Just putting this thread up as promised to @DavidDoerfer who kindly paid forward some free gear a few weeks ago.
I received this amplifier for free from David. A NAD 3155 a bit of research shows they were built in 1985 and this one has been particularly well looked after. Nad specs. I wish all amps had proper specs like this (not many do anymore) instead of inflated power figures at high distortion figures this one shows both chanels driven from 20-20khz with no more than the rated distortion (which is nice and low).
I decided to not even power this amp up and just went into replacing a few capacitors and checking all of them with my meter. Mind you I would have expected this to have worked since most caps were well within spec. The board looked in good condition with what seemed to be original transistors as well.
You will notice that all the electrolytic capacitors on each board have their negative side all facing the same direction. Makes it easy to know which way to place the caps when soldering. (nice engineering thought).
I always found the heatsinks in these Nads interesting. It looks like they used an L piece of extruded aluminium and then get some sharp fins to scrape down the edges to create the fins for the heatsink as evident by the curly ends of the fins.
I haven't checked, but I think these are original transistors.
The caps I replaced. Note that 95% of these were still within spec but I replaced them anyway with new ones. I didn't replace the Power supply caps but they were well within spec and reused them.
I connect a bulb tester (have not got a variac). the bulb is connected in series with the 240v mains and the amp pluged in afterwards. When powering up the bulbs glows bright briefly (less than a few tenths of a second) before dimming down to barely just on. If it continues to glow brightly then there is something wrong with the amp blown transistor or what not that needs to be fault rectified. This amp was perfectly fine.
The bigger multimeter not connected here was used to show the dc offset on both chanels which was un der 0.5mV for both channels. The 2 smaller multimeters show the standby (quiescent) current through the power transistors. The manual states 20 - 25mV setting. Only a very minor tweak was needed for one channel once warmed up. It was still passable before adjusting though.
Put some sine wave through. Used a 7.3ohm resistor as load and just before clipping.
That was 36.8v peak...so   for those who like math.   36.8 / root2 = 26v rms
V = IR  so Current = 26/ 7.3  (7.3 ohm load resistors)   = 3.56 A
Power = VI   = 26 x 3.56  = 92Watts into the single channel being tested.
Running both channels at the same time produced 33.2V Peak so it has around 3V droop in supply voltage with both channels used as can be expected.
This equates to 75W per channel both channels flat out. This actually exceeded the NAD spec sheet although I didn't have any distortion meter on their so I could have been over driving it slighly even though the scope showed no flat spotting of the peaks of signal.
Finally some pics of the amp playing through some speakers. The amp still sounds great and hopefully has another good 20 years of life left in it.
Can't tell this is a diy household at all can we.
Cheers Simon
    • By sk280
      Item Condition: Used, Excellent Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Pennant Hills 2120 State: New South Wales Payment Method: Cash on pickup, Osko, Paypal Reason for selling: Funding upgrade Further information:
       NAD T748 7.1 RECEIVER with HDMI, ARC, HDMI PASSTHROUGH in excellent condition with original remote and microphone (also have original CD with manual, but need to search for it if buyer wants it)
      - Full demo on pickup
      - Sounds fantastic even for 2 channel music, currently connected for stereo use, happy to demo 5 channels as well if required.
      - No issues at all, some marks cosmetically
      - Has 7.1 Pre Outs
      - Pickup from Pennant Hills area NSW 2120
      - Local pickup preferred and will be given preference over shipping.
      PLEASE READ
    • By Hilltop Rob
      Item Condition: Brand new. Opened, Unused. Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Laidley State: Queensland Payment Method: Cash, EFT, PayPal Reason for selling: Not Needed Brand new in box.
      Opened but never used.
      All accessories included.
      PLEASE READ
    • By Ken Lipper
      Item Condition: Very Good - everything works perfectly Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Brisbane State: Queensland Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: Not used Further information:
      I’m selling an NAD D3020 that I, impulsively, bought recently. It’s a great little all-in-one integrated amp with all the digital inputs you need. Due to it’s diminutive size, it would be perfect for a small, secondary system in the office, spare room or kitchen. For the budget minded, matched with the right speakers, it’s more than capable of playing the role of primary system.
      It includes the following:
      The unit itself Remote control Aussie power cord Quick-start guide All original packing materials including the velvet bag
      NOTE: This is the original D3020, not the V2, so it doesn’t have a phone stage if that’s important to you. Otherwise, the original and V2 are more or less the same.
      Here are a few reviews and history of the iconic NAD 3020 evolution:
      https://www.whathifi.com/au/nad/d-3020/review https://www.stereophile.com/content/nad-d-3020-integrated-amplifier https://darko.audio/2014/01/nad-d-3020-review-part-1-vs-nad-3020i/ (Part 1 of 3) Plenty more on YouTube
      Pickup in Bulimba, QLD (inner-city Brisbane) is welcomed but I’m happy to ship, with insurance, in Australia for $30.
      PLEASE READ
    • By Benpen
      Item: NAD T777V3, ARCAM AVR 550 or av receiver with DIRAC
      Price Range: NAD T777 3K, ARCAM AAVR 550 3K
      Item Condition: Used/ Ex demo
      My old Marantz amp died and looking to replace it with a Dirac( or comparable) solution,
      Looking for at least 60Wpc
      so would also conisder:
      NAD T758v3, $1.5Kish
      Arcam AVR 390, $2kish
      Anthem 720
      I am based in Sydney
      Would love a AVR850 or an anthem MRX 1120 , but i think its out of my budget.
    • By kukynas
      Hi guys,
      are you interested in measurements and tear down of this unit? I would do it anyway it's just matter of documenting it all and providing my findings, just let me know...
      Dan
