PKay 2,180 Posted September 2, 2020 Share Posted September 2, 2020 Hi, I am looking at retiring my swimming pool solar system and replacing it with a solar system for the house (and possibly an electrical heat exchanger for the pool). I would greatly appreciate recommendations for a reputable provider? Also any tips? I would rather do it well up front so I'm not looking for the cheapest option. At this stage with battery prices where they are I won't go with that option but would like to retain the flexibility to do so in the future. Thanks in advance. Link to post Share on other sites
Administrators Marc 12,466 Posted September 4, 2020 Administrators Share Posted September 4, 2020 I can't offer any recommendations for installers in Sydney. I think you'd be best off talking to your local pool supplier on the heat exchanger part of the equation as we're talking about two different industries here. As for the solar, you'll definitely want some sort of diversion set up so that surplus energy then activates your pool heat exchanger. This is what I am doing. With a 12kW system (without batteries) I have it setup so that once I am in surplus my EV charger activates and tops the car up, then anything beyond that while still in surplus activates the heat exchanger for the pool. Regarding batteries - not sure if this applies to NSW, but in VIC I made the mistake of not doing batteries at the time of solar installation. You can only get one grant per household so to do batteries now, I can't apply for another grant. Something to consider. I would do the pool heat exchanger first, then tell the solar company you want that integrated into the system as per above. For more advice or potentially some Sydney recommendations, try a post on my other website - https://renewable.net.au/ 1 Link to post Share on other sites
rmpfyf 1,817 Posted September 5, 2020 Share Posted September 5, 2020 On 02/09/2020 at 11:45 AM, PKay said: Hi, I am looking at retiring my swimming pool solar system and replacing it with a solar system for the house (and possibly an electrical heat exchanger for the pool). I would greatly appreciate recommendations for a reputable provider? Also any tips? I would rather do it well up front so I'm not looking for the cheapest option. At this stage with battery prices where they are I won't go with that option but would like to retain the flexibility to do so in the future. Thanks in advance. Can offer some advice/leads. If you're not too concerned on price and don't want LG panels, check out Solahart and ask for a solution incorporating the CET gateway. Rheem/Solahart is incredibly risk averse - everything is 10 year warrantied as a minimum and they test extensively. They don't distribute LG panels however (which are arguably the best you can buy) but what they sell is still quite good. I have the gateway and LG kit. You'll end up with something that at the very least can monitor your consumption at a circuit level, and will expand nicely as you add more power infrastructure. In short they have an energy management system that's quite good and used in many scenarios including your own. The gateway in question is developed in Sydney; if you don't get the response you're seeking from your local distributor let me know and I'll hit up the management team directly. Consider a blanket for your pool, will help a lot. Some state governments provide partial subsidies here. If you want to go passive I'd simply ring LG and ask for your nearest dealer. There are a few checks and balances beyond usual certification to be an LG dealer. That distributorship is run out of Sydney. There are no better panels for your dollar. If you don't get love trying, PM me with a postcode and description of your property and I'll find you a dealer through the LG team. You can always add batteries later on. There are no particularly compelling hybrid inverters outside of SolarEdge's system and whilst excellent that isn't for everyone. The only reason to worry about getting one in now concerns subsidies - where they apply and are sufficient to make one viable. Making a battery work in any context beyond self-consumption involves some serious work on your switchboard which sways cost a good bit. Happy to chat via PM. 2 Link to post Share on other sites
PKay 2,180 Posted September 5, 2020 Author Share Posted September 5, 2020 1 hour ago, rmpfyf said: Can offer some advice/leads. If you're not too concerned on price and don't want LG panels, check out Solahart and ask for a solution incorporating the CET gateway. Rheem/Solahart is incredibly risk averse - everything is 10 year warrantied as a minimum and they test extensively. They don't distribute LG panels however (which are arguably the best you can buy) but what they sell is still quite good. I have the gateway and LG kit. You'll end up with something that at the very least can monitor your consumption at a circuit level, and will expand nicely as you add more power infrastructure. In short they have an energy management system that's quite good and used in many scenarios including your own. The gateway in question is