Hi Guys,
Ok, so I am using almost 20-25 year old TV cabinet which I had picked it up from street. It has been with me ever since and it is there as a reminder of my humble beginning. It has hosted my first TV purchased from Flemington markets to all the way to 60 inch 4k HDR LED TV and now has Center channel on top of it. So far, it had been doing its job just right as it also had a space for AVR in the bottom rack and a space for a bluray player.
Over the years, the system evolved and one AVR grew into Pre/Pro + Power amps, and the TV cabinet had no space for the amps. No problems, I just stuck the power amps on side on floor on top of some wooden planks stacked on top of each other and worked fine for a while. But things got interesting few weekends back. One of my friend's toddler climbed over both power amps and was reaching for some toy that was on top of one of the floor stander. Luckily both the child and power amps survived. But that got me thinking, that this will not do in a long run, as I also have a 3 year old daughter and 1 month old son and the HT room also serves as a toy room (Dangerous combination).
I started looking around for some AV racks which needed to be either short enough to host three components and centre on top or wide enough to host two components side by side as any taller and they would block the TV. Unfortunately, proper AV racks costs just as much as a power amps with their amazing quality to improve the sound and provide total isolation. Also I did not want to replace my current cabinet with sentimental value and wanted to keep it.
Alas, IKEA came to rescue.
IMG_5506.thumb.jpg.4ec918b713f523eecc8fc9f8c78319c4.jpgIMG_5507.thumb.jpg.9d76444b012a9aefa56c113b6f57d712.jpg
This thing was perfect for my needs. Just stacked the AVR and power amps in corner of the room and left the current cabinet as is with Centre channel on top. Each shelf is rated for 100kg each so no problems there and has plenty of space on sides and on top for proper ventilation. Each components are on resting on top of Whites anti-vibration pads (Bigger) + Wooden plank + Whites anti-vibration pads (smaller). All up this costs me $130 ($90 for rack, $20 for wooden plank cut in three pieces, $20 Whites anti-vibration pads). Oh! I have installed the X brace in the front, hopefully that stops kids touching it and leaves me room in the back to change around cables and stuff.
What do you guys think?
1568691392_ScreenShot2020-07-29at9_59_15am.thumb.png.bebbfbfbc4fba8cf255b23d51660d741.png
Practical and looks pretty cool, I was a bit umm...with the X brace at the front till I read your explanation :thumb:
Haha...
Yes, the X brace was supposed to go in the back, but with all the cables and stuff and my habit of changing around things, I decided to keep it in front.
2 minutes ago, JohnL said:
These are pretty good and, being bamboo, will outperform your planks.
https://www.ikea.com/au/en/p/aptitlig-butchers-block-bamboo-60233431/
A lot of happy users out there including me.
Thank you.
Yes, I am aware of these, but unfortunately the size of this block is smaller than both the amp. Only my AVR could sit on it, and since the left over cut from the wooden plank was just the right size for AVR, so I ended up using it.
Funnily enough, I am using this as a base for my DIY speaker stand which was also made using all IKEA parts.
Nice rack. Now fill it full of wool, put a cover over it and you have yourself a great bass trap ;)
Haha... and burn the rack down with the heating.
Actually, there is a sheet of CSR Martini Absorb behind that rack and speaker, it is white so not really visible and also lots of acoustic pin boards with air gap on the wall in different colour.
I love those pin boards. I have them all over my van ATM. If I ever get to do my hifi room they will definitely be part of it.
Yes, they are very effective.
I got them from some warehouse somewhere in Ingleburn, I can't even remember which company or the warehouse that was. But these are thicker than the ones available in Bunnings and came in 2.4x1.2 size. And since these are very stiff and easy to cut, all I did is screw them onto a wooden panel at top and bottom and used command strip to hang them on the wall. That way, they have an air gap which improves their efficiency and no mess, looks good with different colours.
How stable is the rack? does it wobble?
It is fairly stable, but does wobble a little when you push and pull with bit of force. Where the x-brace is that side does not wobble at all but the rest does wobble a little if pushed.
1596859209297498382156377806464.thumb.jpg.bc2369d8db9f2a511203b9e1c7ed3670.jpg15968592973112825392208510923478.thumb.jpg.132d460a6a066bf96e4e68a1d5cfd70b.jpg
    • By carono
      I wanted a cheap but sturdy rack that housed all components and my records. The IKEA Lack table hifi rack hack is quite popular and you can find various versions posted on the internet. I decided to give it a go, with a few variations of my own so that it was sturdy (and heavy) and would hold records.
