hlov Posted July 5, 2020 Share Posted July 5, 2020 Hi all, I found the sound on my Yamaha too bright these days, will a recap improve this? And also will the use of banana plugs make any difference. My gear is Technics SL-7 with and EPS-310MC cartridge, speakers are KEF Q350 Cheers H Link to comment Share on other sites More sharing options...
mbz Posted July 5, 2020 Share Posted July 5, 2020 The CA-810 is well regarded. Consider a recap when the amp sounds flat with a vague sound stage. I wouldn't consider any of that series to be bright, perhaps you have "an issue" maybe oscillation. Worthwhile having someone give it the once over with an oscilloscope also check/set the bias. Link to comment Share on other sites More sharing options...
hlov Posted July 5, 2020 Author Share Posted July 5, 2020 6 minutes ago, mbz said: The CA-810 is well regarded. Consider a recap when the amp sounds flat with a vague sound stage. I wouldn't consider any of that series to be bright, perhaps you have "an issue" maybe oscillation. Worthwhile having someone give it the once over with an oscilloscope also check/set the bias. Thanks for the advise, I have to put the treble in 0 in the lowest position Link to comment Share on other sites More sharing options...
mbz Posted July 5, 2020 Share Posted July 5, 2020 4 minutes ago, hlov said: I have to put the treble in 0 in the lowest position You have a sick amp 2 Link to comment Share on other sites More sharing options...
Al.M Posted July 5, 2020 Share Posted July 5, 2020 (edited) With 40 year old amps the very many circuit capacitors start to dry up, loose value and or fail eventually. A good local tech should help. Compare the sound with another amp and see if there is any difference. Edited July 5, 2020 by Al.M Link to comment Share on other sites More sharing options...
