USB cable - USB A to USB B for DAC
Hello SNA,
Can any one recommend a good USB cable for a DAC - USB A to USB B.
Length : atleast 2m
Budget: $100 - $200
Thank you
Edited by Nope
  • Replies 41
Popular Posts
Looks like I started something 😄
Thanks Con for the heads up with this cable. I have a AudioQuest Coffee USB and I am going to compare them. I am just waiting on my PS Audio DirectStream DAC to arrive (today woohoo) and I'll test
No, it's not you. I go on endlessly about how very few USB cables actually meet the spec. Audiophile cable manufacturers cash in on this fact and produce something slightly better at 100-1000x the cos
  • 2 weeks later...
I am not someone who likes to spend lots of money on cables but I did buy the Audioquest Carbon USB and I actually noticed a difference compared to a Light Harmonic cable I had, so was impressed. I do recommend it.
But I do love a good value so maybe you try the ones recommended above first.
  • Thanks 1
I recommend using Robertson audio cables. Here is a link to the website.
https://robertsonaudiocables.com.au/
I am yet to come across better value cables. These easily compete with much more expensive cables, for a fraction of the price! I compared their top-of-the-line XLR cable, which is the PURE SILVER - (Reference) - Balanced Symmetrical XLR Interconnects (Diamond Range) for $206 to a pair of Audioquest Wind XLR cables at $2290 and the difference was very minimal, if anything the Audioquest had an ever so slightly darker background with a more narrow soundstage but that was it. Not to mention that it took me an hour or so of testing to notice any difference.
More than highly recommend.
  • Thanks 1
OP was after USB cables! Not sure Robertson makes any???
They are not advertised but worth sending Warwick an email to see if he can make one. He might be able to, but even if he doesn't, worth keeping Warwick in mind if any other cables are needed.
This is sounding like an advert !
  • Haha 1
HAHAHA... don't worry, it's not an advertisement. I've just bought a couple of products from him and was very impressed. I forgot that he didn't advertise USB cables but had already typed most of it so thought of sending it through anyway. Just a recommendation for cables.
On 03/07/2020 at 1:02 PM, Ittaku said:
These are excellent if you're not wedded to the idea of spending as much as you've budgeted.
https://www.lindy.com.au/2m-usb-2-0-type-a-to-b-cable-cromo-line
C-ra-zy! I ordered on Friday arvo, arrived Monday morning and i am testing it now. I am testing it against cable that came with another DAC and WOW. I am genuinely impressed.
I think my old cable must have been faulty or something, its a big difference!
Thanks for the recommendation.
  • Thanks 1
You're most welcome. You would be stunned if you learned how few USB cables simply don't meet the USB specification which is pretty much the ONLY thing besides shielding that matters for a USB cable. The cheap throwaway ones almost never do. The vast majority of audio brand USB cables even into the thousands of dollars do NOT meet the spec so there's a good chance the cheap Lindy cable is better than them. You'll see that even though the USB spec says it should only be capable of 5 metre transmission, those Lindy cables come in up to 7.5 metre form, and unlike most other cables on the market, they even list those specs.
  • 0.5-5m: 0.5-400MHz < 5.8db
  • 7.5m: 0.5-400MHz < 7.0db
Edited by Ittaku
  • Thanks 1
I would recommend the $69 OYAIDE Neo d+ Class A -- https://www.mannys.com.au/oyaide-neo-d-usb-2-0-class-a-cable-2m.  These came from their Studio/DJ line have all the specs on there website and are well built for touring.  Its the best cable I have tried (note others where cheap and or printer cables).
They are double shielded, sliver coated copper (the oxygen comes free with the copper (OFC) 🤫), gold plated plugs, 90 ohm nominal impedance and have measurements on their website, triple ticks all round (pixie dust, measurements and electrical engineering).   Plus they come in pretty colours too.  Plus Absolute Sound gave them a great review to put my mind at ease too.
Like Ittaku says its important the cables are up to USB 2.0 specs.  If its not, its not a USB cable, its just a cable.
  • Thanks 2
Exactly. And if anyone's ever interested in reading the spec for USB 2 cables (I have checked it a few times) it's here: https://www.usb.org/sites/default/files/CabConn20.pdf
Pages 17-22 have the requirements to meet specification. Most audiophile cables get fancy with the wire and shielding when they break the spec, applying ideas from analogue cable construction that either don't do anything (harmless) or actually make things worse.
  • Thanks 1
I really feel like i need to post again what a revelation that $16 cable is. I really feel like i am cheating a little bit. I dont have a fancy cable comparo to do...one day i'll buy a special one and compare, but against all of the other cables i have/had its unbelievable.
I know this means all my other cables were total crap and that could just be me...or this is just a better cable?  But how many of us are using simple things like this that are either just faulty or no where near spec? or is this just me?
