Hi guys,
I would really appreciate any guidance.
I have front right/left speakers which are 6ohm 250w (nominal)
central, rear left and rear right are 8ohm 150w (nominal)
My amp is at the moment struggling to push all those speakers so i was wanting to upgrade.
budget wise i think up to about 1k would be something for a 5 channel (just guessing here), if more how much more would be needed ?
would there be one the would be HDCP 2.2-compliant ?
if some that have atmos capability so i can buy some speakers and add in the future would be great.
so would be 5.1.2 i'm guessing here?
would a 7.1.2/7.2.4 be better ? havent seen a lot of bluray that comes with 7channel capability like that.
the 7 i see usually are counting the atmos speakers.
Thanks in advance for reading and for any suggestions that comes my way.
Current Setup
Receiver: Yamaha HTR-3066
Front: NHT C4
Centre: Gale 20
Rear: Axis LS28
Subwoofer: Sound Dynamics THS-10
Edited by mfroes
can you keep AVR you have and add a power amp if thats all thats struggling ? might be a 5-7ch power amp is all need ? beauty with this is you could upgrade to an avr later that can cover the rest of speakers and keep the 5-7ch power amp that will get you driving speakers you have now.
because otherwise $1k is not a heck of a lot.
there is a ton of stuff thats atmos and yes well and truly will do 7.1.2 or 7.1.4 but you'll need to spend more on your budget i would suggest if your AVR is struggling now with speakers you have ....
Hi betty boop,
I was hoping to upgrade the AVR so i could have 4k support.  i've added my current setup in the original post.
What would be roughly the price of a good 5/7 power amp ? arent they usually same price or more expensive than an average AVR?
I've been suggested to use Marantz SR6009, but no idea on that one.
I'm not wanting anything new, so i thought that 1k would be ok.
How much would be one that would be worth it ?
for a 7.1.2 it would be good, but only if on sale, close to the 5ch. i'd say. try finding another 2 speakers would take a while.
1 hour ago, hopefullguy said:
op please post your existing avr.. also why not post your speaker and sub just to round off your info.
Hi hopefull
added to the original post. thanks
14 minutes ago, mfroes said:
Hi betty boop,
No own experience on speakers in question, can only go on what can glean from specs. At 86-88db efficiency speakers none would be classed as easy and need power behind them especially for movies.
problem with the yam avr is not that big power supply 470w max consumption and 40% be lost not leaving lot watts driving all those channels and that’s flat chat so can understand if sounding bit strained.
if buying 2nd hand a rotes 1075 which is good honest power should pick up for under $500 and seen them come up look out ...
problem with avrs even a flagship avr won’t have likes of power stage of the  rotel 1075 .... so hope get my gist
with avrs I’d still look at $2k-2.5k that might find 2nd hard bit cheaper eg in denon/marantz a model from 2016 onwards would do ... don’t need latest greatest and will do all asking for ...
I wonder if one of this would be up to the task atm
then, when a rotel comes up get that to drive them and keep growing with a 11ch...
start separating amp/receiver
Marantz sr6010
https://www.marantz.com/en-gb/shop/avreceiver/sr6010?status=discontinue
or
denon x2400h
https://www.denon.com/en-gb/shop/avreceiver/avrx2400h
the marantz had the advntage of processing 9 channels instead of just 7.
Looking at specs some of them just say 100w/ch other say 100w/ch (when 2ch driven).
does that mean that when connecting more speakers the 200w will be splitted with all speakers?
Nice setup by the way betty, a thing that one can only hope for is to get close to it
Edited by mfroes
Hi @mfroes
Looking on the Yamaha site the Yamaha HTR-3066 is only a 5.1 receiver so if you want to go 5.1.2 you will need a new receiver.
The Marantz you mention only has 650w power sonsumption, so splitting that between 9 channels, after losing 40% loss due to heat etc, that leaves about 400w to power 9 channels or 45w per channel, less for inefficient speakers.
As @betty boop says your speakers need lots of power to perform well, new AVRs are expensive and most of the money is spent on the extra 'bells and whistles' of Dolby this, THX, DTS xx, and other processing formats, little is left to power.
A secondhand Pre and Power setup will give lots, but will cost around $2.5K
You could use an older AVR as a Pre amp
And a Power amp to power the speakers
JJ
Edited by Janjuc
hi @Janjuc,
thanks for the support and suggestions.
I'm unsure why nht are not that known here in AU.
they are current models and was cheap cheap.
so i moved a few of the speakers around to have these as front. hence the need for upgrading
At the moment, i have a bit of a mess.
yamaha driving rear 2 and sub with the stereo out connected to my technics SU-X901 amp which can drive the speakers a bit better.
I think i'm gonna have to a bit more than double my budget then. so no extra speakers for 3D sound at this point.
and maybe stick with a 5.1 until able to save some more $$
My I understand that the AVR does not have RCA out for all channels so it couldn't be used as a pre-amp. or am i wrong?
they only have stereo out.
