Hello Guys,
I am looking for some suggestions for a 7-11 channel AV processor.
Budget $4k-5k
Thanks in advance.
Edited by Nope
Update budget
A budget will help discussions. Are you specifically looking for a pre processor or will an AVR do?
  • Thanks 1
Emotiva have a pre that is 16 channels, and is within your budget
XMC-2 16 Channel 9.1.6 Discrete Dolby Atmos & DTS:X Cinema Processor
Edited by DSD_Fan
Prepros include new Marantz AV7705 and Anthem AVM60, my recommendation with Anthem Room Correction.
Just about any AVR with preouts can also do the job at lower cost.
Dunno why I read this as 11+ channels. But what Snoopy said. I have the AVM60 and LOVE it. I run it with Crown amps and it's great.
7 hours ago, Nope said:
Hello Guys,
Budget $4k-5k
Thanks in advance.
marantz are a good buy will all channels need. something like the av7705 is well in budget :) audyssey xt32 as setup and eq is very easy to use intuitive and will also handle all channels needed :)
@betty boopThank you. Can we have zone 1 and zone 2 in av7705 and can we run two different speaker setup like one with 90db@4ohm(zone 1) other with 97db@8ohm(zone 2)?
As HDMI 2.1 is there is it good wait for the next version of AV7706?
Power amp will be Elektra.
Edited by Nope
Thanks @DSD_Fan , how is crown amp is it classD? Which series /model are you using?
Thanks @Snoopy8 a decent Avr with pre out costs atleast 2500-3000$. If we are spending that money is it not a good idea to get a prepros like AVM60/ Marantz? that  prepros will perform better than AVR ?
I run the 1502's I believe they're class D but they sound a lot better than my old receiver and zero noise that I can hear
I got 6 of them for $3800. This way if I need more channels in the future I just add another amp or 2
  • Thanks 1
check all features to make sure suits you. due dillengence is something will need to do for self :) denon and marantz has had zone 1 zone 2 for about 10+ years. re such disparity of efficiency ... you will possibly have or not have issues in channel imbalance..... if you can't level up will need to use in line attenuators which some need to do at times (this is regardless of pre amp)
hdmi 2.1 in my opinion is a non event.... its a feature list no guarantee something will support all features... not worth waiting for. something from 2016 will do all and you can throw all at right now...
many folk use elektra with marantz ... theyre a great match... and well priced as a local option...so not costing twice what does in home country...because this is home :D power with finese...great dynamic range with huge power reserves the veritable iron fist in a silk glove...
  • Thanks 1
Thanks maximum channel will ever use is 11. But for another couple of years it's only 7 channel is needed.
AVRs come and go and depreciate crazily ! and every time replace will throw out baby with bath water...both pre and power... with av pre pro processing will come go but your power amps will stay can can stay... that said likes of denon marantz keep supporting things a long while too... my last denon flagship they kept updated for 8 years ! my current marantz pre pro though superseded and 5 years old still does everything 4k uhd needs everything appletv 4k, pana uhd player, xboxonex, fetch tv can throw at it ...
  • Thanks 1
A new NAD T758V3 with Dirac Live has a street price of $2K. Marantz SR5014 under $2K, Denon X2200 $1.5K.  Just need the lowest model with preouts.
Getting a used unit is even cheaper, AVRs depreciate quickly.
Prepros usually have better analog circuitry and output stages. In particular, they are better with 2 channel music and can be an option for someone after a 1 box solution. But, for movies, prepros may have an edge on audio for a lot more dollars. And prepros and AVRs both do video pass through (the very high end prepro may do some video processing?).
However, it sounds like you have the budget, so go prepro and take advantage of the better analog audio.
  • Thanks 1
 Between the Yamaha Cx-a5200 and marantz av8805 on perusing the owners threads in various forums you will hardly hear anyone complain of bugs or issues . They work as advertised
you want misery? Grab a JBL synthesis Or a modern arcam
https://au.yamaha.com/en/products/audio_visual/av_receivers_amps/cx-a5200/index.html
Edited by Kdjjdk Will
  • Thanks 1
7 minutes ago, Bunno77 said:
Definitely the Anthem avm60
Thanks mate, is there any new products in near future  for anthem with HDMI 2.1? If incase any news.
