Item Condition: Brand New
Suburb or Town: Chatswood
State: New South Wales
Payment Method: Paypal, EFT, Cash on Pickup
Reason for selling: NLR
Further information: Brand new with original box and packaging. Bought as a set together with my A30/D30 from AliExpress/China, however the shelf does not fit into space for the AMP/DAC stack so never used. Assembled once to take photos only.
PLEASE READ
    • By PassionForSound
      Item Condition: Near new Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Seaford State: VIC Payment Method: PayPal, EFT or cash Reason for selling: NLR Further information:
      I bought these for testing on the channel and although I'd love to keep them as a reference point for other reviews, I can't justify have them sitting in their boxes waiting for equivalent products to compare so they need to find a new home.
      These are very lightly used - only for the review and one or two comparisons (mostly the amp). All original boxes, manuals and accessories provided (see images)
      Happy to discuss splitting, but would prefer to keep them together as a stack.
      PLEASE READ
    • By lenticularis
      Item Condition: Used - VGC Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Isaacs State: Australian Capital Territory Payment Method: EFT Reason for selling: NLR Further information:
      Topping E30 DAC with pre-amp function
      In excellent condition (mint, except for one small rub mark on the underside front corner - invisible when in use, see last photo).
      Bought from another SNA member for temporary use until I bought the new Gieseler Kompakt DAC.
      Like the Gieseler DAC range, uses an AKM chip (the AKM4493EQ).  Sounds extremely good for its price.
      Supplied with all of the original items (USB A-B cable, Micro USB to barrel plug 5V cable, remote, and all original packaging).
      This DAC can also be powered from a power-pack or an iFi 5V supply, using the same micro-5V cable described above.
      Lots of reviews online for this high performance/cost DAC.
      The following specs copied from a post by @Ittaku...thanks!
      Spec:
      PCM
      USB :44.1kHz-768kHz  16bit-32bit
      OPT/COAX : 44.1kHz-192kHz  16bit- 24bit
      DSD (Native)
      USB :DSD64-DSD512
      OPT/COAX :Not supported
      DSD (DoP)
      USB : DSD64-DSD256
      Output Voltage:2Vrms@0dBFS
      THD+N:<0.0003% @1kHz A-weighting
      Noise:<2uVrms @A-weighting
      Crosstalk:-130dB @1 kHz
      SNR:>121dB @ 1kHz
      Dynamic Range:119dB @1kHz
      Channel Balance:<0.3 dB
      Features:
      1. AK4493 DAC chip
      AK4493 is a new generation of premium model AK4490 from AKM.
      -11 3dB :Distortion
      1 26dB* :Dynamic range
      DSD :Support DSD512
      PCM :Support 768k
      * This data is based on the MONO mode of chip, not equal to specs of E30.
      2.Supports DSD512 and PCM32bit/768kHz
      E30 uses 2nd generation XMOS XU208, USB supports up to PCM32bit768kHz and DSD512, which is far
      more than CD and SACD. We also customise the driver (for Win7 and above) from Thesycon to get a better performance with your computer.
      3.AK4118 receiver
      AK4118 is currently the S/PDIF receiver with lowest jitter, compatible with optical and coaxial connection that support up to 24bit/ 192kHz.
      4.Commonly used inputs
      E30 supports USB, optical and coaxial inputs which cover a variety of commonly used occasions, such as computer, mobile phone OTG, digital turntable and media player, TV and set-top box.
      5.5V power supply, anytime and anywhere
      Using 5V power supply, E30 can easily access the working power supply anytime and anywhere in nowadays. You can power the E30 by USB port of computer, mobile phone charger or portable charger. When using portable charger, E30 turns into a portable DAC and bring the Hi-Res music around.
      6.DAC filter mode
      E30 is capable of providing 6 filter modes under PCM decoding, 2 filter modes under DSD decoding, which slightly adjust the details.
      7.Auto turn on/off
      E30 has auto turn on / off. It will automatically enter into standby when the input signal is lost or unavailable in 1 minute. Once detecting any signal inputs, it will turn on and switch to this input.
      8.DAC + Pre-amp application
      E30 has a built-in volume control function that can adjust the volume from -99dB to 0dB by using the remote control, so you are able to directly connect E30 to a power amplifier or active speakers, and control the volume of E30 through the remote control.
      9. Pure DAC application
      The E30 is able to fix to maximum output level so that it function as a pure DAC. In this mode, the DSD signal will bypass the DATT Soft Mute and 02 Modulator to provide pure/direct DSD performance.
      PLEASE READ
    • By Munce31
      Item Condition: Used-Immaculate condition Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Keysborough State: Victoria Payment Method: EFT (preferred if paying from CBA), Paypal Reason for selling: No Longer Required Further information:
      Near new and immaculate condition. Bought on the 24th of July, so owned for a bit over a month. Copy of Ebay invoice will be included.
      Perfect starter head-fi amp.
    • By Moikel
      Item:Topping D70
      Price Range:Negotiable
      Item Condition: V Good or better
    • By mtan002
      Item Condition: New Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Point Cook State: Victoria Payment Method: EFT, Paypal, Cash on Pickup Reason for selling: Redundant Further information:
      I managed to buy the same thing  twice over a 2-week period. Memory failure!
      I just received it yesterday. Un-open, not used. The price includes postage. You can take $15 off if you come and pickup yourself.
      Despite its low price, I am very impressed with this DAC from Topping.
      It supports PCM up to 384khz and DSD to DSD256.
      Input is via USB. But you have line RCA output and S/PDIF out in optical and co-axial.
      You need to download the driver from Topping.
      More details can be found here: https://topping-audio.com/produkt/d10-pcm384dsd256-usb-dac/
      You can also find reviews of this DAC on the net.
