 Share Posted September 13, 2020 15 minutes ago, Stereophilus said: I’m looking at getting a mesh wifi router for my house. Looking at something like this: https://www.asus.com/au/Networking/ZenWiFi-AX-XT8/ I chose this one as it has QoS. My question is, would this be any worse for audio, compared to say a purely Ethernet router, like a Ubiquiti Edge? I plan to use it connected directly to the NBN modem, and then using a ethernet from one of the LAN ports to the music room. The mesh wifi is for everything else in the house. Any thoughts? I'm with @PCOWandre on this one... can you have cables run instead? Link to post Share on other sites
Stereophilus 1,197 Posted September 13, 2020 Share Posted September 13, 2020 (edited) 40 minutes ago, rmpfyf said: I'm with @PCOWandre on this one... can you have cables run instead? I have cat 6 Ethernet wired through the house. However, it is a big house, and even with 3 cheap wifi routers in sync (not meshed), there are weak signal areas. My theory would be to wire the slave router to the master at opposite ends of the house, and free up the backhaul bandwidth to improve the overall wifi quality. Is there something about mesh wifi that would otherwise be a concern? Edited September 13, 2020 by Stereophilus Link to post Share on other sites
PCOWandre 153 Posted September 13, 2020 Share Posted September 13, 2020 If you have cable in place, look at deploying Unifi access points (or something similar from your favourite vendor). I don't generally see much point in the overpriced consumer product that always seems to introduce limitations and problems. Let access points be access points. Real wifi solutions will help your devices roam from AP to AP. Link to post Share on other sites
Stereophilus 1,197 Posted September 13, 2020 Share Posted September 13, 2020 27 minutes ago, PCOWandre said: If you have cable in place, look at deploying Unifi access points (or something similar from your favourite vendor). I don't generally see much point in the overpriced consumer product that always seems to introduce limitations and problems. Let access points be access points. Real wifi solutions will help your devices roam from AP to AP. So I use 3x cheap APs currently. Fairly happy, except for some weak signal areas and I want to get wifi 6 speeds because we mostly use wireless devices around the house. I take the point about cost of the XT8, but I figured it would provide better coverage and faster speeds, justifying the cost. Thanks for the input. Link to post Share on other sites
Guest rmpfyf Posted September 13, 2020 Share Posted September 13, 2020 54 minutes ago, Stereophilus said: I have cat 6 Ethernet wired through the house. However, it is a big house, and even with 3 cheap wifi routers in sync (not meshed), there are weak signal areas. My theory would be to wire the slave router to the master at opposite ends of the house, and free up the backhaul bandwidth to improve the overall wifi quality. Is there something about mesh wifi that would otherwise be a concern? 2-3x WAP's will solve. One big network (or as many as they like). Done. I use these. https://shop.duxtel.com.au/product_info.php?cPath=30&products_id=417. Rock solid. Link to post Share on other sites
PCOWandre 153 Posted September 13, 2020 Share Posted September 13, 2020 I just wouldn't bet on removing access points and replacing them with another device to actually improve the situation, compared to just deploying an additional AP in your weak signal area. Have you conducted a site survey with signal measurements, made sure you don't have overlapping channels, the usual wifi rigmarole? Link to post Share on other sites
Stereophilus 1,197 Posted September 13, 2020 Share Posted September 13, 2020 I think another WAP will work, I just thought I’d upgrade the other 3 WAPs at the same time... so price compared to the XT8 became a lot closer. Aside from this, and back onto something closer to the topic, does separating wireless routing duties from the wired router offer any benefit (audio specific or otherwise)? Or is it ok to have 1 device doing all the routing? Link to post Share on other sites
Guest rmpfyf Posted September 13, 2020 Share Posted September 13, 2020 11 minutes ago, Stereophilus said: I think another WAP will work, I just thought I’d upgrade the other 3 WAPs at the same time... so price compared to the XT8 became a lot closer. A mate on 6 acres and a 60sq home does fine on three of the devices mentioned turned down to 50% radio strength, and only one of the devices is actually installed in the home. Choose wisely, study where they go and you'll be fine. 11 minutes ago, Stereophilus said: Aside from this, and back onto something closer to the topic, does separating wireless routing duties from the wired router offer any benefit (audio specific or otherwise)? Or is it ok to have 1 device doing all the routing? Fine to have one device doing the routing, particularly if you can keep regular decisioning at switch level. What's important is how things are routed, and that the intent/functionality is supported on whatever is doing your switching. Link to post Share on other sites
dbastin 386 Posted September 15, 2020 Author Share Posted September 15, 2020 (edited) On 13/09/2020 at 2:16 PM, rmpfyf said: these wouldn't be my last choice for an 'audio' rig So what would you suggest as next best in terms of performance for audio? Edited September 15, 2020 by dbastin Link to post Share on other sites