59 minutes ago, Bunno77 said:
@Nope I'm not sure sorry but you could email Anthem and will no doubt get a reply quickly
Thanks @Bunno77. My plan is to add Elektra HD7 amp. I have heared great feedback on Anthem. Next comes Marantz.
But will contact Anthem on future release.
Anthem + Elektra
Marantz + Elektra
I am not sure which is better as we cannot have Elektra amplifier to demo.
@betty boop any thoughts on Anthem AVM 60 + Elektra. As you have been using Elektra amplifier for a long time. Any thoughts much helpful.
Planning for Stereo and Home movies.
Edited by Nope
Anthem + Elektra
Marantz + Elektra
elektra and marantz are a good match. and myself am very happy with marantz since day one fault free. not a bug to speak off works well and seamlessly and supported well. 5 years on still does everything can chuck at it and made in japan with some 200 engineers behind it . the setup and eq system on marantz is also 2nd to none in my opinion in ease of use and what can achieve. many other brands are so convoluted its a joke quite frankly givens its 2020 ! for goodness sake not 1985 with needing spl meters and measuring tape and doing what not manually etc !
I am an Anthem fan because of Anthem Room Correction (ARC).  I have used ARC , and Dirac Live and rate both as among the best Room Correction Software (old but relevant article) for both movies and music.  And easy to use as well.
Unlike the big brands, Anthem releases new models every 3-5 years. And they support the products for many years. Eg. ARC 3, latest version worked on previous models released more than 6 years ago.
Yes ;a factor to consider is how long an algorithm has been in use ; ARC and Dirac have been getting better than ever before . In fact Dirac is evolving into more than a room eq system now they have incorporated bass control to meld your subs with your satellites incorporating crossover control . Mehlau lists the latest dirac3.0 firmware upgrades which takes over your bass management for you ..
Quote
Version 3 has been released on 03.06.2020. The user interface is virtually the same as in version 2 but it comes with a new feature, "Bass Control" (although technically "Bass Control" was already available in 2.5.x). "Bass Control" encompasses a number of tools for optimizing the crossover region between sub(s)/sats and seat to seat differences when using multiple subs.
"Bass Control" requires the AVR/P to run Dirac's own bass management DSP code. If the hardware supports it additional controls become available in the Dirac Live app.
"Off": Regular single speaker optimization. Bass management has to be configured by the user in the the AVR/P.
"Upmix Only": Dirac bass management replaces the AVR/P's bass management. Visualize the crossover splice between sub(s)/sats.
"Full Bass Optimisation": Same as "Upmix Only" but adds optimization of the crossover splice if a single sub is used (also applies to AVR/P's that split a single subwoofer signal to multiple outputs). If the AVR/P supports individually addressable subwoofer outputs "Bass Control" additionally reduces seat to seat differences besides optimizing the crossover splice.
  • Thanks 1
Would have to second that, I came from a older Rotel AV pre to the Marantz AV 8802a a couple of years ago and it just works and works well without any issues.
That being said my other viable AV pre at the time of my purchase to the Marantz was the Anthem AVM-60.
In terms of the amplification I use an Elektra HD 2ch Reference and Elektra HD2 7ch amp for surround channels. Again sounds great and have had no issues at all with the power amps. If I was on a bit of a budget and couldn’t buy the Elektra I’d use a cheaper but still decent Rotel Amps. I’d avoid the Marantz/Onkyo/Yamaha matching 7 to 11 ch power amps as they are really only AVR quality amps packed into a seperate box.
In the past I’ve also used Onkyo and Emotiva AV pre-amps and found both very Clunky to use and on sold both within a year of ownership.
JDH
Edited by jdh500
  • Thanks 1
+1 for this.  AVM60 is the pick in this price range.
  • Thanks 1
  • 4 weeks later...
Damn it!
I just sold my Crown 1502 unused. Should have at least hooked it up to my Anthem and checked it before selling.
To OP,
+1 for Anthem.