developed in Sydney; if you don't get the response you're seeking from your local distributor let me know and I'll hit up the management team directly. Consider a blanket for your pool, will help a lot. Some state governments provide partial subsidies here. If you want to go passive I'd simply ring LG and ask for your nearest dealer. There are a few checks and balances beyond usual certification to be an LG dealer. That distributorship is run out of Sydney. There are no better panels for your dollar. If you don't get love trying, PM me with a postcode and description of your property and I'll find you a dealer through the LG team. You can always add batteries later on. There are no particularly compelling hybrid inverters outside of SolarEdge's system and whilst excellent that isn't for everyone. The only reason to worry about getting one in now concerns subsidies - where they apply and are sufficient to make one viable. Making a battery work in any context beyond self-consumption involves some serious work on your switchboard which sways cost a good bit. Happy to chat via PM. Thanks, I will call LG. I would prefer to do it properly with the best panels first up. I had a quick look at battery cost and just can’t see how it currently pays off. Not sure what a CET Gateway is? I do have a pool blanket, however as the pool is a kidney shape (it came with the house) it is a real pain to take off so we don’t use it as much as we should. Link to post Share on other sites
PKay 2,180 Posted September 5, 2020 Author Share Posted September 5, 2020 12 hours ago, Marc said: I can't offer any recommendations for installers in Sydney. I think you'd be best off talking to your local pool supplier on the heat exchanger part of the equation as we're talking about two different industries here. As for the solar, you'll definitely want some sort of diversion set up so that surplus energy then activates your pool heat exchanger. This is what I am doing. With a 12kW system (without batteries) I have it setup so that once I am in surplus my EV charger activates and tops the car up, then anything beyond that while still in surplus activates the heat exchanger for the pool. Regarding batteries - not sure if this applies to NSW, but in VIC I made the mistake of not doing batteries at the time of solar installation. You can only get one grant per household so to do batteries now, I can't apply for another grant. Something to consider. I would do the pool heat exchanger first, then tell the solar company you want that integrated into the system as per above. For more advice or potentially some Sydney recommendations, try a post on my other website - https://renewable.net.au/ Which panels and inverter did you go with? I’m not sure how many panels I will be able to install. It won’t be anywhere near a 12kw system. I’m having the pool doctor come over to look at my heating and pool management. I will try and retain the flexibility to install a battery in the future as they improve and hopefully the price reduces. Link to post Share on other sites
rmpfyf 1,817 Posted September 5, 2020 Share Posted September 5, 2020 9 hours ago, PKay said: Thanks, I will call LG. I would prefer to do it properly with the best panels first up. I had a quick look at battery cost and just can’t see how it currently pays off. Not sure what a CET Gateway is? I do have a pool blanket, however as the pool is a kidney shape (it came with the house) it is a real pain to take off so we don’t use it as much as we should. Batteries pay off in very few cases, self-consumption payback isn't a metric I'd go with. If you want to hit your bills aggressively or want grid resilience then they work. Even then they are the last thing you want to flex with respect to demand response - there are cheaper ways. Hot water, HVAC, thermal storage, car charging etc. To control these relative to opportunity (e.g. when the sun's out) you need either a diverter (which some inverter manufacturers offer, also some car charger manufacturers, etc -these are devices that meter your export and switch something accordingly) or a legitimate home energy management system - something that can control multiple things against complex targets. The CET gateway is such a thing. It also provides circuit-level metering. Here's some output from a house with a battery, managed hot water and HVAC. (My own home has managed hot water, HVAC and car charging.) Note the intelligent use of solar - export is minimised. You have to want it though IMHO its great, and I'd sooner go smart hot water over a batter. Live view All devices time history Hot water control 1 Link to post Share on other sites
PKay 2,180 Posted September 5, 2020 Author Share Posted September 5, 2020 Our hot water is a gas Rinnai instantaneous system which is great. We have gas cooktop and BBQ plumbed. Link to post Share on other sites
rmpfyf 1,817 Posted September 6, 2020 Share Posted September 6, 2020 2 hours ago, PKay said: Our hot water is a gas Rinnai instantaneous system which is great. We have gas cooktop and BBQ plumbed. No management for you then until car charger etc. Your only real questions concern roof sharing which becomes a microgrid/hybrid microgrid/string inverter question. Link to post Share on other sites