Guest rmpfyf Posted September 15, 2020 Share Posted September 15, 2020 45 minutes ago, dbastin said: So what would you suggest as next best in terms of performance for audio? AES67 is a dream for now (no time to implement), I'd get something carrier-grade with SFP for starters, a good-quality fibre cable and a good fibre card in the PC. If you wanted to hack it you could. But starting with something not CPU-bound is a good start. It won't be $230 new though Link to post Share on other sites
PCOWandre 153 Posted September 15, 2020 Share Posted September 15, 2020 Actual carrier-grade is a bit much. Enterprise-grade is more reasonable. 3750G should be cheap enough second-hand and won't run out of steam. Link to post Share on other sites
dbastin 386 Posted September 15, 2020 Author Share Posted September 15, 2020 The AES discussion as been interesting (BTW, its on another thread). And for most people its probably not accessible or practical. My endpoint is not a PC. And even the Antipodes server is unlikely to be able to accommodate a fibre NIC. I will probably use EtherRegen as a Media Convertor, and the wired ethernet from Side B. How would cariier grade be more beneficial than enterprise grade in terms of use for short runs (eg. household scale) with the aim of maximising audio quaiy? What brands are carrier grade? How do I decipher if it is not CPU bound, and why would that be better (lower electrical noise, heat?). Cheers Link to post Share on other sites
dbastin 386 Posted September 15, 2020 Author Share Posted September 15, 2020 7 minutes ago, PCOWandre said: 3750G Thanks. Do Cisco have routers with less wired ports and more SFPs than 3750? Link to post Share on other sites
Guest rmpfyf Posted September 15, 2020 Share Posted September 15, 2020 9 minutes ago, PCOWandre said: Actual carrier-grade is a bit much. Enterprise-grade is more reasonable. 3750G should be cheap enough second-hand and won't run out of steam. That's a fair call. My lingo is out. 'Professional stuff that isn't CPU-bound' is the step beyond the Mikrotik/Ubiquiti's of the world, and they are a step beyond consumer stuff. Link to post Share on other sites
PCOWandre 153 Posted September 15, 2020 Share Posted September 15, 2020 (edited) There's so much random Cisco hardware out there, you'll have no trouble stitching it all together. Hang on -- how much do you want to plug in? If you're trying to keep noise out, you only need fibre to the bits you're trying to keep noise away from. You don't need to put everything on fibre. Edited September 15, 2020 by PCOWandre Link to post Share on other sites
Guest rmpfyf Posted September 15, 2020 Share Posted September 15, 2020 4 minutes ago, dbastin said: The AES discussion as been interesting (BTW, its on another thread). And for most people its probably not accessible or practical. My endpoint is not a PC. And even the Antipodes server is unlikely to be able to accommodate a fibre NIC. I will probably use EtherRegen as a Media Convertor, and the wired ethernet from Side B. But you see there's the rub - many audio solutions are ultimately limited by convenience. You could have mega-FIFO buffers everywhere with kickass clocks and implementations, though that'd be somewhere around the $1k mark retail all onit's own and most audiophiles would rather pay for the latest thingy blah blah and wouldn't stomach a half second or more delay on playback. You could have fibre at the endpoint but most audiophiles would rather not stomach the $500 or so it'd add to every product offering a good implementation, because so few would that the price ends up being >>$500 because there's no scale. This said the market for high end gear is a little disgusting here IMHO - most makes will happily slug punters for Bling They Know How To Make - witness music servers running $500 costing in excess of $2k, power supplies with audio-quality caps, etc - but won't get into Stuff That Makes A Difference That They'd Need To Stretch For. There are a few people on this forum that are fortunate enough to play at the bleeding end, right where it's expensive. And I think these people have great motivations, the share their findings with us all and we all gain a little through their travels. But whoever sells to them needs a touch up. We get into these recursive discussions around solutions and down rabbit holes of ever-more-rarefied solutions, the discussion moves so quickly beyond definitions of problems that we've a complete industry of solutions of ever-increasing resolution that are fairly iffy in terms of their actual accuracy towards solving problems. When you've paid as much for four-figure cables, super-spec routers and the like then it's fair to suggest you can take a step back and realise you can afford a solution including fibre, or AES67, or whatever else that actually deals with problems in a more structured and diligent manner. This or one admits they've accepted some inherent compromises in their rig and faces a comfort level in what they'll spend to indulge it. The EtherREGEN is one of the best engineered band-aids I've ever seen. It's a band-aid as in 'you're trying to get packets to land in a structured way without using a means of sending them with any consideration for timing' and 'you want min noise to the device