SOLD: SOLD: MONITOR AUDIO Radius 270HD, compact floorstanders
Item Condition: Used, VGC
Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost.
Suburb or Town: Kardinya
State: Western Australia
Payment Method: bank transfer
Reason for selling: NLR, upgrade
Further information:   https://www.monitoraudio.com/en/product-ranges/radius/radius-270/
https://youtu.be/UPPQfiOLDOc
The Radius 270 houses a precision-crafted Radius driver system of twin 100 mm (4") C-CAM mid/bass drivers and a 25 mm (1") C-CAM tweeter.
Technology
  • 4" C-CAM bass driver - Radius features bass drivers with concave cone profiles, introduced by our top-of-the-range Platinum speakers and applied subsequently to Gold GX. Extensive research and FEA modelling have allowed us to perfect the relationship between the radiating diaphragm and its motor design, introducing larger motor sizes and voice coils for increased excursion, higher power capability and reduced distortion.
  • C-CAM Gold Dome tweeter - optimised to deliver the finest and widest performance within the compact Radius cabinets. It benefits from a more efficient rear-venting design, releasing air trapped and compressed at the back of the tweeter dome, and guiding it around the drive assembly to a rear-loading chamber.
  • HiVe II port design - Straight from Platinum’s design blueprint, the HiVe reflex port makes its Radius debut. It’s shaped to have the same effect on airflow as a gun-barrel on a bullet. Rifled grooves inside the port help to accelerate the flow and reduce turbulence, so air moves in and out of the port more efficiently, for a faster more dynamic bass response.
  • Single through-bolt driver fixing provides mechanical de-coupling and enhanced mid-band clarity and resolution. The through-bolts also act as rigid cross bracing to give a very solid non-resonant cabinet.
  • Front and rear ported reflex design
Nominal  Impedance 6 ohms
Power Handling Single (RMS) 100 watts
System Power Handling (RMS) 150 watts
Recommended Amplifier Requirements 40-150 watts
Maximum SPL (dBA) 107
Bass Alignment Bass reflex - front and rear ported
Driver complement 2 x 4” (100mm) C-CAM® cone bass/mid driver
1 x 1” (25mm) C-CAM gold dome tweeter
Cabinet Dimensions (H x W x D) 1000 x 177 x 208mm
(393/8 x 615/16 x 83/16 Inches) Inc Plinth, Without Spikes
(Inc Grille & Terminals)
1025 x 177 x 208mm
>(403/8 x 615/16 x 83/16 Inches) Inc Plinth, With Spikes
Weight
9.9kg (21lb 12oz)
MA radius 180HD centre speaker available (see Home Theatre / Visual).
Can demo for serious buyers. Local sale preferred but can ship at agreed price (depending on postcode).
Price already reduced few times (2K speakers).
Edited by MAXXX
Combined with a sub and an amp that knows to cut-off , these are fabulous for both movies and music!
    • By juleshoolio
      Item: Monitor Audio Silver Centre
      Price Range: Negotiable
      looking for Centre speaker to match Silver 2 bookshelf speakers 5th Generation.
      Based in Sydney for local pick-up or will pay postage within Aus.
      Open to similar suggestions if not matching.
      https://www.monitoraudio.com/en/support/past-products/silver-5g/silver-2/
    • By MAXXX
      Item Condition: used, VGC Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Kardinya State: Western Australia Payment Method: Bank transfer, PayPal Reason for selling: NLR Radius 180HD
      Frequency Response 60 Hz - 35 KHz
      Sensitivity (1W@1M) 87 dB
      Nominal Impedance 8 Ohms
      Power Handling (RMS) 60 W
      System Power Handling (RMS) 10 - 100 W
      Recommended Amplifier Requirements 10 - 100 W
      Maximum SPL 105
      Bass Alignment Bass reflex - rear ported
      Drive Unit Complement
      1 x 100mm (4") MMP®II cone mid-bass driver
      1 x 25mm (1") C-CAM® gold dome tweeter
      External Dimensions (H x W x D)
      350 x 125 x 105 mm
    • By Erbacher
      Item Condition: Very Good Shipping Options: Pickup available and you can audition. Suburb or Town: Castlecrag (Lower North Shore) State: New South Wales Payment Method: Cash, PayPal Reason for selling: Replaced by new centre Further information:  Selling as moved on from my MA Silver 100's to GX100's, love this centre but needed to go to a ribbon tweeter to match. There are some small scuffs in places where it doesn't matter but looks wise its 8.5/10 and it sounds perfect.
        ps://www.monitoraudio.com/en/support/past-products/silver-rs/rslcr/
    • By Erbacher
      Item: Monitor Audio Center with ribbon tweeter (gold C150 ideally)
      Price Range: market
      Extra Info: If anyone has a center with ribbon tweeters that might match MA GX100's let me know.
    • By BenBenBen
      Item: Monitor Audio Silver Centre Speaker
      Price Range: Negotiable based on condition etc.
      Item Condition: New or Used
      Extra Info: To match existing speakers needs to be 5th generation (2014 - 2017) and natural oak finish.
      Can anyone comment - were these even imported into Australia?
      Prefer Brisbane for pickup, but OK to have shipped.
