audiome 164 Posted August 24, 2020 Share Posted August 24, 2020 hi guys, recently I got a SOTM sms200. I use Audirvana and apparently audirvana sees my sotm but no sound going to my sound system. I made DLNA active in SOTM and it detected my dac. Is there anything else I am missing? Link to post Share on other sites
Steffen 979 Posted August 25, 2020 Share Posted August 25, 2020 When Audirvana finds the device, does it automatically discover the correct capabilities (bitrates, formats)? When you select the sms200 as output device and play a track, does Audirvana think it’s playing? What bitrate is it sending? Link to post Share on other sites
audiome 164 Posted August 25, 2020 Author Share Posted August 25, 2020 5 minutes ago, Steffen said: When Audirvana finds the device, does it automatically discover the correct capabilities (bitrates, formats)? When you select the sms200 as output device and play a track, does Audirvana think it’s playing? What bitrate is it sending? i didnt really check but i hope so. I also tried roon and apparently it isn't working too. It skipped every songs i choose Link to post Share on other sites
Snoopy8 3,563 Posted August 31, 2020 Share Posted August 31, 2020 Have you checked whether the SMS-200 is working by itself? E.g. use MPD to play music from a USB stick. If there is a problem, then suggest updating the firmware within Eunhasu. You can also update using this procedure http://docs.sotm-audio.com/doku.php?id=en:eunhasu:burn_sdcard_image It is often faster and more reliable than an online update. Link to post Share on other sites
audiome 164 Posted September 1, 2020 Author Share Posted September 1, 2020 1 hour ago, Snoopy8 said: Have you checked whether the SMS-200 is working by itself? E.g. use MPD to play music from a USB stick. If there is a problem, then suggest updating the firmware within Eunhasu. You can also update using this procedure http://docs.sotm-audio.com/doku.php?id=en:eunhasu:burn_sdcard_image It is often faster and more reliable than an online update. it is all good now. SOTM manufacturer's support is really good. All sorted 1 Link to post Share on other sites
