cabel Posted September 1, 2020 Share Posted September 1, 2020 (edited) Hi, I just picked up some second hand krix neuphonics and epicentrix and one of the speaker plugs doesnt have the hole for a banana plug? Is it meant to be like this, was it just not drilled out? Edited September 1, 2020 by cabel Link to comment Share on other sites More sharing options...
BATMAQN Posted September 1, 2020 Share Posted September 1, 2020 Shouldn't be deliberate just a factory flaw I'd guess, the previous owner probably didn't bother doing anything about it and either used spades or the top plugs alone. Might be a replacement at some point and it's only meant for spades? unlikely. You should be able to drill it out but it might corrode. Link to comment Share on other sites More sharing options...
Krix Loudspeakers Posted September 2, 2020 Share Posted September 2, 2020 Hi @cabel, That's definitely an anomaly! Could I trouble you for the serial number please? If you'd like to use banana plugs I'm happy to send out a replacement terminal plate to switch out. If you'd like to do this, just PM your phone/delivery address and I'll get it organised. Cheers, Michael 16 Link to comment Share on other sites More sharing options...
Eggmeister Posted September 2, 2020 Share Posted September 2, 2020 Pretty good when krix chimes in to help 3 Link to comment Share on other sites More sharing options...
cabel Posted September 2, 2020 Author Share Posted September 2, 2020 Excellent, thanks for the quick reply all and for jumping in Krix PM'd my details, not sure if it is worth changing, I can just use a direct connection. Good to know It is not something weird I was not aware of. Link to comment Share on other sites More sharing options...
xCombatWombatx Posted September 6, 2020 Share Posted September 6, 2020 @Krix Loudspeakers fantastic response, first rate service! 1 Link to comment Share on other sites More sharing options...
