Fabrice Dal-Cin Posted July 16, 2020 Share Posted July 16, 2020 Hi everyone need assistance on good quality surround sound speakers or even some bookshelf speakers, even a couple Tower Speakers @ the front but not absolutely necessary, I'm on a budget as well so keeping that in mind, if anyone can help I would appreciate it. Link to comment Share on other sites More sharing options...
Andre28 Posted July 16, 2020 Share Posted July 16, 2020 What is the budget? Are you looking for 5 speakers and a subwoofer? Do you have an amp already? Link to comment Share on other sites More sharing options...
Fabrice Dal-Cin Posted July 16, 2020 Author Share Posted July 16, 2020 Thanks for replying first up, I already have the Klipsch R-25C centre & already have the Klipsch R-10SW Subwoofer, what I need is something that'll match these, I haven't bought the Rec/Amp yet, I was thinking maybe in the quality of Marantz SR6014 or the Denon AVR-S950H or the Denon AVR-X2600H, any rec. that has the option for adding ceiling height speakers & or Dolby Atmos Height Virtualisation, whatever rec/amp. I buy will have to have all of the options that these Rec/Amps I've mentioned above has, the budget I have now is probably around $1500-2000 maybe less, cause I've already got centre & Sub, oh another thing, the Rec/Amp I buy must have the options to add more Speakers, but for now I am slowly buying good Speakers with a budget in mind, I looked at the Klipsch R-14S, R-14M, R-15M, R-24 26,28F cause according to some expert opinions they match perfectly, but if I can buy some similar I'll be a happy camper. Link to comment Share on other sites More sharing options...
