I recently replaced the Behringer DEQ2496 EQ & DCX2496 crossover, driving my homebuilt hybrid electrostats & Ripole subs, with a DBX Driverack Venu 360 crossover/EQ.  I opted for the Venu 360 over the less expensive PA2, only because I needed the Venu's digital inputs to accept the digital out from my Logitech Transporter.
This will not be an in-depth, dispassionate, or measurement based review. I still have a lot to learn about the Venu 360, and the Behringers are all I know to compare it to. Below are my initial impressions:
Behringers have a less than stellar rep among audiophiles but they served me well for many years, and I found them to be dead quiet and crystal clear.  The DBX specs a little better but I rate them equally for inaudible noise floor.
The DBX’s wireless remote user interface is hands-down better than the Behringers’ front-panel intefaces. To be fair; the Behringer crossover does have a computer interface, but I couldn’t use it because its outdated serial port won’t connect to my laptop, or any laptop newer than 10 years old.
With the DBX, all functions are wirelessly controllable using a laptop/tablet app, and I use my Ipad for this.   The wizards make setup easy, and the control screens are intuitive and easy to use.
The Behringer’s auto-EQ is comparatively tedious, slow and cumbersome, with pink noise to endure-- downright primitive compared to the slick DBX auto-EQ.
The DBX auto-EQ is easy and fast. There’s no loud, obnoxious pink noise-- just a few rapid (2-second) frequency sweeps from (3) mic positions, and the unit instantly overlays about eight parametric EQ’s to smooth out the nasties. The resulting sound is balanced and wonderful right off the bat.
As we know; whenever you experiment and change crossover points or filter slopes, you must then re-EQ the system. With the DBX, I find it much easier to experiment and fine tune the crossover because the auto-EQ is so fast that I don’t mind re-doing it. This is a real time saver for fine tuning the system.
Whereas the Behringer DCX2496 can automatically time-align the speaker drivers, the Venu 360 has only manually adjustable time-delays, which I used to time-align the drivers the old-school way-- by playing a test tone at the crossover frequency and adjusting the delay until I found the constructive interference peak on the RTA (actually; I inverted the speaker phasing and adjusted the delay to find the negative/destructive interference dip -- either method works, but I prefer inverted phase).
After time-aligning the drivers, and having the DBX auto-EQ the system, I played an old Supremes song, and I could hear the studio reverb applied to the voices in the recording.   Just for fun, I turned off the time-delays and I could no longer discern the studio reverb and Diana Ross's voice became one-dimensional.   But when I turned the delays back on, Ross’s voice came back to life—the difference was amazing, and attests to the effect of even a small (0.33ms) phasing error.
And then I discovered the sub harmonic synthesizer and … WOW!   This feature should be used judiciously—probably not at all on modern recordings, but it miraculously enhances the bass on older recordings where the bass was anemic.
LOVE this DBX Venu 360!
Edited by jazzman53
  • Like 3
Interesting review thanks.
I believe Roger Sanders has moved to the Venu for his speakers do you you are in good company ?
One question I had was the DCX2496 can do some sort of dynamic eq - that is the EQ can be set to be volume dependant. Do you know if the Venu has a similar feature?
Good to hear from another experienced DBX crossover user, and nice write-up. :thumb: I have a couple of DBX - DRPA units which allows me to create up to a 6 way active loudspeaker. I find the DBX unit intuitive, easy and flexible to use and once dialled in correctly - quite transparent sounding. Passive crossovers do sound better (more pure) using high quality parts Mundorf, Duelund caps etc, but can take years to perfect! Whereas active xos like the DBX can pretty much produce decent sound from a DIY speaker at the get go.
Steve
Edited by Steve M
Btw, one tip I learned is that the DBX units like to be driven hard to get good sound. You set the amplifier gain interface to a level that gets those digital VU meters on the DBX dancing up to almost the red clipping zone. In my case I use multiple integrated amplifiers and set the volume controls low - everything starts to sounds truer and more transparent this way.
Also, does the Venu model still have the annoying (and sometimes destructive) thump at shut down, that the older models have?
Edited by Steve M
1 hour ago, Steve M said:
Btw, one tip I learned is that the DBX units like to be driven hard to get good sound. You set the amplifier gain interface to a level that gets those digital VU meters on the DBX dancing up to almost the red zone - then everything starts to sounds truer and more transparent.
I don't know whether the DBX would have a shutdown thump because I always shut the amps off first.   And at startup; I always turn on the Logitech streamer and Venu 360 first.
Edited by jazzman53
I'm not yet sure if the DBX can do that, but it does have dynamic limiters.
Steve
Guest gnnett
So the PA2 has the same functionality as the Venu 360, apart from no digital input?
I will have a thorough read of specs, just the saving is significant for a first time venture into this area.
I am looking to use it as a means of "measuring" the effects of changes in passive tuning components (resistor values in an ESL segmentation network), from an established baseline using the DBX Auto EQ and then a Ripole sub support. I have a modest but pleasant sounding DAC and primary source will be analog.
Kind Regards
Grant
Kind Regards
Grant
HI Grant,
Two friends who I built ESLs for are using the Driverack PA2.  I'm still learning all the features but I'm pretty sure that everything you would use in a home stereo application (crossovers, EQ's, limiters, time-delays, etc.. ) are identical in the PA2 and Venu 360.