No, it's not you. I go on endlessly about how very few USB cables actually meet the spec. Audiophile cable manufacturers cash in on this fact and produce something slightly better at 100-1000x the cost but even then still don't meet specification.  Despite the fact you're using it in audio, it IS a data cable, with well defined requirements and specifications to make it work. Random audiophilia analogue cable ideas have no place here. Welcome to the red pill.
  • Like 3
  • Thanks 2
  • Like 4
  • Thanks 1
I received my Lindy cromo 2m usb cable few days ago.     Has been running for over 72hrs.   Works pretty well so far in my opinion.  Comparing it to my standard 'printer' cable that I have been using,  the sound does sound a bit smoother/refined.  Slightly less of an edge/hardness to the sound.      This is connection between my MS Surface pro tablet and a Gustard U16 DCC.
Today I received my Lindy USB cromo 3m, and using for last 2 hours. Waiting for good 100 hours use to see how it shines....
Edited by Masseey
  • 3 weeks later...
How'd your test go?
21 minutes ago, JPete9 said:
How'd your test go?
I don't think I gave it enough time to 'burn in' as it was a big bright over the AQ Coffee cable. I have the week off so I might do some more testing.
look out for hate mail from audio cable manufactures. who knows you might even get a letter  from Monster cable.
  • Haha 1
  • 2 weeks later...
I too gave this a go.  Needed a couple of shorter cables after rearranging some kit and grabbed two 50cm cables.  Ordered Sunday, delivered Tuesday.
Put one of these in my main listening room.  It replaced a longer wireworld ultraviolet cable.
Certainly not disappointed with a $13 cable but I have gone back to my wireworld.  More depth and detail but for about nine times the price there'd want to be 🤪
I'll put the cable in another setup in my study where it's replacing a cable of unknown origin.  Haven't tested yet but it should sound better.
Anyway, that means I have one USB cable still in its packaging that won't get used.  Lindy USB 2.0 CROMO LINE 0.5M.  PM if interested.
And thanks Ittaku - good recommendation.
I too gave t another go over the whole weekend. I played a lot of tracks I know and love. I was happy with the sound.
I then changed back to my AQ Coffee and right away me and the wife could hear the difference.
The Lindy I'd say is better than the lower end AQ cables I've tried, but the higher end cables I'd say no (in my system)
But for anything under $200 I'd use this all day long
  • 1 month later...
Happy Friday mates,
Between wireworld and Curious which is better?
Is curious evolved how much times better in comparison to yellow curious?
Thank you
  • 3 weeks later...
On 23/06/2020 at 9:08 PM, Snoopy8 said:
Try these
https://m8audio.com/product/kr-2-silver-usb/
They are suprisingly good and I prefer them to much more expensive Audioquest ones.
I just ordered a pair of these to run between a Project Streambox S2 Ultra and a Schitt Eitr replacing a generic cable that came free with something.  Hopefully I'll hear an improvement.  Will report back.
  • Like 3
I understand digital cables (well, those with RCA plugs, anyway) need to be no shorter than 1m, to work properly.  So that could be your problem, blairy?
Does the same limitation apply to USB cables, @Ittaku?  (My gut feel says it must.)
No. The problem is to do with reflections and are worse with impedance mismatching in the cable, but only when the signal is used to drive the clock of the device downstream. In USB communication, the signal is completely asynchronous from the DAC's clock which must drive its clock itself as the timeframe of USB packets is completely different from the normal DAC clockspeeds (multiples of 44.1 and 48kHz).
Aah, OK.  Tks, Con.  :thumb:
  • 2 weeks later...
On 23/06/2020 at 8:36 PM, Drunken Monk said:
Hello SNA,
Length : atleast 2m
Budget: $100 - $200
Thank you
https://www.storedj.com.au/oyaide-neo-d-usb-2-0-class-s-cable-1m?SearchID=9540562&SearchPos=12
Comes is class S (Thick) and class A (Less thick).
Cooper cores. good shielding, and separation of data and power pairs.
https://www.theabsolutesound.com/articles/oyaide-neo-d-class-a-usb-20-cable/
Edited by Grizaudio
I tested my new Oyaide class A vs a generic 2m cable tonight.
I heard no difference between my generic USB cable and my new Oyaide Neo D+ Class A.
I'm using an RME ADI 2, which uses Steady Clock FS for jitter rejection.
Interestingly I have heard differences in SPDIF cables via the same dac.
Obviously that's with my ears and system. Others may have different observations.
If there are other RME ADI 2 users here, I would be interested to know if they hear differences between USB cables.
