An inexpensive integrated amplifier with decent output capacity
Guys, I would appreciate the help of an experienced audiophile, since I am a layman on the subject.
I am looking for an inexpensive integrated amplifier to power my pair TA-Oscar Duas Vias 8 Inch Kevlar tower speakers from Tropic Audio (https://www.tropicaudio.com.br/torre-ta-oscar-duas-vias-8 -pol-kevlar-olive-green) and a Sony Subwoofer SA-WP16 (I intend to substitute it, soon).
I found this Marantz PM6006 (https://htclick.com.br/produto/amplificador-integrado-marantz-pm6006/), but I am intrigued by the low power capacity of these integrated amplifiers.
This PM6006, for example, delivers only 45 watts per channel (remember that my tower speakers accept up to 150 watts, as I told in the link above).
I add that my current receiver (Pionner VSX 534) delivers, according to its manual, 80 watts per channel, under the same conditions as this Marantz (with 8 ohm speakers, 20-20,000 Hz; total harmonic distortion of no more than 0.08% ), almost twice the power of this Marantz.
I am afraid to buy this Marantz and regret it because of this low power capacity, since with my current receiver I sometimes get close to the maximum volume level, in an environment of 10.5 square meters.
It should be noted that this integrated amplifier that I am looking for is for another environment, of 15 square meters, that I am setting up.
What is your budget for this inexpensive amp? and what are the dimensions of the room
Edited by wen
reading the specifications on your speakers, it says they are 93db/w/m and
8 ohms which make them fairly efficient, 45watts in a 15 sq room would be loud, unless you listened at disco levels. the 150w you quote is their maximum input. Ihave speakers that are 91db/w/m in a 16 sq m room with an 8 watt per channel valve amp, if i turn it up to half on the volume dial, you cant hear yourself talk, mine have a rating max of 120 watts. Usual advice to everybody, audition with your other gear, let your ears be the judge, good luck
You can't go comparing the stats on an integrated amp and an AVR without comparing them in context.
The Pioneer states 150 watts into 6 ohms yes, but only while driving one channel and at 10% total harmonic distortion.  At 10% THD you wouldn't be able to stay in the room.  That's a "screamingitstitsoff" rating and has very little meaning when comparing it to an amp specifically meant for music.
The marantz is indeed a 45 watts into 8 ohms (so about 55 into 6 if you are after a direct comparison) but at 0.0008% THD.  Even dialed back into its comfort zone the Pioneer would likely measure between 0.1 and 0.05% THD at best.  The Marantz is meant for music, the Pioneer is meant for movies.
With 93db sensitivity speakers I suspect even a 10 watt amp would give you quite a nice listening experience (maybe not for death metal or orchestral music at concert level volumes, but anything less than that it should do just fine).
The Marantz should do the job without a problem, although I would recommend shopping around and demoing other amps as the PM6006 is far from the only choice at it's price point and the Pioneer and Marantz house sounds are quite different.
Edit:  Sorry, I just re-read your post and noted the manual specs for the Pioneer.  I am guessing you listen quite loud.  Maybe the Marantz will run out of juice at that level but I still doubt it.  I will re-iterate though, demo if you can and don't buy if you aren't sure.
Edited by Cafad
Hi @remomoreira,
It is good to hear about Brazilian manufacturers, that are rare for speakers!
I agree with most of the comments: you don't need high power, as you speakers have high sensitivity, meaning they will play louder for the same power input (dB per watt). But don't think a multichannel receiver can play stereo anywhere close to an integrated amp (or a stereo receiver), at similar price. There are a lot more than only power and THD, like channel separation, peak current limit, rise time, dedicate DAC, etc. I recon you will notice a good improvement with this change, especially if you include a good DAC (inside or separate from the amp).
I like the Marantz, but If you live in Fortaleza, there are some other good options at similar prices, like the Rotel A-10, Rotel R-12 (good DAC included),  Yamaha A-S700 and the AAT PM-2 (acho que 100% brasileiro).
Good Luck!
