Hi All,
Looking to upgrade my current AVR into a one stop shop for music and home theater (will be a 5.1 setup). I have been looking at processors/Prepro's and they appear to be very expensive compared to AVR's with the same features.
Is it worth making the upgrade to a Prepro over a decent AVR with pre-outs? I will be using a separate power amp even if i go with an AVR.
Thanks in advance!
A budget will help guide discussions.
Please have a read of the following threads which discuss similar things
Hi indeed av processors are more expensive but usually for folks looking next level performance ... definitely get what pay for. Better dacs processing analog stages and power supplies.
with avrs you can also get improvements in these as go up the range :)
music and home theatre in one is a big ask. Most avrs that combine that well you are looking at top end units of denon marantz ... arcam not much else. Nad make avr that Likely decent for both but expensive. Quality costs
there is a simpler path to this. Get the avr that does what want ... couple that with a quality 2ch integrated with ht bypass that will give you the quality pre and power stage needed for 2ch music ... best both worlds. Av source through avr. 2ch sources through 2ch integrated.
beauty with this approach is when the Swiss Army knife avr jack of all trades is superseded. You replace that and pure analog 2ch integrated can stay
other alternative if going av seperate something like marantz 8 series processor in av8802a or av8805 are actually pretty decent with 2ch. Couple with a multichannel power amp like the Elektra that is also decent with 2ch and will also have way into excellent av and pretty decent 2ch. Will have to pay for it though.
if don’t need latest greatest older marantz av8801 was also pretty decent 2ch wise just won’t do latest Audio video formats for av ...
Yep, and there's good reasoning behind that.  As @betty boop says, you get what you pay for.
Would Prepro's like the Emotiva MC-700 still be a good step up from an AVR?
Also saw the Outlaw Audio model 976 which seems to be a reasonable price as well, but just hard to buy in OZ.
https://emotiva.com/products/mc-700
https://outlawaudio.com/shop/index.php?id_product=23&rewrite=model-976&controller=product
Hi Viso.  You've mentioned a brand that I wouldn't touch or go near, so not the best example IMHO.
I wouldn’t touch either. Especially given how current support up in air out here. If looking for bargain basement budget a better example be rotel going in classifieds or nad pre
Another good example
Emotiva are known to use bad capacitors in the past, can’t say what they use now.
I owned the predecessor of the MC700 Viso ; the UMC200 [its a spare atm] and the MC700 was nowhere near as reliable , due to its combination of hdmi2.0a and hdmi1.4 inputs 😬
If wanting reliability and performance ; the XMC1 that people are trading in on XMC2;s at the moment is on another level ; no emoq req ' its got dirac B)
https://www.audioholics.com/av-preamp-processor-reviews/xmc-1-7.2-av-processor
but as Al said service is now up in the air with local distribution gone now so shipping to the US is required..
Pretty much reflect what others have said, if money and space is less of a concern and performance is most important, just go with a an AV pre and power amp combo, other alternative would be to go with a higher end to flagship AVR and add a decent 2ch power amp for the main speakers and drive the rest of the speakers  off the AVR.
JDH
What about those for pure HT setup?
with integrated 2ch you sort out the L+R but for HT Center is really important as well.
These pre/pro and amp can be really expensive so are the quality AVR. Don’t mind paying big for quality AMP that lasts you 10 years or so and swap out the pre/pro as new ones comes in, but the problem is the pre/pro Costs even more than AVR. So no easy swap.
a quality item supported by the maker can mean it takes through the years. with av pre pros the last one i had was supported by its maker over 8 years i had it .... so was upto date and do everything i wanted. ofcourse there comes a point no longer viable to support or tech moves on significantly and there is a significant jump that warrants replacement.
my current av pre pro does all i want and have had it since it was released some 5 years ago ? it has received hardware and software updates and still does all i throw at it from various sources. can i keep using it another 3+ years ? cant see why not ? might even take me to 10 years ?  and yes over that 8-10 years my power amp will stay as is and no reason cant keep going way beyond that. good amps can o easily some 20+ years if a quality item :)
sure however often for many folk interested particulary with music the mains L&R speaker's can be a significant load that can take off the need of the AVR to power...AVRs even with the very top end ones tend to be a significant compromise... just look inside see the power supply can squeeze in limited heat sinking and how everything is so crammed in ...this is more the case these days where the AVRs are cramming more and more channels in only exacerbating the situation... and all that you need to toss out when time comes to update...
Look at meridian processors
568.2 or a g68 are fantastic at 2 channel as well as dolby & dtx (no atmos though but unless you have a dedicated room who cares).
May I ask which pre/pro and power amp are you using?
hi I run a marantz av8802a pre pro and for power amps elektra theatre HD1 & HD2 for a 7.1.5 setup
did have a Yamaha RXV 1081 using as a Pre only into a Emotiva XPA-5
movies it was not bad, for 2ch music it was woeful
6 months ago I upgraded to a Emotiva XMC-2 pre
movies, its an upgrade, but not leaps and bounds, but def better
for 2 ch
OMFG, outstanding
I have finally found a compromise between HT and 2 ch in one system
the down sides,
for the first 4 months it was a piece of poo, then they rewrote the FW and it became usable
buying Emotiva, you become their R&D dept
if it goes bung, I have to send it back to the States
Dirac is STILL not ready for the XMC-2
but seeing I got it on a 40% discount I don't think I could getting anything close for HT and 2ch for the cost
My colleague at work bought a traded in XMC-1 the same time I bought the XMC-2
its like new
he has run a few Rotel Pre's, a heap of Denon gear over the years and says the XMC-1 is the best sounding kit he has had in his house
Dirac has a fair bit to do with it
the only thing you have to be careful with the XMC-1 is its superseded and might not gel with future upgrade path
Yes ; although its had 2 hdmi upgrade boards over the years from the original hdmi1.4 to the current hdmi2.0b ; I wouldnt expect a hdmi 2.1 board being developed for its texas instruments dsp ;  not when the XMC2 is going to get a hdmi 2.1 board upgrade one day :)
One of the most common question and one of the most complicated to answer. Many variables.
Thanks for the input to all that commented, really appreciate it.
At this stage I will seek out a used Marantz unit and go from there!
Seems to be the best compromise between $ and sound quality without having to go down the route of buying an AVR and using the pre-outs.
In 2ch integrated amp, is the tone defeat same as HT bypass?
No..
Tone Defeat takes the treble and bass control out, makes a cleaner path from input to output
HT bypass basically turns the integrated amp into a power amp, it either bypasses the volume control/pre-amp stage or fixes the volume control to a consistent level.
25 minutes ago, Hytram said:
No..
oh! ok Thank you for the clarification.
Bugger! I was fixed on using one of the integrated amp in my HT setup. I guess, I am going to have to look for something else.
Most 2ch integrated and 2ch pre from last 15 years tend to have the feature... can be called ht bypass. Ht direct, processor pas through and such ... some provide an input for the  feature,  others allow any input be setup for it.  But yeah have to have the feature to use it :)