PKay 2,180 Posted September 15, 2020 Author Share Posted September 15, 2020 On 06/09/2020 at 12:15 PM, rmpfyf said: No management for you then until car charger etc. Your only real questions concern roof sharing which becomes a microgrid/hybrid microgrid/string inverter question. The process of getting quotes has begun and what a process.... Always interesting when someone starts off immediately stating that they wont be the cheapest (I'm not looking for the cheapest - just a fair price and a good product). I am now looking at two alternatives both using the LG panels. The back of the house is West facing. Link to post Share on other sites
PKay 2,180 Posted September 15, 2020 Author Share Posted September 15, 2020 Option 2 is Solar Edge technology. The big question for me is which is the better technology. The solar edge guy said the Enphase choke capacity down to 300 watts so the 350 panel is being under utilised. Also claims the tech support and backup is not anywhere near as good and they had more failures. It is difficult to work out who to believe. Link to post Share on other sites
PKay 2,180 Posted September 15, 2020 Author Share Posted September 15, 2020 (edited) The simple payback is very simple and I would realistically need to double the timeframe to get my payback - which is still a good investment and a benefit to the environment. @rmpfyfDo the panels increase the heat in the roof space? This is important because my stereo room is built into the roof. Edited September 15, 2020 by PKay Link to post Share on other sites
rmpfyf 1,817 Posted September 15, 2020 Share Posted September 15, 2020 36 minutes ago, PKay said: The simple payback is very simple and I would realistically need to double the timeframe to get my payback - which is still a good investment and a benefit to the environment. Both are good options for that layout though I'd favour SolarEdge if you want to integrate a battery or do any DR. Support experience about the same with both. Are you getting shading? Otherwise that could be done on a string inverter just fine. Prices are a bit high though. 36 minutes ago, PKay said: Do the panels increase the heat in the roof space? This is important because my stereo room is built into the roof. Slightly, though really depends on your roof construction. If you've got some sarking in there it'd be nor here nor there. Worry more about the effect on your AC. Link to post Share on other sites
PKay 2,180 Posted September 15, 2020 Author Share Posted September 15, 2020 9 minutes ago, rmpfyf said: Both are good options for that layout though I'd favour SolarEdge if you want to integrate a battery or do any DR. Support experience about the same with both. Are you getting shading? Otherwise that could be done on a string inverter just fine. Prices are a bit high though. Slightly, though really depends on your roof construction. If you've got some sarking in there it'd be nor here nor there. Worry more about the effect on your AC. We may get a bit of shading from the front tree. What do you mean about the effect on my AC? I'm wondering whether the panels are the same quality? Link to post Share on other sites
rmpfyf 1,817 Posted September 15, 2020 Share Posted September 15, 2020 1 hour ago, PKay said: We may get a bit of shading from the front tree. What do you mean about the effect on my AC? I'm wondering whether the panels are the same quality? All LG Neon panels are 25-year warranty. New generations of panels come out at higher power, they displace older generations in price. Quality identical, power density is not. An inverter will generate AC at a small scale. The process does not make for sine waves as beautiful as what comes out of a large thermal coal plant with 500-odd tonnes of steel going around and around; broadly speaking a square wave is made and is filtered (think Class D). Enphase does a full-amplitude square wave at a small scale aggregated across multiple inverters into a big thing. Solaredge HD Wave uses 8 square waves on DC offset at higher frequency then filtered. Theoretically you have cleaner mains with SolarEdge HD Wave (I have measured it so), though in audiophile speak it'll sound 'different' and you'll most likely enjoy your music most when the sun isn't shining or the solar PV is off assuming your equipment is on the same phase as your playback. Various factors go into how observable these phenomena are including how much PV is in your distribution network (neighbours), line quality, earthing, etc. There is no hard and fast rule or experience. 1 Link to post Share on other sites
PKay 2,180 Posted September 15, 2020 Author Share Posted September 15, 2020 4 hours ago, rmpfyf said: Both are good options for that layout though I'd favour SolarEdge if you want to integrate a battery or do any DR. Support experience about the same with both. Are you getting shading? Otherwise that could be done on a string inverter just fine. Prices are a bit high though. Slightly, though really depends on your roof construction. If you've got some sarking in there it'd be nor here nor there. Worry more about the effect on your AC. Thankfully most of my listening is at night. Link to post Share on other sites
