Audio Connection
Goldmund Logos 1 Bookshelf Speakers with Logos 2 Active Sub with Stands
Item Condition: As Traded in Good Condition
Shipping Options: Pickup available and you can audition.
Suburb or Town: Leichhardt
State: New South Wales
Payment Method: Cash on Pickup, EFT
Reason for selling:
Further information:
Here is a rare opportunity to own some great technology and get some fabulous sound quality. The Goldmund Logos 1 Bookshelf Speakers are a passive speaker and can be used with a range of very good power amplifiers including Goldmund's own power amplifiers. They even feature the Goldmund coaxial speaker connector. The Logos 2 Active Subwoofers are very flexible and high performance subwoofers, they can be used with a wide variety of preamplifiers with 2 analogue outputs, processors with 2 analogue outputs and quality integrated products if they have and analogue or subwoofer output. They feature both Digital and analogue inputs, the Digital  inputs are specific to Goldmund Processors whilst the analogue inputs can be used with any quality processor or preamplifier as long as they have either a second analogue or subwoofer output.
LOGOS 1
- Fully constructed in metal with implementation of the mechanical grounding system to
evacuate vibrations.
- 7” woofer and soft dome tweeter, both selected for their high linearity and dynamics.
- Frequency response: 45Hz - 25kHz
- Efficiency: 88dB / 1W 1m
- Dimensions: 330mm (13”) H x 230mm (9”) W x 280 (11”) D
- Weight 15.5 KG (34lbs)
User
LOGOS 2 ACTIVE
Amplifier Analogue Input Impedance: > 51 kOhms.
Amplifier maximum power: 650 W Rms.
Drivers: 30cm (12”) driver and 30cm (12”) passive radiator mounted in phase.
Bandwidth:
• Low Frequency Cutoff : < 20 Hz -3dB.
• Electronic Crossover: 4th order low-pass filter with 6 separate frequencies.
Position 1 - infinity : digital
Position 2 - 150Hz : higher crossover frequencies
Position 3 - 80Hz : higher crossover frequencies
Position 4 - 55Hz : Logos HE or Mini-Logos
Position 5 - 50Hz : Logos 1
Position 6 - 35Hz : Epilogue 1
Master level control
Bass Load: Passive radiator.
Size and Weight:
• Weight of one sub-woofer : 30 kg (66lbs).
• Size of one sub-woofer : 35 cm (14”) H x 35 cm (14”) W x 35 cm (14”) D.
I've always loved the styling of these. I imagine they're not for everyone though.
Having heard them overseas too, they're very well priced here.
