FS: Relist. Price drop. Ortofon MC20 Super MC Cartridge
Item Condition: 9.5/10
Suburb or Town: Tura Beach
State: New South Wales
Payment Method: Paypal F&F, EFT
Reason for selling: Not being used. Downsizing and rationalising
Further information:
I have relisted this and dropped my original price. I am open to fair and reasonable offers.
Low output MC cartridge with van den Hul type 2 stylus with less than 50 hours on the clock.
It is quite respected and well reviewed.
I probably didn't give it a chance to run in and warm up but I preferred my Garrott Bros modified Coral MC81 at the time. It is quite respected and well reviewed.
As seen in the photos, it has all the accessories in the packaging. The mounting screws are there but have been used. The cardboard outer box is about 8/10 as it is a bit scuffed.
PLEASE READ
Edited by Igotmearecord
additional details
    • By Class A Audio
      Item Condition: Trade in, excellent physical condition and function Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Notting Hill State: Victoria Payment Method: Pickup - Cash, Paypal, COD Only Reason for selling: Further information:
      Location: Class A Audio, 8/585 Blackburn Rd, Notting Hill, VIC, 3168. phone (03) 8555 0735
      The Musical Fidelity X-PSU is the dedicated power supply for the X-CAN, X10-D, X-LP, X-DAC and the other models of the X-ponents series. It delivers 12 Volts of AC for up to 4 devices. It also provides the on/off switch that's missing from individual devices. With the X-PSU at work, one immediately hears the difference it makes. It is a truly worthwhile investment. Instantly the bass response tightens by several orders of magnitude, the midrange becomes more warm and clear, and timbre improves overall. There is a much greater sense of space, and the sound at both the low and high frequency extremes is even more detailed and exciting. The listener is able to hear the "sting" of cymbals and the precision of drum rolls better. With more running in done, one will find not only the bass has improved depth, but also better sound imaging and more details can be heard. Things are tighter with more punch, notes decay longer and there is more natural sound to cymbals and snare drums. By swapping one or more of the plug top transformers for an X-PSU, the user gets to hear a richer sound altogether. The X-PSU is a must have if they own the X-Can or any other Musical Fidelity X-Ponents.
      Specifications
      Outputs
      Four @ 12V AC 20VA
      Power requirement
      100/115/230V AC 50/60Hz
      Factory preset
      Power consumption
      60W
      Standard accessories
      IEC mains lead
      Set of four X-Series power leads
      Dimensions(w × d x h)
      11 x 20.5 x 11cm
      Weight
      3kg
    • By Class A Audio
      Item Condition: Trade in, excellent physical condition and function. Still under warranty Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Notting Hill State: Victoria Payment Method: Pickup - Cash, Paypal, COD Only Reason for selling: Further information:
      The CD-S3000 CD/SACD player delivers the ultimate in audio performance with a newly designed disc drive mechanism which eliminates vibrations and new digital/analogue circuits to ensure data loss is minimised.
      Optimised high-precision, rigid CD mechanism with heavy anchors improves vibration control and achieves precise signal reading
      Highly rigid aluminium CD tray
      Highly rigid main chassis improves anti-vibration properties and left-right symmetrical construction
      Independent configuration of digital and analogue circuits
      Digital/analogue boards with integrated power supply circuits
      Single-stage configuration I/V conversion circuit enables direct analogue output
      Exceptionally high performance 32-bit D/A converter
      Built-in USB DAC functions
      ASIO 2.3 Yamaha Steinberg USB Driver
      Pure Direct mode enhances the quality of analogue soundmusic.
      Specifications
      Disc Compatibility SA-CD, CD, CD-R/RW (MP3, WMA) and USB devices
      Output Level 2 +/- 0.3 V (1 kHz, 0 dB)
      Signal-to-Noise Ratio 116 dB
      Dynamic Range [CD] 100 dB, [Super Audio CD] 110 dB
      Harmonic Distortion [CD] 0.002% (1 kHz), [Super Audio CD] 0.002% (1 kHz)
      Frequency Response [CD] 2 Hz-20 kHz, [Super Audio CD] 2 Hz-50 kHz (-3 dB)
      Dimensions (W x H x D) 435 x 142 x 440 mm; 17-1/8” x 5-5/8” x 17-5/16”
      Weight 19.2 kg; 42.3 lbs.
    • By Class A Audio
      Audiophile Musical Fidelity X-LP MM / MC phono preamplifier.
      The Musical Fidelity X-LP is from the famous X-series and matches many other Musical Fidelity X-Series components.
      Specifications
      MM input:
      - Sensitivity 3mV
      - Input impedance 47KW
      - THD < 0.01% @ 1kHz, 350mV out
      - Input overload margin 27dB
      - S/N ratio > 75dB unweighted, > 80dB "A" weighted
      MC input:
      - Sensitivity 350mV
      - Input impedance 100W
      - S/N ratio > 65dB unweighted, > 72dB "A" weighted
      General:
      - RIAA accuracy + 0.5dB 20Hz-20kHz
      - Power requirement 12V AC 500mA (via mains adaptor supplied)
      - Dimensions (W x H x D): 110 x 110 x 220 mm
      - Weight: 1.3kg
    • By Class A Audio
      Item Condition: Brand new Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Notting Hill State: Victoria Payment Method: Pickup - Cash, Paypal, COD Only Reason for selling: Further information:
      The NA-11S1 Premium Network Audio player is arguably the most advanced, next-generation player there has ever been. Its introduction to this year’s Premium collection is a true milestone in the Marantz history and is a momentous occasion for every audiophile. Why? Because finally, it is now possible to enjoy new media on the highest of levels, by utilizing the increasingly available high resolution downloads it creates ‘studio master’ quality right in your own living room. It produces such breath-taking audio quality because inside it includes the High Current Audiophile D/A converter DSD1792 as well as a Marantz original DSP and Digital Filter PEC777- a high-end algorithm previously used only in professional recording studios - we call it Marantz Musical Mastering. This type of filtering retains greater detail for an even wider sound stage and a perfect balance. Its analogue audio circuits feature Marantz HDAM®-SA2 and HDAM®, and the Toroidal transformer ensures that there’s always power in store the instant it’s needed, while the rigid copper-plated chassis with 5mm thick aluminum top cover minimize vibration and interference. Importantly, selectable digital filters allow you to tune the sound as you prefer. The USB-B port works in asynchronous mode and supports not only 192kHz / 24bits but also the DSD 2.8MHz and 5.6MHz for maximized versatility. You can play FLAC HD 192/24 files, WAV 192/24 files, Internet Radio and Streaming Services support via Ethernet, and AirPlay Music Streaming from iTunes or iDevices – as well as many other file types. It is also DLNA 1.5 certified, so Android integration is easy, and the USB-A port on the front panel also makes playback from an iPod/iPhone/iPad or USB devices just as simple.
      Specifications
      Analog Output    2
      Coaxial Input    Yes
      Coaxial Output    Yes
      USB A Ports    Yes
      LAN    Yes
      RS-232 Port    Yes
      Warranty    Australian Manufacture Warranty
      Dimension
      Product Dimension (H×W×D)    127 x 440 x 417 mm
      Product Weight    14.6 kg
    • By Ray H
      Item Condition: NIB Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Tullimbar State: New South Wales Payment Method: PayPal+ fees, EFT or cash on pick-up. Reason for selling: NIB Further information: Aus stock from Nike shop. Extremely comfortable cross training shoe ! Postage approx $18.
      PLEASE READ