PKay 2,180 Posted September 16, 2020 Author Share Posted September 16, 2020 New quote with the latest micro inverters which increase output from 295w to 350 per panel Hi Peter, 8.64kW - 24* LG ‘NeON 2’ 360 watt panels + Enphase IQ7A Micro Inverters - Includes GST and is after Government Rebate - STC’s) - Pre site inspection to confirm 24 panels will fit and upgrade to IQ7A + 15 yr product warranty on Enphase Microinverter.. Link to post Share on other sites
rmpfyf 1,817 Posted September 17, 2020 Share Posted September 17, 2020 On 16/09/2020 at 9:52 PM, PKay said: New quote with the latest micro inverters which increase output from 295w to 350 per panel Hi Peter, 8.64kW - 24* LG ‘NeON 2’ 360 watt panels + Enphase IQ7A Micro Inverters - Includes GST and is after Government Rebate - STC’s) - Pre site inspection to confirm 24 panels will fit and upgrade to IQ7A + 15 yr product warranty on Enphase Microinverter.. I assume the price didn't increase, as the last quote was BS given the undersized inverters Only the 7A works for that panel. If you really really want Enphase I'd try for a second quote with the 350W panel and a slightly smaller inverter. If they have the stock (and they might not) it'll be 5% or so less effective and more than 5% cheaper. This assumes you're building a system that won't do a battery indigenously tomorrow. Any batter you have with Enphase is AC-,coupled, and their offering is not really compelling. You'd either put something else on it's own inverter or a good AC-coupled battery (e.g. Tesla). Link to post Share on other sites
PKay 2,180 Posted September 17, 2020 Author Share Posted September 17, 2020 2 hours ago, rmpfyf said: I assume the price didn't increase, as the last quote was BS given the undersized inverters Only the 7A works for that panel. If you really really want Enphase I'd try for a second quote with the 350W panel and a slightly smaller inverter. If they have the stock (and they might not) it'll be 5% or so less effective and more than 5% cheaper. This assumes you're building a system that won't do a battery indigenously tomorrow. Any batter you have with Enphase is AC-,coupled, and their offering is not really compelling. You'd either put something else on it's own inverter or a good AC-coupled battery (e.g. Tesla). The price was even more ridiculous $14k. I am leaning towards SolarEdge technology. Link to post Share on other sites
rmpfyf 1,817 Posted September 17, 2020 Share Posted September 17, 2020 10 minutes ago, PKay said: The price was even more ridiculous $14k. I am leaning towards SolarEdge technology. I have happy customers with either, though I do a good amount of work with SolarEdge. Properly installed it's a good system. If you want any special stuff (smart plugs/circuits, etc) get it done during the installation. Link to post Share on other sites
PKay 2,180 Posted September 17, 2020 Author Share Posted September 17, 2020 (edited) @rmpfyfIt is difficult to know who to believe. The SolarEdge guys tell me that they are designed for hotter climates like ours and that Enphase won't work as well or last as long. Then you get the companies using Enphase. Hello Peter, Thanks for your email, I think this will open your eyes the DC optermizers vs Microinverters.. Here's a great video that explains the difference between the two products - https://www.youtube.com/watch?v=NfbyNQUFN5Y - Please also note that in the US they no longer install high voltage string inverter systems, but instead only install Module-level power electronics (MLPE) devices, like Enphase. The key difference between the two options is Enphase is a genuine ‘modular’ solution where each panel performs to its optimal output whereas Optimisers are simply paired with a string inverter for string level optimisation. Due to this ‘all panels operate independently’ functionality, your level of daily, monthly and yearly energy production is increased with Enphase. There is also no ‘central point of failure’ with Enphase, so if one panel/inverter fails it will not stop the system from operating. An Optimiser system still has a single inverter doing all the DC-AC conversation so when it fails, your entire system shuts down until it is repaired/replaced. If this were to happen at Christmas time, you could be without any solar production for 4-6 weeks. Another key benefit is the fact that Enphase will fire up independently (like popcorn in the microwave) means you’re not having to wait for a single inverter (like an Optimiser system) to hit it’s ‘trigger voltage’ to start (and continue) operating. This means that on less than ideal weather days, Enphase will outperform and generate more savings than an optimiser option. Please let me know if you have any questions. Edited September 17, 2020 by PKay Link to post Share on other sites