along the cable but you're using copper' (or silver, see 'rarefied solutions' above). I like the device. It attempts to deal with many things you might face, and makes an honest fist of solving for all of them. It is not a last-word solution for any of them. I would stress that many solutions are compromised not just in the network implementations but how they handle data at an endpoint once they have it. As @PCOWandre has detailed, there are some very reasoned approaches to getting last-word jitter performance, but you're not going to get it through Roon. If I didn't have the PC and I used canned media server software and I wasn't prepared to change either - which is fine, it's not a criticism, just an observation - then a good switch, fibre to an EtherREGEN, a high-quality cable (likely UTP) to the device as short as reasonably possible would be the go. I'd play with network settings on the upstream switch to limit traffic and up priority on the audio route. If you were worried about conducted s*** between the EtherREGEN and the endpoint, a fibre Ethernet isolator could work (yes, GigaFOIL is the best of them) though it's a tradeoff - you're changing the waveform that you paid a nice router to make - IMHO a (very) short Ethernet cable would be a smarter choice. My 2c. Link to post Share on other sites
PCOWandre 153 Posted September 15, 2020 Share Posted September 15, 2020 18 minutes ago, dbastin said: cariier grade be more beneficial than enterprise grade Actual carrier-grade equipment is so big, power-hungry and noisy (think four classic Krells stacked on top of each other with 32 fans blowing on them) that you'd never, ever hear any noise because you couldn't hear it over the giant stack of equipment roaring. OH&S guidelines recommend hearing protection in network sites. I feel like these threads are going around and around in circles a little. I always recommend looking at IT problems as IT problems - heading in with a business requirement or fault to be remediated, identify the root cause, design a solution, review that solution and implement with a set of success/fail criteria. Now, I do understand a requirement of "bored and want to make things nicer", at which point I'm going to recommend mapping out your entire network and looking at what can be made nicer without wheeling in a 19" rack full of hardware. And I say this as someone who used to have two 19" racks of hardware running at home. Link to post Share on other sites
keinesorge 128 Posted September 15, 2020 Share Posted September 15, 2020 (edited) I'm using a Netgear DG834v4. An ADSL hand-me-down. Edited September 15, 2020 by keinesorge its late. 1 Link to post Share on other sites
Hydrology 2,553 Posted September 15, 2020 Share Posted September 15, 2020 Trying to get my hands on a Waversa WSmartHub. New Australian distributor so stock shouldn’t be too far away. Link to post Share on other sites
Assisi 1,319 Posted September 16, 2020 Share Posted September 16, 2020 On 13/09/2020 at 5:19 PM, recur said: All I hear is anecdotal evidence and confirmation bias. Spend your money but I’d wager 100:1 that if the same money was spent on room treatment you’d get a much better outcome. @recur, To suggest that those who perceive a benefit from audio quality network components as just mere confirmation bias is to me of itself confirmation bias to justify one’s respective position. Rather than allude to anecdotal evidence it would be interesting to actually experience the benefits of a network comprising audio quality components. You may be surprised. If what comes out of your speakers is low quality then room treatments will not improve the SQ. It seems to me that all a room treatment will do is maybe help so that the listening experience is not further degraded by room imperfections. John 1 Link to post Share on other sites
Assisi 1,319 Posted September 16, 2020 Share Posted September 16, 2020 (edited) On 13/09/2020 at 5:46 PM, rmpfyf said: I think everyone here is well-intended though the amount of money spent in some cases is crazy for a problem that can be solved easily. Whilst (IEEE 1588) compliant switches are light on the ground they're growing in number and hopefully the audio community takes heed. AES67 is an excellent standard. It seems to me that you and a few others are taking a simplistic perspective to what is possibly a little more complex for many of us. Some members of Stereo Net have the knowledge and skills to design and construct well performing audio components. Most members are probably not so blessed. Most need to buy what they need or want. Even less members probably have the knowledge and skills to put together and setup networks with the components as discussed in this and other threads. I have to buy the components and connect them up and hope that the network actually works. I am still surprised that mine does and especially the listening outcome. In simple terms what is the problem that can be easily solved? How would a person with no network skills go about doing it? John Edited September 16, 2020 by Assisi Link to post Share on other sites
