GruntPuppy
Rega Planar 2 Subplatters - what have you tried?
Everything I've read so far about the Planar 2 suggests that the best first upgrade is to put a better sub-platter in.  If you've had any experience with doing this, I'd really like to know which subplatters you've used, and what your experience of the results was like - currently I'm leaning towards the Tango Spinner subplatters, but I'd like to benefit from other people's experiences where possible.
I have used the Groovetracer Reference sub-platters with a number of Rega decks. They are superb.
Damn.  I was hoping NOT to hear this, they are bloody expensive!   I do appreciate the feedback though.
Yes, it is often the way. I have heard that the Tango Spinner ones are very good too. Either would be a marked improvement over the standard offering.
Yep, the Tango Spinner ones are also firmly on my radar.  There's also a Uk company machining them out of Delrin, but I have my doubts as to the comparative accuracy of manufacture that can be achieved by machine a piece of flexible plastic as opposed to aluminium.   I do hope that someone can give me a first hand experience of the Tango Spinner subplatter,  which is a fair bit cheaper, if for no other reason than that I wanted to spend a little more on the arm upgrade - I fear that I will not be able to resist Audio Origami's RB250 modifications...
A lot of people have purchased the Tango Spinner products and are very happy with them. I am sure that you would be too.
J7 from Audio Origami is the man for tonearm upgrades, you will be happy with the result.
I put a Groovetracer reference subplatter and delrin platter on my RP1 and it made a big difference in "tightening" the sound up.
Well, hopefully my sub-platter search is over.
I'm going to give Fidelity Designs a try - this is their reference sub-platter - looks nicely machined,  aluminium with a delrin centre boss, ball-bearing grade stainless steel spindle, and a silicone locator ring.  I'm still thinking about the bearing seat upgrade, but this is getting ordered tomorrow morning, as is an Iceni  Audio 2-part platter, I just need to speak to Patrick about one last bit of customisation on this.
[edit]  It's not as pretty as some of the other candidates, but since I'm not going for a transparent acrylic platter, I'm not worried.  If I go for a transparent plinth it's still not going to be all that visible.    It is, hopefully, a cost-effective upgrade, and bang-per-buck makes sense to me with what has been an extremely cheap purchase - £85 plus post for a Planar 2?  That'll do nicely :)
If I start feeling inferior about it, I'll stick some heat-shrink on the spindle, stick it in a drill and polish it myself.
Edited by GruntPuppy
Well sod it.
I couldn't help myself, I've just started the ball rolling on the Fidelity Audio  reference sub platter and bearing upgrade kit.  Looks like superb value for money considering what's in it for £102, let's see how it goes.
I figure if I'm going to be looking at something for a few years, I may as well be looking at something good.   And it'll give me a push to sell on some of the hoard of stuff that I've got here to free up funds and make some space!
On 23/07/2020 at 6:27 PM, GruntPuppy said:
Well sod it.
Has it arrived yet, and have you tried it out?
Yes and no...
It's arrived, and I've tried the platter with teh standard bearing in place - there's a definite increase in stability, and a decrease in noise floor.  I haven't tried out the bearing upgrade yet because I'm thinking about an upgraded plinth, and I'm not a fan of fitting and removing fixed parts unless I absolutely have to.  That said, I did oil up the bearing and fit the platter to give it a spin in the hand, and it is beautifully smooth.
As a summary - although not the prettiest subplatter, it's brushed steel rather than polished it is superbly designed and engineered, and I can thoroughly recommend it.  The combination of a precision machined outer sub-platter, a delrin hub, stainless steel spindle and a silicone locator ring are superb - it's not going to be visible unless you've got a transparent platter, and even then it can hold its' head up.  The price of the reference sub-platter and bearing upgrade (and the finish and engineering on this is superb too) is cheaper than a lot of people are charging for a sub-platter alone.  I swapped a few emails with Ben Lamb, who I think is the owner and he's a good bloke to have dealings with.  He does a delrin platter for £49 that's an absolute steal.
It's a different story with the Iceni Audio platter - which arrived, looked superb - until I noticed the top face, rather than being clean polished acrylic as pictured on his website and ebay, came with "Iceni Audio ltd" machined on it - twice.  And there was lipping from the machining on part of the platter too - not what was expected, so that was returned at his cost.  I went a bit strait-jacket over that one...  I wouldn't have minded the engraving if it had been done nicely, but it just looked bloody awful.   Half-inch high letters going round in two semi-circles, in a font that didn't even match his company logo.
I've ordered a similarly styled item from Cherry Audio, so we shall see what that looks like when it turns up.   This time it's a one-piece platter with 6 underslung weights. and has a recess machined in for record labels.  I asked questions to make sure there'd be no silly surprises as well.