rmpfyf 1,817 Posted September 17, 2020 Share Posted September 17, 2020 3 minutes ago, PKay said: @rmpfyfIt is difficult to know who to believe. The SolarEdge guys tell me that they are designed for hotter climates like ours and that Enphase won't work as well or last as long. Then you get the companies using Enphase. Hello Peter, Thanks for your email, I think this will open your eyes the DC optermizers vs Microinverters.. Here's a great video that explains the difference between the two products - https://www.youtube.com/watch?v=NfbyNQUFN5Y - Please also note that in the US they no longer install high voltage string inverter systems, but instead only install Module-level power electronics (MLPE) devices, like Enphase. The key difference between the two options is Enphase is a genuine ‘modular’ solution where each panel performs to its optimal output whereas Optimisers are simply paired with a string inverter for string level optimisation. Due to this ‘all panels operate independently’ functionality, your level of daily, monthly and yearly energy production is increased with Enphase. There is also no ‘central point of failure’ with Enphase, so if one panel/inverter fails it will not stop the system from operating. An Optimiser system still has a single inverter doing all the DC-AC conversation so when it fails, your entire system shuts down until it is repaired/replaced. If this were to happen at Christmas time, you could be without any solar production for 4-6 weeks. Another key benefit is the fact that Enphase will fire up independently (like popcorn in the microwave) means you’re not having to wait for a single inverter (like an Optimiser system) to hit it’s ‘trigger voltage’ to start (and continue) operating. This means that on less than ideal weather days, Enphase will outperform and generate more savings than an optimiser option. Please let me know if you have any questions. Peter, the solar industry is not exactly a high-margin place to be and is quite full of s**t talkers. SolarEdge does fine in the US. SolarEdge and Enphase run around 80% of the residential solar market in the US (both are classed as MLPE). SolarEdge has recently lost some share to Enphase, though still outsells them 2:1. This is expected; Enphase nearly failed as a company and has recently recovered - sales were going to improve. Inasmuch as decoupling an individual panel's performance from a string, true microinverters are the only solution to do it absolutely though properly installed a hybrid micro (optimiser) solution is very nearly as good. It is not correct to term a SolarEdge system a string inverter with optimisation; it is possible to buy optimisers for string inverters and these are quite different things. The turnaround time for any genuine inverter failure replacement depends on the company you buy your system from. Your agreement is with them, not the inverter manufacturer. The minimum voltage on a SolarEdge system is practically so low as not to make any significant difference in performance. If you were to install a battery on an Enphase system, the conversion losses through mains back to DC would (more than) nullify any system performance advantages of SolarEdge. They are both very good systems with different weak points. Enphase tends to be sold with very top-end panels, you might find a better deal with a 350W panel and a slightly lesser microinverter (as suited to the panel). 'Latest' panels always cost more $/W. This only holds up if you find a dealer with stock, or access to it through their distributor. Was actually just on the phone with the GM of solar at LG (he's a friend). PM me if you've any questions and we can chat offline. 2 Link to post Share on other sites
ArthurDent 2,877 Posted September 20, 2020 Share Posted September 20, 2020 (edited) On 18/09/2020 at 9:22 AM, rmpfyf said: Enphase tends to be sold with very top-end panels, you might find a better deal with a 350W panel and a slightly lesser microinverter (as suited to the panel). Yeah, slightly odd to pair 360W panels with 350W (366W peak) inverters. Or is "overclocking" no longer in vogue? On 16/09/2020 at 9:52 PM, PKay said: 8.64kW - 24* LG ‘NeON 2’ 360 watt panels + Enphase IQ7A Micro Inverters Edited September 20, 2020 by ArthurDent Link to post Share on other sites
Rosco8 172 Posted November 24, 2020 Share Posted November 24, 2020 (edited) I have put 3 systems in with AHE in Sydney, 3 months ago added a 10Kw Trina Honey Mono (28x370w panels) to my existing 6Kw system 18 x 300w LG panels, AHE are a small family company and have been here a long time which to me is important, especially when I had some serious problems with the previous ABB Trio Inverter, normally a reliable unit. I got the original recommendation from Whirlpool. They are a LG dealer but this time talked me out of the LG's onto the Trina as they are having a lot of success with them, and they are cheaper. Upgraded my Inverter to a 15Kw Fronius with Energy Management unit thrown in ... I wanted a design that would give me 4-5Kw capacity for batteries over what I needed to run the house, that is when the payback on batteries becomes effective. The system peaks over 15Kw and i have the