jaspar Posted July 1, 2020 Share Posted July 1, 2020 I need a quick and easy DAC-Headphone Amp for computer use. I'll be using a pair of Sennheiser HD600s which I'm sure many of you would be familiar with. I've had advice from certain quarters that this product is all I would ever need https://www.smsl-audio.com/portal/product/detail/id/546.html Am I on the right track or should I be looking at other alternatives? Thanks, Jason. Link to comment Share on other sites More sharing options...
jaspar Posted July 1, 2020 Author Share Posted July 1, 2020 When available, it retails for about $588 (AUD), but is out of stock at present. Link to comment Share on other sites More sharing options...
Volunteer sir sanders zingmore Posted July 1, 2020 Volunteer Share Posted July 1, 2020 If this is a WTB post then it should go here: https://www.stereo.net.au/forums/forum/41-wanted-to-buy/ Link to comment Share on other sites More sharing options...
jaspar Posted July 1, 2020 Author Share Posted July 1, 2020 1 minute ago, sir sanders zingmore said: If this is a WTB post then it should go here: https://www.stereo.net.au/forums/forum/41-wanted-to-buy/ No. I'm just seeking advice. Link to comment Share on other sites More sharing options...
jaspar Posted July 1, 2020 Author Share Posted July 1, 2020 Here is a review Link to comment Share on other sites More sharing options...
Mutatis Mutandis Posted August 2, 2020 Share Posted August 2, 2020 Haven't used this particular device - but have only good to say about the little SMSL M8 DAC. Had in main system for ages before my Giesler DAC came and sent it on to my son's system. If this is at all similar in build and sound, and the headphones aren't at the hard-to-drive end of the scale, you ought to do fine. Link to comment Share on other sites More sharing options...