BugPowderDust 479 Posted September 16, 2020 Share Posted September 16, 2020 3 minutes ago, Assisi said: @recur, To suggest that those who perceive a benefit from audio quality network components as just mere confirmation bias is to me of itself confirmation bias to justify one’s respective position. Rather than allude to anecdotal evidence it would be interesting to actually experience the benefits of a network comprising audio quality components. You may be surprised. If what comes out of your speakers is low quality then room treatments will not improve the SQ. It seems to me that all a room treatment will do is maybe help so that the listening experience is not further degraded by room imperfections. John John, I'm just a tad experienced in networking and have decades of experience delivering far more time sensitive and bandwidth heavy applications than audio. I've been involved in design and implementation of super low latency, high frequency trading networks here and in the US and also ran the team that delivered the biggest IP based video distribution network in this country. I also personally know people who design the switches that run our banking and internet industries and the IP backbones for companies like Google. Your assertions that you hear a difference because you spent money on something is understandable and I won't dispute it, but it doesn't make it anything other than anecdotal in nature. 4 1 Link to post Share on other sites
pwstereo 704 Posted September 16, 2020 Share Posted September 16, 2020 1 hour ago, Hydrology said: Trying to get my hands on a Waversa WSmartHub. The Ethernet portion of that device is described as a hub, so all traffic repeated on all ports, it's not even a switch. Doesn't the thread title request a router? 1 Link to post Share on other sites
BugPowderDust 479 Posted September 16, 2020 Share Posted September 16, 2020 I think the name might be misleading. I've seen it advertised as both a hub and a switch interchangeably, although they are very different things in reality. It's hard to tell when the OEM website is predominantly all in Japanese. @Ittaku can you read the WsmartHub bit and translate for us? But yeah, not a router. Link to post Share on other sites
Ittaku 4,740 Posted September 16, 2020 Share Posted September 16, 2020 1 minute ago, recur said: I think the name might be misleading. I've seen it advertised as both a hub and a switch interchangeably, although they are very different things in reality. It's hard to tell when the OEM website is predominantly all in Japanese. @Ittaku can you read the WsmartHub bit and translate for us? Link? Link to post Share on other sites
BugPowderDust 479 Posted September 16, 2020 Share Posted September 16, 2020 https://waversasystems.com/wsmarthub 1 Link to post Share on other sites
Ittaku 4,740 Posted September 16, 2020 Share Posted September 16, 2020 2 minutes ago, recur said: https://waversasystems.com/wsmarthub It's a network switch. They call it a hub to describe that it handles both ethernet and USB. Link to post Share on other sites
pwstereo 704 Posted September 16, 2020 Share Posted September 16, 2020 From the makers website (also repeated on resellers websites): "The LAN and USB hub circuits that affect sound quality are ultra-high-end specifications that operate with the high-precision power supply of the built-in battery of WSmartHub." Link to post Share on other sites
BugPowderDust 479 Posted September 16, 2020 Share Posted September 16, 2020 I managed to squeeze it through Google Translate. They say it is a 100 Mbps "switching hub", which I'll say is probably an unmanaged switch. Networking might be complicated to the uninitiated, but there's no excuses for getting the terminology wrong if you're a manufacturer. I continue to love the furphy that abounds that a 100 Mbps port is better than a gigabit port because "noise". The big noise removal in the "switch" is apparently by getting rid of those LEDs that most switches have to let you know the thing at the other end of your cable is connected and turned on. Points loss for claiming LAN cables are directional, not knowing the difference between a hub and a switch and for thinking a better clock on the switch will make any difference to the IP traffic running above it. 1 Link to post Share on other sites
pwstereo 704 Posted September 16, 2020 Share Posted September 16, 2020 There's a .kr makers website in English. It says "Key Features Remove/isolate digitial noise from USB/Ethernet source equipment Built-in USB2.0 Hub and Gigabit Ethernet Hub" Link to post Share on other sites
PCOWandre 153 Posted September 16, 2020 Share Posted September 16, 2020 7 minutes ago, recur said: Points loss for claiming LAN cables are directional, not knowing the difference between a hub and a switch and for thinking a better clock on the switch will make any difference to the IP traffic running above it. Can we take away another couple of points for a billet CNC job that looks like a "My First Fusion360 Project"? 10 minutes ago, recur said: getting rid of those LEDs Getting rid of some passives and adding an LCD with controller and backlight! Yippie! 2 Link to post Share on other sites
Ittaku 4,740 Posted September 16, 2020 Share Posted September 16, 2020 39 minutes ago, recur said: I managed to squeeze it through Google Translate. They say it is a 100 Mbps "switching hub", which I'll say is probably an unmanaged switch. Networking might be complicated to the uninitiated, but there's no excuses for getting the terminology wrong if you're a manufacturer. I'm a Japanese translator... I explained it above. 1 Link to post Share on other sites