panels installed North and West. What I didn't expect is that with the cloudy days and rainy days we have been having I am still getting a reasonable feed to run the house. More is better. Over the last 2 months on average I have generated 2000 Kw per month and are consuming 40%. I have imported on average 750 Kw and exported 1250Kw to the grid per month. I was originally going to put a separate 6Kw system on making a total of 12Kw but the extra panels added very little cost and the new Inverter takes 2 strings, so I use the 2 panel arrays as a feed, and it came with a real time monitoring unit, installed between everything that has good online statistics that has really assisted me in understanding our energy consumption. I expect at a point my next vehicle will be electric, my oldest son partner has a Telsa 3 that is charged here on average once a week, during daylight hours 🙂. It can take anything from 25 to 50 Kw depending on usage and the system is managing that easily during daylight hours. Edited November 24, 2020 by Rosco8 1 Link to post Share on other sites
PKay 2,180 Posted November 24, 2020 Author Share Posted November 24, 2020 28 minutes ago, Rosco8 said: I have put 3 systems in with AHE in Sydney, 3 months ago added a 10Kw Trina Honey Mono (28x370w panels) to my existing 6Kw system 18 x 300w LG panels, AHE are a small family company and have been here a long time which to me is important, especially when I had some serious problems with the previous ABB Trio Inverter, normally a reliable unit. I got the original recommendation from Whirlpool. They are a LG dealer but this time talked me out of the LG's onto the Trina as they are having a lot of success with them, and they are cheaper. Upgraded my Inverter to a 15Kw Fronius with Energy Management unit thrown in ... I wanted a design that would give me 4-5Kw capacity for batteries over what I needed to run the house, that is when the payback on batteries becomes effective. The system peaks over 15Kw and i have the panels installed North and West. What I didn't expect is that with the cloudy days and rainy days we have been having I am still getting a reasonable feed to run the house. More is better. Over the last 2 months on average I have generated 2000 Kw per month and are consuming 40%. I have imported on average 750 Kw and exported 1250Kw to the grid per month. I was originally going to put a separate 6Kw system on making a total of 12Kw but the extra panels added very little cost and the new Inverter takes 2 strings, so I use the 2 panel arrays as a feed, and it came with a real time monitoring unit, installed between everything that has good online statistics that has really assisted me in understanding our energy consumption. I expect at a point my next vehicle will be electric, my oldest son partner has a Telsa 3 that is charged here on average once a week, during daylight hours 🙂. It can take anything from 25 to 50 Kw depending on usage and the system is managing that easily during daylight hours. Thanks Rosco8 after much deliberation and some very helpful advice from @rmpfyfI have decided to go with SolarEdge and the new LG Mono X plus panels made in China at a substantial discount to the Korean panels. Like you I’m going for a smaller company called MPV. The panels are waiting to clear customs and my instal date is Dec 9. I will post how the process goes and a bit more detail later on. 1 Link to post Share on other sites
progladyte 3,534 Posted December 14, 2020 Share Posted December 14, 2020 Any update on your installation @PKay Link to post Share on other sites
PKay 2,180 Posted December 14, 2020 Author Share Posted December 14, 2020 My system went in on Wednesday and the team were great, which was what I had expected after all the research and quotes. The team at MPV had a difficult installation with airconditioning ducting taking up both ceiling and underfloor space (we have separate systems for the old part of the house and the renovation). In addition to that most of our roof space is split by two rooms. They hard wired the consumption meter to the modem (no wifi here) which is in a very difficult spot in the house. Everything is working well even with some very overcast weather in Sydney. I love the SolarEdge App http://www.mpvsolar.com.au/ 2 Link to post Share on other sites
progladyte 3,534 Posted December 14, 2020 Share Posted December 14, 2020 Thanks for the info! I am looking at getting a few quotes from some of the local companies on the Sunshine Coast so don't expect I can use MPV. Hope your system does what you want. Cheers Prog Link to post Share on other sites
MrBurns84 439 Posted December 29, 2020 Share Posted December 29, 2020 Great readup! I recently moved and the power bill over the last 2 months scared me, just pipping over $250. Neighbour just recently installed 25 panel 6.6kw system and this has given me some though about doing the same to. Its a new ballgame now since i last had solar in my old place - 3.5kw 14 panel system. I'm in melb so if anyone has any recommended installers, pls pm me . Link to post Share on other sites