Edited by Grizaudio
Well my ViaBlue™ KR-2 Silver USB Cable 2.0 A/B has arrived and sounds great after just 4 hours run in.  The sound is more refined (smoother, more liquid) and timbres sound more woody where there is 'wood' or more twangy where there is 'twang', etc...  I won't go on.  Keep in mind it is replacing a generic freebie.  Thanks for the recommendation Snoop!!  BTW has anyone had experience with their digital coax cables?  That would be from my Schiit Eitr to my Ayon cd player replacing a Monster subwoofer cable that is incidentally 6m long.
From Karl Schuster's review:
[I auditioned the Oyaide d+ Class A USB cable briefly each day for a week, tracking the sonic changes as it warmed up. Some days it sounded shrill, other days dull. By the fourth day, it sounded quite coherent, and encouragingly similar in many respects to the reference, but still a little sweet and euphonic in the upper octaves. I was unable to conduct any serious listening on the fifth day, but returned on the sixth day to find the residual euphonic sweetness gone. Thankfully, by the seventh day the warm-up process appeared to reach a plateau, as the sound was recognizably similar to that of the preceding day.]
Give it time, you might have caught it on one of its 'dull' days.
(I hope this isn't the end of the story - I like what I've seen of Oyaide quality, and would gladly try more).
I can't say I believe in cable burn in.
I believe this is psychoacoustic's at play.
Happy to keep an open mind.
Is that because of experience, or the science saying otherwise?
  • 1 month later...
Thanks for this!
i decided to try and put order on Friday. It arrived on Monday.
Its definitely an improvement from stock cables (although a minor one and requires AB testing). Its more detailed and tighter.
Would love to get curious usb but the money may be wiser spent on something else in my systtem.
    • By Tumpom
      Item Condition: 8/10 Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: 2095 State: NSW Payment Method: Cash on pick up or EFT Reason for selling: Upgrade I ordered this pair of Van Den Hull CSS 122 from Audio Fidelity (associated to SGR Audio) custom made to the length of 5m for the RPP of $526 in October 2013 (invoice attached). They served me very well for a pair of Vivid Audio 1.5V loudspeakers.
      Still in production today with plenty of excellent reviews online for this high value-for-money cable and one of the sweet spots in the VDH range.
      https://www.vandenhul.com/what-hi-fi-magazine-2000-cs-122-hybrid/
      The 2 conductors are made of 147 strands of 0.16 mm. diameter high purity Matched Crystal OFC with a very dense pure silver coating.
      Each conductor exhibits a cross-section area of 2.96 mm², equaling AWG 12.5.
      Covering the two conductors you find an extra Linear Structured Carbon ® saturated layer to improve the sonic performance and to transform the radiated magnetic field into an audio-signal again.
      The resistance per lead is: 0.58 Ohm/100 meter.
      The capacitance between the 2 leads is: 32 pF/meter.
      The cable jacket is made of our HULLIFLEX ® 3, a very flexible and mechanically superb insulation material.
      The insulation of the plus and minus leads is different in shape with printing in the flat middle section. Both properties are easy polarity finders. Type printing on every 25 cm. (10″) makes cutting of specified lengths very easy.
      The banana plugs are the original VDH gold plated ones I ordered with the cable, hence they do have some signs of wear commensurate to their age.
      As a bonus if interested I am adding a free set of 4 pairs of EGM gold plated banana plugs with heatshrink sleeves, all brand new and mint, should you want to change them.
      Any question please PM me.
      Thanks for watching
    • By BobbieBeat
      Item Condition: As new Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Malvern State: VIC Payment Method: PayPal (fees on buyer), Cash on pick up, Direct transfer Reason for selling: Further information:
      Selling an as new Focal Clear balanced 3m 4pin xlr cable. Bought this during lockdown to try with my Woo Audio WA11 (also for sale in seperate ad). Am selling as I am rotating my gear and just don’t need it (actually never really used it).
      PLEASE READ
    • By hiphile
      Item Condition: Used Shipping Options: Pickup available but audition is not available. Suburb or Town: Oakleigh State: VIC Payment Method: EFT, Cash Reason for selling: No longer needed Further information:
      QED Profile audio cable in 2M length in excellent condition.
      No longer needed as my new amplifier requires a different connection.
      Cheers!
      PLEASE READ
    • By hugo_wilco
      Item Condition: mint Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Melbourne State: VIC Payment Method: Paypal, EFT Cash on Pickup Reason for selling: NLR
      Further information: Bought from JD audio mid year . Have had to down grade all my gear so this has been boxed and been unused for months.
    • By Tumpom
      Item Condition: NEW still sealed Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Manly State: NSW Payment Method: EFT, cash on pickup Reason for selling: Surplus For sale, brand new, still sealed in its original bag and with connector protection on, so a good saving if you want to buy a new one at RRP $35 for the 1m length
      Also for sale the 2m length one in another ad.
      All tech info on EGM Audio website (version 2.0 of the cable)
      https://www.egmaudio.com.au/product/egm-audio-hdmi-2-0-1-metre-cable-grey-series-copy/
      Thanks for looking.