Both have six output channels.  And aside from the extra/digital inputs on the Venu 360, the other differences apply to PA applications where you might need to daisy chain components.  For example; the Venu has three separate input processing chains (versus one in the PA2), as well as capability to make interconnections between the chains.  I'm not a PA guy so it's all Greek to me.
Below are screen shots of the PA2 and Venu 360 remote control app home/function screens, which show the available functions:
Edited by jazzman53
1 hour ago, gnnett said:
Hi Guys
What microphones do you use? The dbx, or maybe the Behringer?
Grant
I'm using the Behringer mic because I already had it when I purchased the DBX.   BTW; the DBX setup wizard has a prompt to select either the DBX mic or non-DBX mic.
Edited by jazzman53
  • 2 months later...
Hey @jazzman53, just wondering if you could give  little more detail on this feature and describe how to use it?
Yes, the Driverack has a control module that enhances bass response.  I use in on older recordings that were not recorded with punchy/deep bass.  Here's an excerpt from the user manual:
DriveRack
PA+
Section 5
Detailed Parameters
Number Fixed - 0-12
This will range from values 0-12. The total number of filters will stay at 12, and the number
of live filters will be = Total Num Filters – Num Fixed. If this is changed before the filters
are reset, then the filters will be reset one by one as the number changes. For example, if
the number of Fixed filters goes down, then the last fixed filter set will be reset. Likewise, if
the number of Fixed filters goes up (and thus the number of live filters goes down), then the
last live filter set will be reset. The Fixed/Live filter usage will be indicated at the bottom
of each page of the feedback elimination effect. 'F' indicates an available fixed filter, and 'L'
indicates an available live filter. A blocked out F or L indicates a filter that is set, or in use.
Live Filter Lift (On/Off)
This parameter turns the Live Filter Lift on and off.
Lift After - 5 sec to 60 min
This parameter allows the user to setup the AFS module so that the Live filters will
automatically be removed or set to flat after a set time (as indicated by the "Lift After"
parameter). It ranges from 5 seconds to 60 minutes. This feature is useful if the microphone
being used is moved or the characteristics of the venue change over time. As example; a
filter placed minutes ago will not be presently preventing feedback. This feature removes
unnecessary filters from the spectrum to increase sonic quality. If the feedback is still there
(after the filter is removed), it will catch it and notch it out the same.
5.3 Subharmonic Synthesizer
The Subharmonic Synthesizer module has been specifically optimized to enhance Bass audio
material for use in a variety of professional applications, including nightclub and dance DJ
mixing, theatre and film sound, music recording, live music performance and broadcasting.
The Subharmonic Synthesizer module's two separate bands of subharmonic synthesis provide
the best combination of smoothness and control, and the independent low frequency boost
circuit is designed to get the most out of high-performance low frequency speaker systems.
Sub-Harmonic Synth - On/Off
Turns the Subharmonic Synth module on and off.
Sub-Harmonics Synth - 0 to 100%
This parameter sets the overall level of the Subharmonic Synthesizer.
24-36Hz and 36-56Hz (Subharmonic Synthesis) Level - 0 to 100%
These controls individually let you customize the amount of the respective synthesized
frequencies to be added in, tuning the ultimate bass response of your system to taste. For
example, if the sound is too woofy or growly, try turning down the 36Hz-56Hz level. If your
woofers are bottoming out (making a ticking, popping sound), try turning down the
24Hz-36Hz level. You may find that a setting produces fine results in one room, but produces
too much boominess in another. If this occurs, adjust the controls as needed, (e.g., increase
or decrease one or the other of the band levels). Experimentation will pay off with smooth,
full, deeply extended bass. Remember, you are not selecting a frequency. You are controlling
the overall level of each band.
IMPORTANT! The Subharmonic Synthesis process creates very low frequency audi
  • 2 months later...
1 hour ago, Grizaudio said:
Looks suspiciously similar. Would you risk it though?
Yes, I suspect its identical.
After conversing with the owner of the store, I believe Green Audio produce these units for DBX.
My circumstance is different to most, I have access to wholesale buys on most pro sound (and some Hifi) gear, so I would probably just buy locally for warranty.
But the saving is decent, and provokes thought.
Reading online, a few Venue users have reported reliability issues. So that needs to be considered.
So much of what we buy, is made or rebadge Chinese product. I suspect this item would be perfectly fine.
The main draw back of the DBX unit is its lack of FIR support. Not an issue for most.
A friend of mine just purchased this DSP. Which offers great value.
https://www.aliexpress.com/item/32979626577.html?srcSns=sns_Copy&spreadType=socialShare&bizType=ProductDetail&social_params=20042389915&tt=MG&aff_fsk=_mq3jE9n&aff_platform=default&sk=_mq3jE9n&aff_trace_key=5c39c225c84b498496fad47345d78f1d-1611312267821-06750-_mq3jE9n&shareId=20042389915&businessType=ProductDetail&platform=AE&terminal_id=fceddd04db9749bc8402a97ba3b8152c
You can use their software, or Sigma open architecture software to program.
3 hours ago, Grizaudio said:
I don’t see any info about it. No specs or not even a description of how you configure it
which one?
I have the software if you are interested in the second link....
I have the software, so I can see what it does.
Its basic, similar to the DBX.
I'm not endorsing the unit, as I haven't heard it yet.
6 hours ago, sir sanders zingmore said:
I guess what I’m asking about is how do you know what that unit does and how you get it to do what it can do?
How do you evaluate whether it is suitable?
I sent you a link to the included software.
Steve