progladyte 3,534 Posted December 29, 2020 Share Posted December 29, 2020 1 hour ago, MrBurns84 said: Great readup! I recently moved and the power bill over the last 2 months scared me, just pipping over $250. Neighbour just recently installed 25 panel 6.6kw system and this has given me some though about doing the same to. Its a new ballgame now since i last had solar in my old place - 3.5kw 14 panel system. I'm in melb so if anyone has any recommended installers, pls pm me . @MrBurns84 I used this site to obtain some preliminary information and to enable me to familiarize myself with some of the latest trends / opinions. https://www.solarquotes.com.au/ Firstly, the content created by the owner, Finn, is first class. No bullshit, all honest and open opinions and very up to date. Once you have learned more about solar you can dive in the deep end and obtain 3 obligation free quotes from local operators. If you have thought about using some company and don't know about their reputation, they may well be listed on www.solarquotes.com You may recall a while ago there were some rather dodgy operators offering very cheap prices on solar. Some of them are still going, some went bust and re-opened under another name but very few of them will be hosted on Finn's site despite their continual pleas to be included. He does not want anyone having a bad experience using his site and makes regular recommendations to avoid the cheapest end of town. I reas a number of reviews from the likes of these guys and was gobsmacked at how often they had shafted their customers. Euro Solar True Value Solar Arise Solar Sunboost Plus any company that advertises heavily on TV. I'm not suggesting that using any of these companies will lead to grief but from the heaps of negative reviews hosted on the site, it seems that many people have. My suggestions: Use the site before you ring anybody and explore thoroughly. Use a smaller family owned local company that only uses their own employees. (Most of the problems arise when outside contractors turn up and do a poor job. There is little accountability after that. If you are seriously limited by your budget, then look for a company that sells products with at least a 10 product warranty (apart from a 25 year performance warranty - they are not the same) Once you have agreed on a price, don't accept substitute products, (due to delivery issues etc, as these guys will be offloading lesser quality products = more profit for them) Although I am loathe to use Chinese products after our fallout with the CCP, they still produce good solar materials. Use the site to determine which ones to go with. I am looking at: LG panels with a 15 year product warranty Either Fronius / Sungrow or Solaredge inverter I expect to pay about $7K to $8.5K for an 8kw system that should give me some credits for most of the year. My current bill is between $450 to $ 600 a quarter so I should be able to save about $1800 to $2K a year which gives me a 4 year amortization period. Batteries are way to dear at the moment and if you factor in a $12K-$16K battery, your amortization period will be about 20+ years. With only 10 year warranties on these things, it doesn't make sense. Get a system that can accept a battery later when prices have come down (a lot). I obtained 3 excellent quotes from 3 excellent operators and after reading reviews about them on the site I would have no qualms about using any of them. There are other sites that offer similar quoting opportunities but this guy is miles ahead of the pack. Use him and be amazed at how seamless it can become. Keep us updated. Cheers Prog Link to post Share on other sites
rmpfyf 1,817 Posted December 30, 2020 Share Posted December 30, 2020 @PKay I'm glad to hear it worked out! That's awesome dude. @progladyte you have one particularly good installer for LG in your region that's worth checking out. I wouldn't worry too much about Solarquotes - not that Finn's data isn't good, though if you're on the LG/Fronius bandwagon you're doing fine already. SolarEdge also good though you have to need it to justify it. Wouldn't suggest batteries are as you suggest for price (the world thankfully isn't Tesla) there are other things to do first. There's cheaper and arguably better stuff out there depending what you need (disclaimer: I'm involved in one of the companies in this space, and have worked for and with a bunch of them) and there's other merits for batteries than simple payback. Unless you had a three phase system then there's no cost-effective perspective to get a Powerwall unless you specifically want one. I've just put in my second (phase) system - up to 17.6kW PV, all LG, Fronius inverters, CET management (on water and car, HVAC to come) and tank. Pulled a 125kWh generation day not too long ago, not unhappy with it either. Link to post Share on other sites
