larry42 Posted July 12, 2020 Share Posted July 12, 2020 I have a Yamaha RX-V1900 in my movie room that recently seems to have stopped putting video via hdmi ( I connected my nvidia shield direct to the JVC x3 projector and it works , but not when via the amp. I have two long hdmi cables run to my projector, and one isn’t working , but the spare cable does ( when going direct to the projector ) so I looks like video output from amp, plus one hdmi cable aren’t working. any suggestions for a receiver repairer in perth? if I was to update to a newer receiver any suggestions ? I have a Sony DN 1080 in the tv room. Both rooms have 5.1 setup Link to comment Share on other sites More sharing options...
larry42 Posted July 14, 2020 Author Share Posted July 14, 2020 (edited) i contacted a local repairer but he thought it would be about $300-400 to fix..... i was thinking of trying a hdmi splitter (1 in, two out) so i can run the nvidia shield to the amp, and connect it direct to the projector at the same time. any suggestions for a good unit to try ? https://www.amazon.com.au/HDMI-Splitter-Out-Aluminum-Supports/dp/B07YZFHCLR/ref=sr_1_11?dchild=1&keywords=hdmi+splitter&qid=1594734292&sr=8-11 Edited July 14, 2020 by larry42 Link to comment Share on other sites More sharing options...
bizzibee Posted July 15, 2020 Share Posted July 15, 2020 (edited) I'd personally proberly get it fixed if it was only $300-$400. Otherwise you could buy something like that splitter you linked to: https://www.amazon.com.au/HDMI-Splitter-Out-Aluminum-Supports/dp/B07YZFHCLR/ref=sr_1_11?dchild=1&keywords=hdmi+splitter&qid=1594734292&sr=8-11 I have no experience withit but, its cheap and it may solve your issue. It certainly reads like it would solve your problem as long as you don't need something that required HDMI 2.0 & HDCP 2.2 which your Yamaha won't do anyway. Quote HDMI Splitter 1 Input 2 output Techole HDMI splitter will duplicate or "mirror" a single HDMI source on two HDMI displays. Both displays will show the same video and audio simultaneously. Powered HDMI splitters will act as a repeater to boost the digital HDMI signal and allow you to surpass the normal 100ft length limitations of the format. HDCP 1.4 Compatible This HDMI splitter could strip hdcp, enable you can record with avermedia game portable. Compatibility Supported Audio: LPCM, Dolby-AC3, DTS7.1, DSD/Dolby TrueHD/DTS-HD master audio. Video Format: Deep Color, 480i/ 576i/ 480p/ 576p/ 720p/ 1080i/ 1080p/ 1440i/ 1440p / 4K, 3D Support at 1080p@30Hz, 1080p/60Hz, 4K@30Hz max. Works with all devices fitted with an HDMI port, such as PCs, laptops, gaming consoles ,XBox 360, Xbox One, PS3, PS4, PS4 pro, Blu-Ray DVD player, Satellite Receiver, Route Roku, projectors, TV receivers , HD-Ready, Full HsD TVs, Apple TV, Samsung TV, monitors etc. 24-Month Warranty All Techole products are backed by our 24-Month Product Warranty and you will always get friendly support. Package Contents: 1x HDMI Splitter 1 input 2 output 1x Micro USB charging cable 1x User Manual 1x Warranty Card Note: 1.This active splitter amplifies and equalizes the input signal in order to perform at maximum spec without signal loss for longer runs. It means that if you are running multiple displays with different resolutions, the splitter will send the lowest "common" resolution to all displays. 2.If Your HDMI Source Device (like XBox, PS4) supports 4K, please use a HDMI cable 2.0 to connect 4K HDMI Source Device & HDMI switch & display, since HDMI cable 1.4 (or below HDMI 1.4) isn't enough to support the resolution of 4K (4096*2160). Here's some other info of this unit: https://hdmiusa.blogspot.com/2019/09/best-hdmi-splitter-1-in-2-out-techole.html 10 Best Hdmi Splitters - July 2020 https://au.bestreviews.guide/hdmi-splitters?loc_redirect=US HDFury AVRKey can Split Video and Audio, but much more expensive. See: https://www.ezyhd.com.au/shop/hdfure-avrkey-3/ More info here: https://www.hdfury.com/product/avr-key/ If you're interested in Dolby Atmos & DTS:X etc and want stay with Yamaha, you could look at a Refurb Yamaha from Excel HiFi from either on their Web Site or eBay store https://www.excelhifi.com.au/audio-visual-receivers/ http://www.ebaystores.com.au/Excel-Hi-Fi-AV-Clearance-Centre/Home-Theatre-Receivers-/_i.html?_fsub=2&_sid=41578513&_trksid=p4634.c0.m322 But there are plenty of other options from other brands available. Edited July 15, 2020 by bizzibee Link to comment Share on other sites More sharing options...
ScottR Posted July 15, 2020 Share Posted July 15, 2020 Hi Larry, another option for you - i have an RX-V3800 you can have for $375 - it was the top of the line model a year before the #900 series came out - all in perfect order. Let me know if you are interested! Link to comment Share on other sites More sharing options...
Snoopy8 Posted July 15, 2020 Share Posted July 15, 2020 20 hours ago, larry42 said: i contacted a local repairer but he thought it would be about $300-400 to fix..... Not surprised.. 4 hours ago, bizzibee said: I'd personally proberly get it fixed if it was only $300-$400. Otherwise you could buy something like that splitter you linked to: There was one on Grays on-line which listed for $369 in 2019. Spend to $300-400 to fix it does not make sense! For OP: If you are not after the latest and greatest features, then a second hand high end model like what ScottR proposed is a better way to go. But if you want new, go with what you know i.e. Yamaha and aim for at least a mid range model which should have better power. Often, there are bargains when new models come out and you still have the advantage of buying with full warranty. Link to comment Share on other sites More sharing options...
larry42 Posted July 17, 2020 Author Share Posted July 17, 2020 Hi guys, thanks for the information and suggestions. i have ordered a simple hdmi splitter, no point going too expensive or the splitter costs more than the amp. Scottr, thanks for the offer, I will have a think about it, possibly wanted a bit newer. downstairs I just run an nvidia shield to the projector, I also have a Sony DVP S700 DVD player, but I haven’t used it for a long time. So I just need an easy to use setup for the family. I’ve had a console also, but normally the one upstairs on the tv gets used 1 Link to comment Share on other sites More sharing options...
