Rheme
SOLD: FS: JDS Labs cMoyBB v2.03
Item Condition: Good
Shipping Options: Shipping is available at agreed cost.
Suburb or Town: Mascot
State: New South Wales
Payment Method: Cash, PayPal, EFT
Reason for selling: Moving out
Further information:
Buyer pay shipping (not worth it)
Quick sale, moving out in a week
Will even include 2x 9v batteries for pickup
    • By hipnhop
      Item Condition: Used in good condition Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Ascot Vale State: Victoria Payment Method: Paypal, EFT or cash on pickup Reason for selling: Downsize Price reduced from $345 > $295
      Fatman Tube Amp in great condition just a little dusty as it been sitting in the corner since I've replaced most of my speakers to Sonos.
      Great tube amp with output to speakers. Fatman is a UK audio company.
      Fatman stats:
      Power Output 13Wx2 Frequency Response 20Hz – 20KHz (±1.5dB) Harmonic Distortion 0.5% Signal-To-Noise Ratio 86dB Input Impedance 100K Output Impedance 4ohm, 8ohm Valve Type 2 x 6N1(ECC85) 1 x 6E2(EM87) Power Supply AC100~120V/50~60Hz AC220~240V/50~60Hz Dimensions (l-w-h): Amp: 10.2" x 5.7" x 5.1", Dock: 6.1" x 5.1" x 4.8" Weight: 9.5 lbs
      PLEASE READ
    • By Ednnf
      Item Condition: Used. As new conditions Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Kangaroo Point 4169, QLD State: Queensland Payment Method: PayPal, EFT, Cash on Pickup Reason for selling: Upgrade. No longer needed Further information:
      This unit was purchased in March, perfect conditions. Comes with original packaging and accessories (remote etc.). Upgrading to Naim system hence selling this unit.
      Local pick up is preferred, can post on buyer’s expense.
      PLEASE READ
    • By Christopher L. Handlebars
      I'm having some trouble with my Yamaha DSP A1 amplifier. It sounds like the right channel is giving a weak or sub-par performance. It's relatively subtle, but seeing as my wife agrees with me it must be true.
      It sounds as if one of the two mid-range speakers might not be operating, like that side is lacking something.
      Also, occasionally after turning the system on there will be zero sound coming from the right. After turning off and on this usually resolves itself.
      However, I've recently started using the amp's headphone socket, and have noticed that if I plug and unplug from the headphone socket a few times this can lead to the sound returning to the right channel.
      This leads me to believe there is something amiss to do with this part of the amp.
      However, even after regaining sound from the right speaker it sounds slightly weaker, lacking in clarity, as if one of the right tower's speakers is not working.
      I am an utter novice, so please forgive me.
      I've switched cables and attached speakers to the opposite outputs. When attached to opposite outputs the issue follows to the left channel.
      Any help would be much appreciated, and if there's anywhere else I should ask this question please let me know.
    • By ikwong
      Item Condition: Mint Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Adelaide State: South Australia Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: Need funds for first home Further information:
      The Rotel RB-1582 MKII amp (RRP $2799) is in perfect working condition and is pristine in appearance.  The unit was purchased from a local dealer in late 2018. My job roles changed since the purchase and I barely have time with my gears since.
      The unit is extremely well taken care of and was covered with cloth while not in use (I tend to be away from home for weeks!).
      The amp is barely used for 120 hrs in total. So, make sure you allow more burn-in time.
      I have all the original boxes, manuals etc.
      Note: Priority will be given to the buyer of both the Rotel RB-1582 MKII amp AND Rotel RC-1572 preamp (see another ad). Further discounts will be given if buyer purchases both units.
      Details:
      Rotel’s largest stereo amplifier at 200 watts per channel provides the massive current to drive the very largest hi-fi systems effortlessly. And like its smaller brother, the RB-1582 MKII has been designed to excel at resolving the subtle details in music as well as supplying the brawn required for extremely dynamic passages. It is able to achieve this difficult dual requirement because of the meticulous attention paid to circuit design and parts selection.
      The RB-1582 MKII ‘s high-end performance begins with an extremely large toroidal transformer combined with a total of 60,000uF storage capacity in special “slit foil” capacitors to provide completely stable power to the output stage. Slit foil capacitors have the ability to charge and discharge extremely quickly, thereby ensuring signal fidelity during orchestral crescendos or repetitive kick-drum impacts, for example. Both left and right channel construction are laid out in a mono block design (after the toroidal transformer) and all grounding is terminated in a star pattern on a copper grounding plate to ensure low signal to noise. The output stage is a discrete design that consists of 10 high current bipolar transistors per channel. Input options consist of both balanced XLR and unbalanced RCA connectors.
      The RB-1582 stereo power amplifier is yet another outstanding example of Rotel’s Balanced Design Concept and will form the heart of a very impressive stereo or home theater system for years to come.
      Specifications:
      Power Configurations: 2 x 200 watts (20Hz-20kHz, <0.03%, 8 Ohms)
      Watts/Channel: 200 watts, all channels driven, 8 ohm load, 20-20kHz
      THD (20-20,000Hz) 8 Ohms, all channels driven: < 0.03%
      IM Distortion: < 0.03%
      Damping Factor (8 Ohms): 1000
      Input Sensitivity / Impedance: 1.5V / 32kOhms
      Frequency Response (+/-1dB): 15-100kHz (+/-1dB)
      S/N Ratio (IHF A): 116dB
      Power Consumption: 550 watts
      Dimensions (W x H x D): 431 x 140 x 406 mm
      Front Panel Height: 3U (5.25”)
      Shipping Weight: 18.5 Kg
      Finish: Silver
    • By jchoi
      Item Condition: Used (Near Brand New) Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Epping State: New South Wales Payment Method: EFT, Cash on Pickup Reason for selling: Need funds Further information:
      Near new Topping DX7 Pro DAC Amp in Black. Purchased in March 2020, working in perfect condition with all accessories.
      See http://www.tpdz.net/productinfo/398244.html for official specs and information