MrBurns84 439 Posted December 30, 2020 Share Posted December 30, 2020 On 29/12/2020 at 3:41 PM, progladyte said: @MrBurns84 I used this site to obtain some preliminary information and to enable me to familiarize myself with some of the latest trends / opinions. https://www.solarquotes.com.au/ Firstly, the content created by the owner, Finn, is first class. No bullshit, all honest and open opinions and very up to date. Once you have learned more about solar you can dive in the deep end and obtain 3 obligation free quotes from local operators. If you have thought about using some company and don't know about their reputation, they may well be listed on www.solarquotes.com You may recall a while ago there were some rather dodgy operators offering very cheap prices on solar. Some of them are still going, some went bust and re-opened under another name but very few of them will be hosted on Finn's site despite their continual pleas to be included. He does not want anyone having a bad experience using his site and makes regular recommendations to avoid the cheapest end of town. I reas a number of reviews from the likes of these guys and was gobsmacked at how often they had shafted their customers. Euro Solar True Value Solar Arise Solar Sunboost Plus any company that advertises heavily on TV. I'm not suggesting that using any of these companies will lead to grief but from the heaps of negative reviews hosted on the site, it seems that many people have. My suggestions: Use the site before you ring anybody and explore thoroughly. Use a smaller family owned local company that only uses their own employees. (Most of the problems arise when outside contractors turn up and do a poor job. There is little accountability after that. If you are seriously limited by your budget, then look for a company that sells products with at least a 10 product warranty (apart from a 25 year performance warranty - they are not the same) Once you have agreed on a price, don't accept substitute products, (due to delivery issues etc, as these guys will be offloading lesser quality products = more profit for them) Although I am loathe to use Chinese products after our fallout with the CCP, they still produce good solar materials. Use the site to determine which ones to go with. I am looking at: LG panels with a 15 year product warranty Either Fronius / Sungrow or Solaredge inverter I expect to pay about $7K to $8.5K for an 8kw system that should give me some credits for most of the year. My current bill is between $450 to $ 600 a quarter so I should be able to save about $1800 to $2K a year which gives me a 4 year amortization period. Batteries are way to dear at the moment and if you factor in a $12K-$16K battery, your amortization period will be about 20+ years. With only 10 year warranties on these things, it doesn't make sense. Get a system that can accept a battery later when prices have come down (a lot). I obtained 3 excellent quotes from 3 excellent operators and after reading reviews about them on the site I would have no qualms about using any of them. There are other sites that offer similar quoting opportunities but this guy is miles ahead of the pack. Use him and be amazed at how seamless it can become. Keep us updated. Cheers Prog @progladyte Many thanks Sir! this has been a wealth of info for me to start off. I have been watching Mr Peacocks youtube vids on solar, and that has been very informative. Yes, there's too many shysters around. Recently an electrician who was doing a light globe swap over to led's did as part of the vic govt green energy program, visited my place. He tried to sell me a solar system and bagged the next door neighbor's install. He couldnt change over all the globes as there were some of the outdoor lamp cover was a bit too tight for his screwdriver... so i asked just use your impact drill to loosen it. He said that he 'forgot' his toolset.. lol. Dont think i'd be getting him for a quote.. Will post my experience when i do pull the plug on it. Link to post Share on other sites
MrBurns84 439 Posted December 30, 2020 Share Posted December 30, 2020 3 hours ago, rmpfyf said: I've just put in my second (phase) system - up to 17.6kW PV, all LG, Fronius inverters, CET management (on water and car, HVAC to come) and tank. Pulled a 125kWh generation day not too long ago, not unhappy with it either. OMG! ☺️ thats insane Link to post Share on other sites
rmpfyf 1,817 Posted December 30, 2020 Share Posted December 30, 2020 37 minutes ago, MrBurns84 said: OMG! ☺️ thats insane Was out all day and setting up a few things; usually would self-consume a good bit more. Still... decent day 2 Link to post Share on other sites
PKay 2,180 Posted December 30, 2020 Author Share Posted December 30, 2020 15 hours ago, rmpfyf said: Was out all day and setting up a few things; usually would self-consume a good bit more. Still... decent day That is a serious amount of generation for a home. Link to post Share on other sites
rmpfyf 1,817 Posted December 31, 2020 Share Posted December 31, 2020 (edited) 3 hours ago, PKay said: That is a serious amount of generation for a home. Its a slow consumption day. There's usually a good bit more, panel orientations are set relative to thermal demand. I'm wired for a third phase and have the space for another 10kW.... Edited December 31, 2020 by rmpfyf 1 Link to post Share on other sites