@remomoreira Personally I rekon the Marantz will blow the sox off the Pioneer. In loudness, theres not much difference between an 80 watt and a 45 watt amp especially if the 80 watter is a cheap A/V receiver. Get the Marantz if its a good price.
https://www.videopro.com.au/p-12752-pioneer-vsx-534-51ch-av-receiver.aspx Nope.
Edited by Wimbo
Audition a few integrated amps. Listen to what you enjoy the sound of.
The PM6006 can drive 89dB floor standing speakers in a 21m^2 room to a point where hearing protection is needed. That power figure is sufficient for a lot of spaces. Speaking from experience.
On 27/08/2020 at 2:03 AM, Luciano Milioli said:
Hi @remomoreira,
Good Luck!
Thanks dear Luciano! :)
Thanks! :)
1000 US dollars, and 15 square meters.
You might find PM8005 for that money.
So long as you don't need a DAC or lots of facilities and just want a great sounding amp, I would personally buy newest model the Rega Brio.
Far more musical than the Yamaha and has a really nice MM phono stage if you are( or plan to be ) using vinyl.
  • Moderators
What can you demo with your speakers where you are.... I’d explore  options
as far as power goes clean and capable drive most things explore musical fidelity All amps are conservatively rated with power supplies to support honest claims - unlike avrs
In the musical fidelity range,
a3.5 150wpc
a5 200wpc
or any m5 or m6 that are later releases
Ive used a marantz 6005 with small dynaudio bookshelves.
It goes very loud with the volume no where near half the way. Next house would hear it.
  • 1 month later...
Agreed.  (Presuming it clips nicely - if it doesn;t you need another 15db of headroom for my taste in music)
If the 93db are marketing spin and/or the impedance is all over the place, then you might need more grunt.
I have used the Marantz PM6006 with Elac UniFi UB5 speakers which are 85db@4 ohms. They can drive them to decently loud levels so your speakers will never complain about the need for more power. However what is also important is system synergy. Marantz is a warm relaxed amp. If your speaker is also very relaxed then it probably won’t be engaging. So keep that in account when you consider an amp. Cheers.
22 hours ago, thoglette said:
Agreed.  (Presuming it clips nicely - if it doesn't you need another 15db of headroom for my taste in music)
Which means how many watts are needed, above 10?
Will need (not 'might '!).  xD
    • By DecoMoose
      Item: Yamaha R-N803D
      Price Range: 850-950 ish?
      Item Condition: New or Used (preferably used, ex-Demo is fine)
      Extra Info: I'm starting out into the land of decent speakers. I have Buchardt S400 in smoked oak arriving at the end of September 2019 and it would be good to have a decent integrated stereo amplifier to power them. Open to suggestions if you have something you think will be suitable? The Buchardts are 4 ohms and if possible it'd be good to have 100+ watts to get the most out of them.
    • By lgcommacomma
      Item: Naim Supernait 2 (Integrated Amplifer)
      Price: $4,400 (naturally will donate some to SNA)
      Item Condition: 9/10 (only a 9 as second-hand, in immaculate condition)
      Reason for selling: Changed to active speakers so no longer require
      Shipping: Pickup or delivery Australia-wide
      Payment Method: Cash, Bank Deposit or PayPal (fees at buyer's expense)
      This amplifier probably doesn't need an introduction, I'm sure you are all familiar with the product.
      Top of the integrated range for Naim.
      Purchased from Melbourne Hi-Fi in January 2016.
      Only selling as just moved to a smaller house and have switched to active speakers (amongst other changes) to reduce the number of components in my system...happy wife, happy life as they say.
      I have all of the original packaging so more than happy to courier interstate at buyer's expense.
      Feel free to check out the following links for more detail or just Google, there is plenty online about this awesome product.
      https://www.naimaudio.com/product/supernait-2
      https://www.melbournehifi.com.au/products/naim-supernait-integrated-amplifier
      https://www.whathifi.com/naim/supernait-2/review
      Please PM for more photos, I was having issues uploading.