Will start looking for some amps..
my guess is that LX-7 is better than the hotel 1075 as it is 200w X 7 and nor 120w X 7.
forgot to ask as well... the NHT C4 says it is a 250W speaker, would it be good to have a 250W amp running them or something like the LX-7 (200w) would be ok ?
sorry if those are too much of a newbie questions. just trying to learn more.
Edited by mfroes
Would this preprocessor be suitable? any suggestions?
this guy is close to home and has 7.2 rca out. that combined with LX7 should make a good setup with about 2k
what are your thoughts ? maybe ?
or for what i am wanting id better to go so me other path?
not really diving into the 3d sound at the moment with the budget increase.
Hi @mfroes
The NAD would be very good to match with an amp with 7 channels of 100w or more.
The NHT C4 is 86dB sensitivity, with is lowish, but should not be that difficult to drive with 100W or more amps, but that is proper 100w per channel RMS, all channels driven, so the actual power consumption should be around 900w for the 7 channels. As for saying 250w speaker, this is usually a guide to maximum watts, as depending on the music or scene it varies depending on the load placed on it which could vary from 1-2 watts in a quiet scene to 200+ if there are explosions etc, and this is where the amp is important, as if it doesn't have the power to do these changes then the speaker may begin to clip / distort which could cause speaker damage.
JJ
sorry op and no offence meant to others but waiting around and trying to pick up a rotel 1075 for $500 could mean missing other possible amps that come up... last 3 sold on this forum for an ave of $650.
your speakers are inefficient so seemingly need more power than normal to get volume out of them.
Hi @hopefullguy,
sorry to bother you with a silly question, but just so i dont have this problem again,
how do i know if the speakers are inefficient? is that by the sensitivity ? my previous was 89db. was loud but not even close to the fidelity(clarity on shows) that this one gives me. and i thought that 86db was close enough to the 89 i had before.
what would be a good one ?
not that i will buy right now, but just to learn really.
https://www.lifewire.com/speaker-sensitivity-3134850
guess it depends on what speakers you are use to. i use a combination of klipsch/psa so around 95 db sensitivity.
The thing with sensitivity is that many brands actually have a lower sensitivity than they state, often 1-2dB less when tested, which requires more power to bring them up to a decent level, also if you are using 10 watts to listen at nearfield level, then you need 100watts to double the volume, then to double it again you will need 1000watts, its a logarithmic progression, and doesn't account for losses due to heat,  poor placement etc..
Greets.
Thing is the Yamaha HTR3066 is an entry level AVR, the sort used to package up with an entry level speaker pack at Harvey Norman etc.  here and Walmart etc. in the US. Therein lies your immediate limitation. It just doesn't have the oomph to run the NHT's nicely.
10yrs ago, before I left the hi-fi industry and ran away to become a gardener and pensioner, I was recommending to people that a good option for around $2.5 - 3k was to get an AVR which could do bi-amp and main speakers that could make use of that with bi-wirable terminals. Typically, this was a Denon or Marantz AVR with Monitor Audio Bronze series or Jamo 606/608 speaker kits.
Set up properly, these systems were great value for money and could be very satisfying which gave me a bunch of happy camper customers.
If I apply the same thinking to what I see available today and I was looking for an AVR for around $1k, the one that keeps coming across my radar is the Onkyo at around $1400. Current model is TXNR696.
https://www.intl.onkyo.com/products/av_components/av_receivers/tx-nr696/index.html
I have seen them and/or their predecessor down to around $900 on sale/promotion at JB. I think Selby have done a few deals too.
Now the flaw in my proposition here is that the NHT C4 speakers are not bi-wirable from what I can determine which means you couldn't get the benefit from that feature on this AVR. However, the AVR does have front pre out which means you could add a 2 channel power amp at a later date if you decide to keep going with the NHTs or you could go for the bi-amp option if you changed/upgraded speakers. The power output and quality of this AVR should still be a good step up from the Yamaha and it has more home theatre capabilities than I can decipher these days.
I guess I just see something like this as a neat, clean solution with the possibility of future upgrades and within the region of your budget but I know it won't be the answer on everyone's lips and plenty will choose to disagree with me.
As an added bonus it has a phono input so you can play records :)
Whenever I see them come up on a deal, I try to think of a good enough reason to buy one and have a play but I just haven't come up with a good enough reason yet. Probably, if my Sony STRDN1050 bit the dust, this is what I would look out for if I didn't find anything second hand. It is in my second system in the kitchen/family room and does the job.
    • By manbat
      Item Condition: Mint Shipping Options: Pickup available but audition is not available. Suburb or Town: Melbourne State: VIC Payment Method: EFT Reason for selling: Renovation Further information:
      Professional series -  Sony VPLW520ES Projector Bundle (latest software upgrade.) White.
      This is the native 4K deal professional series – all glass Sony lenses made in Japan, excellent reviews.