      What i used:
      6 x IKEA Lack Tables  22 x wooden dowels (each approx 50mm/2 inches long) 1 x tube of PVA wood glue hard wood lengths to go inside hollow table legs
      Tools
      1 x drop saw (mitre saw) 1 x electric drill 1 x bench vice (to hold legs when drilling the holes for wooden dowels)
      Here is what i did:
      Measured height of each audio component and made a little sketch to show dimensions of finished product. I left a bit of space to allow for air circulation, with more space over my amp than other components. Cut the legs of each Lack table set to suit required height. I put gaffa tape around the leg where the cut was to be made to prevent any splintering/chipping of the white surface. A handsaw, jigsaw or circular saw will not to the job (i tried this on a test piece before remembering i had a dropsaw in the shed). I filled the hollow legs with lengths of hard, solid wood (from an old balustrade that i had dismantled a few years ago) and wedged and glued them in. They fitted quite well, but i still had to wedge and glue them in. Drill holes on the bottom of each table leg, and at each corner of the table top surface. This is for the wooden dowels that will hold each table together.  Remember not to drilll the table top of the top unit (the one your turntable sits on). Using a drill press will make sure your drilling is perfectly vertical and accurate. I didn't have a drill press, and managed ok. Make sure you measure where your holes are going to go, and use a drill bit so that the wooden dowel will fit snug.
      You can now start assembling each individual table. The lack tables come with some double screws to fit the tops of the legs to the underside of the tabletop.
      Each assembled table can now be fitted together in the order you require, with a length of wooden dowel to hold the table to the one above it. I made sure the wooden dowel was tight in the hole as i didn't want to glue them (in case i want to change the order of each unit at a later date).
      Each tables come with plastic bases. Throw most of them away, and fit four plastic bases to the legs on the lowest unit (the one on the floor)
      I used a spare bits of legs to put in the addition vertical 'leg' so that records can be held upright properly (see photo)
      I used spare bits of leg to make cable tidy that go at the back. I used a 35mm drill bit to make the holes in  the table tops and for the cables to exit the legs (see photo). [note the photo was taken during test assembly and the units aren't pushed together properly. The finished product is very neat with no gaps].
      Here are some tips:
      Measure at least twice Put a cloth around peices you hold in a vice so not to damage the white veneer Don't tighten vice to much label front and back with a pencil, so anything less than perfect gets hidden at the back Do a trial assembly before any gluing
      lack-side-table.pdf
    • By Selby Thornbury
      Item: Avico 19 inch 42U 600mm Depth Network AV Rack With Glass Door
      Price: $550 (WAS $999, RRP $1195)
      Item Condition: Qty 3 Brand New in Box
      Reason for selling: Clearance
      Extra Info: Can be viewed in person at the Hallam retail store before purchase.
      19 Inch 42U Steel Network or AV Rack.
      600mm Depth
      Includes Roller Caster Feet and Static Feet
      Glass Window on Door
      Key Lockable Door
      Removable Side Panels
      Quantity of 3 Available Brand New in Box at our Hallam Retail Store.   No shelves or accessories are included, but can be purchased separately here: www.selby.com.au   Feel free to ask for more information.
    • By Anish
      Item: Home Theatre equipment rack with glass door
      Price: $300
      Item Condition: Good
      Reason for selling: Consolidating home theatre and hifi equipment to a new rack
      Extra Info: This rack is 100cm tall, 50 cm deep and 50 cm wide. The front door is glass, which can be fitted to open from the right (current state) and the left. The middle shelf is fixed, but the top and bottom ones can be height adjusted. with holes at the back for wires. The top of the rack has a piece of thick glass sitting on four rubber washers, which can be taken off if you don't like it.
      I think it's made from MDF, and it's heavy. LOCAL PICKUP only.
      And stating the obvious, none of the equipment seen in the pictures come with the rack.
    • By lasseo
      Item: IKEA Benno CD/DVD rack, birch veneer, two of
      Price: $25 each
      Item Condition: Used but great
      Extra Info: If anybody still uses there, I have 2 x Ikea Benno CD/DVD Towers that I no longer need. Used but great condition, birch veneer finish. Each tower measures 203 cm tall by 20 cm wide by 17.5 cm deep and fits 180 CDs or 88 DVDs. Pickup from VIC 3212, could organise delivery within 30 km or so - Geelong or Melbourne western suburbs. Fridge or pot plants are not included.
    • By thathifiguy
      Item: Billy Bookcase & CD Towers Black/Brown
      Price: FREE!
      Reason for selling: Sitting in garage, unused
      Extra Info: Bought from Ikea back in 2012, replaced last year. I have been lazy trying to move them on, but if you can fit it, you can have it!
