Gwhitten
FS: ESP Essential 2.0m USA power cord (RELIST & REDUCED PRICE)
Item Condition: very goog
Suburb or Town: Melbourne or Geelong
State: Victoria
Payment Method: EFT CASH
Reason for selling: New cords purchased
Further information:  2.0m ESP-Essential Sound Products USA plugs these plugs are Expoy filled by ESP
Cord has been feeding my PS Audio P20 power supply without issue so high current devices are not an issue - I have hung on to this cord for awhile everything i put up to it in the same $ range didn't meet the grade and had to make a significant step up to outperform this one
ESP make great cords.
Will also throw in at no cost a USA to Australia converter plug if required
PLEASE READ
Edited by Gwhitten
typo
    • By Audio Connection
      Item Condition: As Traded in Excellent Condition Shipping Options: Pickup available and you can audition. Suburb or Town: Leichhardt State: New South Wales Payment Method: Cash on Pickup, EFT Reason for selling: Further information:
      Electronic Crossover.
      System : 24dB/octave filter
      Bessel function high-pass and low-pass
      DC buffer amp
      Bandpass gain : 0dB
      Inputs : 1V rated / 50kOhm 7V maximum)
      Outputs : 1V rated / 100 Ohm 7V maximum)
      THD : less than 0,05% at 1V output
      less than 0,03% at 1V output (D88B)
      less than 0,05% at 5V output (D88B)
      S/N ratio : better than 110dB (1V rated input, A-weighted)
      Frequency response : DC...100Khz (+0 / -1dB)
      PC : 15W (D900)
      20W (D88B)
      Item Condition: As Traded in Good Condition Shipping Options: Pickup available and you can audition. Suburb or Town: Leichhardt State: New South Wales Payment Method: Cash on Pickup, EFT Reason for selling: Further information:
      Here is a rare opportunity to own some great technology and get some fabulous sound quality. The Goldmund Logos 1 Bookshelf Speakers are a passive speaker and can be used with a range of very good power amplifiers including Goldmund's own power amplifiers. They even feature the Goldmund coaxial speaker connector. The Logos 2 Active Subwoofers are very flexible and high performance subwoofers, they can be used with a wide variety of preamplifiers with 2 analogue outputs, processors with 2 analogue outputs and quality integrated products if they have and analogue or subwoofer output. They feature both Digital and analogue inputs, the Digital  inputs are specific to Goldmund Processors whilst the analogue inputs can be used with any quality processor or preamplifier as long as they have either a second analogue or subwoofer output.
      LOGOS 1
      - Fully constructed in metal with implementation of the mechanical grounding system to
      evacuate vibrations.
      - 7” woofer and soft dome tweeter, both selected for their high linearity and dynamics.
      - Frequency response: 45Hz - 25kHz
      - Efficiency: 88dB / 1W 1m
      - Dimensions: 330mm (13”) H x 230mm (9”) W x 280 (11”) D
      - Weight 15.5 KG (34lbs)
      User
      LOGOS 2 ACTIVE
      Amplifier Analogue Input Impedance: > 51 kOhms.
      Amplifier maximum power: 650 W Rms.
      Drivers: 30cm (12”) driver and 30cm (12”) passive radiator mounted in phase.
      Bandwidth:
      • Low Frequency Cutoff : < 20 Hz -3dB.
      • Electronic Crossover: 4th order low-pass filter with 6 separate frequencies.
      Position 1 - infinity : digital
      Position 2 - 150Hz : higher crossover frequencies
      Position 3 - 80Hz : higher crossover frequencies
      Position 4 - 55Hz : Logos HE or Mini-Logos
      Position 5 - 50Hz : Logos 1
      Position 6 - 35Hz : Epilogue 1
      Master level control
      Bass Load: Passive radiator.
      Size and Weight:
      • Weight of one sub-woofer : 30 kg (66lbs).
      • Size of one sub-woofer : 35 cm (14”) H x 35 cm (14”) W x 35 cm (14”) D.
    • By hugo_wilco
      Item Condition: VG+ Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Melbourne State: Victoria Payment Method: Paypal EFT cash on pickup Reason for selling: NLR Further information: selling albums I have never played or hardly played. See other listings
    • By miyouzaic
      Item Condition: Good for age Shipping Options: Shipping is included in price. Suburb or Town: Bellingen State: New South Wales Payment Method: Paypal, EFT, Cash on Pickup etc Reason for selling: NLR Further information:
      4 x Celestion HF1300 15ohm Square face midrange/tweeter also used in "Rogers Studio 1" model.
      They have original mounting gaskets and all measure around 12ohms DCR +- 0.3ohms
      Check the photo's for condition.. there are what appears to be fine hair line fractures off of many of the screw and mounting holes on the face plate...
      But on much closer inspection, you can see that they derived from the mold/casting process...  thought I'd mention it for those with an eye for detail !
    • By miyouzaic
      Item Condition: Fully Functional Shipping Options: Shipping is included in price. Suburb or Town: Bellingen State: New South Wales Payment Method: Paypal, EFT, Cash on Pickup etc Reason for selling: NLR Further information:
      These came out of the same Ditton 25 enclosures as the T1600 Bass drivers and Celestion HF1300's also listed.
      All original and functioning as they should. All the rubber surrounds are supple and flexible.
      As you can see in the photos.. the plastic mounting shells that the ABR panels are supported by, are different colours.. one black.. the other off white.
