Audio Connection
Goldmund Logos 1 Bookshelf Speakers with Logos 2 Active Sub with Stands
Item Condition: As Traded in Good Condition
Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost.
Suburb or Town: Leichhardt
State: New South Wales
Payment Method: Cash on Pickup, EFT
Reason for selling:
Further information:
Here is a rare opportunity to own some great technology and get some fabulous sound quality. The Goldmund Logos 1 Bookshelf Speakers are a passive speaker and can be used with a range of very good power amplifiers including Goldmund's own power amplifiers. They even feature the Goldmund coaxial speaker connector. The Logos 2 Active Subwoofers are very flexible and high performance subwoofers, they can be used with a wide variety of preamplifiers with 2 analogue outputs, processors with 2 analogue outputs and quality integrated products if they have and analogue or subwoofer output. They feature both Digital and analogue inputs, the Digital  inputs are specific to Goldmund Processors whilst the analogue inputs can be used with any quality processor or preamplifier as long as they have either a second analogue or subwoofer output.
LOGOS 1
- Fully constructed in metal with implementation of the mechanical grounding system to
evacuate vibrations.
- 7” woofer and soft dome tweeter, both selected for their high linearity and dynamics.
- Frequency response: 45Hz - 25kHz
- Efficiency: 88dB / 1W 1m
- Dimensions: 330mm (13”) H x 230mm (9”) W x 280 (11”) D
- Weight 15.5 KG (34lbs)
User
LOGOS 2 ACTIVE
Amplifier Analogue Input Impedance: > 51 kOhms.
Amplifier maximum power: 650 W Rms.
Drivers: 30cm (12”) driver and 30cm (12”) passive radiator mounted in phase.
Bandwidth:
• Low Frequency Cutoff : < 20 Hz -3dB.
• Electronic Crossover: 4th order low-pass filter with 6 separate frequencies.
Position 1 - infinity : digital
Position 2 - 150Hz : higher crossover frequencies
Position 3 - 80Hz : higher crossover frequencies
Position 4 - 55Hz : Logos HE or Mini-Logos
Position 5 - 50Hz : Logos 1
Position 6 - 35Hz : Epilogue 1
Master level control
Bass Load: Passive radiator.
Size and Weight:
• Weight of one sub-woofer : 30 kg (66lbs).
• Size of one sub-woofer : 35 cm (14”) H x 35 cm (14”) W x 35 cm (14”) D.
Wow.....just wow
Interesting design
That would be one very large bookshelf...
Never really thought of Goldmund using Velcro to secure their speaker grills.
I auditioned these when they were released in Australia and while the aesthetics are certainly challenging the sound is actually pretty amazing. Only issue is that you do need to use them with a dedicated Goldmund front end ie preamp with digital outputs.
hi
those units have been ordered so it can be used with non goldmund equipment
a preamp with 2 stereo outputs plus a power amp
or an integrated amp with a preamp output can also run them
I have a same thought, why there is Velcro at this level ???
hi
the possible did not want to drill holes in the aluminium speaker boxes
    • By astonmartinv8
      Item Condition: Used Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Milsons Point 2061 NSW State: New South Wales Payment Method: Paypal, EFT, Cash Reason for selling: No use for it Further information: Four lengths of 290cm of un-terminated silver plated cable with 5-stars from What Hi-Fi. Quote from their review "The jacket covering The Clearwater speaker cable has an almost jelly-like consistency, which makes the cable extremely pliable – it’s one to consider for installations. The appeal goes up a couple of notches thanks to a balanced and involving sound. There’s an impressive level of detail, dynamic clout and clarity, but this cable also allows your system’s sense of refinement and finesse to shine through. Natural-sounding vocals and plenty of layering and texture to instruments really give tracks the ability to communicate effortlessly with the listener."
    • By Nicknotes
      Item Condition: Very Good Shipping Options: Pickup available and you can audition. Suburb or Town: Winthrop State: Western Australia Payment Method: Paypal, EFT or Cash on Pickup Reason for selling: Upgraded Further information:
      These are cherry vinyl wrap speakers from a Canadian manufacturer that is now part of the Klipsch group.  The 'Omnipolar' design produces Dolby Atmos style sound, with an amazing soundstage, offering versatility for both stereo listening or as part of a home theatre setup. Rated at 93dB sensitivity @ 8 Ohms, the Omni 260's are ideal for a small to medium size room & with forward firing bass ports and the Omnipolar design are fairly forgiving in terms of placement.
      See: http://www.soundstagenetwork.com/revequip/mirage_omni260.htm for a review.
      One of the titanium sputtered domes was accidentally damaged, so the driver assembly was replaced some years ago. Although I've only ever replaced the single driver, as these are the most fragile part of the speaker, I bought 2 spare drivers and am offering these free of charge with the speakers, which also come with front outriggers and spikes.
    • By btan
      Item Condition: Good Shipping Options: Pickup available but audition is not available. Suburb or Town: Glen Waverley State: Victoria Payment Method: EFT, Cash Reason for selling: NLR Further information:
      Selling my modified Audio Note DAC 1.  It's gone through a few upgrades over the years including Black Gate caps and new power supply.
      Preference at this stage is for a local sale.  Thanks for looking.
      PLEASE READ
    • By Peter WM
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available. Suburb or Town: Sydney State: New South Wales Payment Method: Cash on Pickup Reason for selling: Upgraded to new processor Further information: Includes remote and Audyssey mic.
    • By EasterlyDrake13
      Item Condition: Used Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Chatswood State: New South Wales Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: NLR Further information: A mint condition FiiO X5 III (3rd generation) digital audio player with original leatherette case, clear case and screen protector applied in-factory. This was mainly my car player, never actually left the car much or carried around. Mostly using Spotify in car these days so no longer required, selling to fund a new turntable and phono stage. Further information, specs and manuals are available on FiiO's website: https://www.fiio.com/x5iii . Does not include original box, micro USB cable, coaxial digital adapter cable, micro SD card slot ejector pin, charger and other paper documentation that originally came with the unit. As a bonus I am including 2x 32GB SanDisk Ultra micro SD card installed in unit for free (not pictured). Also note the clear TPU case has blemishes although never been used.
      PLEASE READ