      Lamp time – 2200hrs (lap rated for 6000hrs) – Additional lamp also available
      https://www.techspot.com/products/projectors/sony-vpl-vw520es.122529/
      https://www.avforums.com/reviews/sony-vpl-vw520es-4k-projector-review.12100
      What you get (bundle costs 4 times brand new)
      1.     Sony 4K VPLW520ES Projector - Glass lens made in Japan.
      2.     Screen Technics Tab Tension 110 inch screen (electric screen with remote)– I had this made to order with extra-long lead. Great screen - no striations. Mint condition. Screen disappears out of site. Great WAF
      3.     Blue Stream - HDMI – over Ethernet kit (HEX70B-KIT) Base and Transmitter set - https://www.blustream.com.au/ Picture perfect signal over long distances, better than HDMI.
      4.     Projector mount comes from Screen Technics model PRGUNV.
      5.     Projector extender from Screen Technics.
      6.     Spare lamp new – Free and included!
      7.     Remotes – mint condition
      All purchased locally from Carlton Audio Visual CAV.
      I am selling everything as a package. All items are mint. Pick up only.
      Serious parties only - home demonstration available.
      Strongly suggest that if purchased you get professionals to remove and reinstall at your residence.
      No boxes available – instructions and remote for projector and screen present and correct in mint condition.
      **If you want this posted please arrange a professional company for removal, package, and transport.
      Sony VPLVW520ES Reviews
      What Hi-Fi
      A pull-out-all-the-stops performer with future-proofing to its name
      Pros:Fantastic picture all-round, HDR support, Native 4K, Future-proofed, Solid, attractive design
      Cons:No 3D glasses, A pricey option
      Home Cinema Choice
      The selling point of the VW520ES is essentially this: it gives you both a native 4K resolution – something no other brand has yet been able/bothered to manage on a home cinema projector – together with high dynamic range (HDR) playback.
      Pros:4K pictures look amazing; HDR pictures look even more amazing; good setup flexibility; good price for what’s on offer
      Stuff TV
      A future-proofed projector with a license to thrill
      Pros:Startlingly good picture all-round, HDR and 4K, Dead simple set-up
      Cons:No 3D glasses, Still a pricey option
      https://www.avhub.com.au/product-reviews/sound-image/sony-vpl-vw520es-4k-av-projector-review-430128
      Screen - Electronic Tab Tension.
      Screen Technics
      https://screentechnics.com.au/products/roller-screens/motorised-screens/electricinema-side-tension-screen
      110 inch tab tension extra-long lead (allows to have the screen positioned lower than usual  – remote – excellent screen free of any striations.
      Blue Stream
      HDMI – over ethernet
      Projector mount comes from ScreenTecnics model PRGUNV.
      Projector extender
      PLEASE READ
    • By rt3m
      Item Condition: Great Shipping Options: Pickup available but audition is not available. Suburb or Town: Botany State: NSW Payment Method: Cash or bank transfer Reason for selling: NLR Further information:
       Includes original remote and original power cable (detachable, with Singapore plug)
      Photos
    • By Mikey B
      Item Condition: Excellent Shipping Options: Pickup available and you can audition. Suburb or Town: Alexandria State: NSW Payment Method: Cash on pickup Reason for selling: Have upgraded to a new system Further information:
      Selling a Vincent SP-331MK Hybrid Power Amplifier. It's a hybrid tube-transistor design that delivers class A at lower outputs and then class B at higher outputs. Two sets of output posts to allow for bi-wiring. Big, powerful amp that delivers great sound in my opinion. Generally very positive reviews: https://www.theabsolutesound.com/articles/vincent-audio-sa-31mk-hybrid-linestage-preamplifier-sp-331mk-hybrid-power-amplifier-tas-208-2   Full tech specs are here: www.vincent-tac.de/en/product-lines/powerline/sp-331mk.html   This amp has been well-used but has also been well looked-after. No cosmetic damage anywhere on the unit. Still performs perfectly. Comes with orginal box and packaging. Audition is possible but will require some notice. I no longer have it set up in my system.    Recommended retail is $2,900. Pickup only. It weighs about 25kg so shipping is not really practical.
      PLEASE READ
    • By Dave05
      Item Condition: Near New / Demo Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Heathridge State: WA Payment Method: PayPal, Cash, PayID Reason for selling: Not installing system Further information:
       Near New - installed to load firmware and DSP config but never used.
      HEC HD USB audio card installed (RRP $299). Enables bit-perfect audio from eg Android phone, with an OTG adapter and the supplied mini-USB cable.  Sampling rate up to 32/192.
      6ch Analog (high and low level) and digital inputs.  Sensitivity can be changed to accommodate mV headphone output from a phone.
      Currently retailing for $2299 without the USB card, which is another $250.
      There are a few superficial scratches around the cable entries but otherwise perfect condition. Priced to sell.
      PLEASE READ
    • By Mikey B
      PLEASE READ
