citrusvodka
To bypass the AVR or not ... that is the ????
So I'm hopefully taking possession in a short little while, courtesy of one of the friendly folk on here, a second hand W4S ST-500 power amp that I intend to use to drive an also recently acquired pair of vintage Celestion SL6 speakers - which are quite tight and need a v.solid power source to drive.
I've currently hooked these up via my Denon X3000 Zone 2 amp which also allows the Denon to run as my DAC and pre-amp / amp for any of the inputs.
I also have an Audiolabs MDAC that is used specifically for a set of Beolab 3s and is fantastic.
With the arrival of the ST-500 power amp, my signal path will change and am wondering whether I still use the Denon as the pre-amp using the Zone 2 pre-outs or go the dedicated pre-amp path and run a second out from the MDAC to the new pre-amp to feed Sonos.
I am toying with the idea that I can switch a few settings on the Denon and potentially run the speakers as a another set of surrounds for Movie watching etc whilst retaining the flexibility but just wondering if I'm going to be tarnishing the music aspect.  Not after audio-phile outcomes and a turntable may soon be on the cards to listen to via the Celestions.
Keen for thoughts if you have the time to share them.
definitely preamp with ht bypass
Thanks for comment - do you mean use a preamp that has Home Theatre (HT) bypass (not sure what that is as I would not send HT “inputs” to the preamp) or more simply just bypass HT AVR with use of a preamp?
Something similar to this. Music source in your case would be the DAC. Allows you to run surround and good 2 channel music in same system without changing cables.
A preamp like Parasound P5, Primare i22/i32 and i think w4s have ht bypass too. Many others also out there
There is a few threads here on how to do it and plenty of others online too
How much music vs movies? And are you serious about music?
An AVR compromises music and should only be considered when you want a one box solution, have space limitations.  You appear to have no problems with space nor additional boxes. Suggest getting a preamp for music...
48 minutes ago, Bunno77 said:
Something similar to this. ...
Thanks for the suggestion - my only problem is X3000 AVR only has zone 2 pre-outs which means I can't setup these speakers as the primary R+L for HT usage.  Can configure them as extra surround speakers (haven't checked if can also do this via the pre-outs, suspect not and can only via the amplified speaker connections).
I should probably do some A/B testing between running them via the Denon DAC vs my audiolab DAC to see if the DAC differences are discernible over the Denon AMP (which is quite good at 105W per channel out of Zone 2).
@citrusvodka I just did a quick search and looks like it has preouts for L+R
https://www.trustedreviews.com/reviews/denon-avr-x3000
Also looks like your DAC has volume control so yeah maybe do some tests first with it straight from dac to w4s amp. It will be a lot better than through avr
best of luck
yep but this is Zone 2 - I can specifiy an dual front A+B HT setup in the Denon settings so maybe that would work via the w4s amp.
Regardless some fun to be had experimenting, although feeding those bloody speaker wires into the connectors at the back of the amp which sits in an entertainment unit is a PitA!
Thanks for suggestions and will report back once the W4S arrives and is properly setup
I simply use a Beresford TC-7210 speaker switch box so I can run music via DAC and class A integrated amp while sharing the speakers with my AVR for movies. It sounds FAR better than running through my AVR, and the AVR sounds better for movies. Whoda thunk it  ;)
Edited by MattyW
    • By Fabrice Dal-Cin
      Item:Denon or Marantz
      Price Range:$800-900
      Item Condition: New or Used
      Extra Info: Any leads would be appreciated.
    • By adamg
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Tugun State: Queensland Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: Time for a change – less boxes. My listening is mostly CD and streaming in the background now so I am moving on a few items while they are still in good nick to fund simplified set-up. Further information:
      Purchased from DeepHz Audio end of 2014 this amp has been faultless and IMO has been a great partner with LS50s, and in particular the Dynaudio X12s, and PMC Twenty5 22’s it has powered. What I have appreciated most is the honest musical reproduction it’s provided across the various genres I listen to, dead quiet noise floor, and build (incl. XLR input). If it had a built in phono stage I’d keep it.
      Here are the specs – there is a V2 now with more current ICE modules so have had to refer to a review.
      http://v2.stereotimes.com/post/wyred-4-sound-sti500-integrated-amplifier
      Comes with original remote, manual, power cable and packaging.
      NOTE: The amp is in perfect working order – cosmetically excellent with the exception of some minor tarnishing of a few screws and potentially a trivial mark on the front right which I’ve never noticed until looking at the pictures to post FS – see pictures. The remote has been kept in a zip lock and never used but is a sticky that seems to happen sometimes.
      Check out the Kimber Kable 8VS (3 m pair) I've listed for sale if interested.
    • By saileshpm
      Item Condition: Very good Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Stirling State: Western Australia Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: Upgrading Hi fellow SN'ers
      Up for sale is the Pioneer SC-LX86. Great multi-channel AVR as seen https://www.whathifi.com/au/pioneer/sc-lx86/review
      Would prefer local sale as I do not have any boxes/packaging - but I if there are requests from Eastern states I can try and find some boxes/adequate protection/packaging to get it across. Shipping will be via Sendle or some other agreed courier, at an agreed cost.
      Condition wise this AVR is very good aside from some minor marks and has been used for my Home Theatre set up. It was purchased as part of a package from West Coast Hi-Fi some years ago and I have now upgraded to an Anthem unit.
      Audition available in Stirling, WA if needed.
    • By Kso
      Price: $2000 Item Condition: As new Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Chatswood State: New South Wales Payment Method: Cash on pickup Reason for selling: Downsizing Further information:
      Marantz SR7012 4K atmos receiver - used about 2 years. Comes with setup mic, remote, antenna etc.
      price negotiable - make me an offer!
      Selling due to Downsizing
    • By 943
      Price: $400 Item Condition: Used - very good condition Shipping Options: Pickup available but audition is not available. Suburb or Town: Kingston State: Australian Capital Territory Payment Method: Any Reason for selling: No longer required. Only use 2 channel now. Further information:
       Pioneer SC-2022k AVR for sale. In very good used condition.
      https://www.pioneer-audiovisual.eu/eu/products/sc-2022
      7.2 Class D amplification
      7 x HDMI in
      1 x HDMI out
      Apple AirPlay
      App control
      I have all accessories, manual and remote. Also have the original box which is in poor condition but no internal packing.
      AVR has been lightly used and in storage for the past 12 months and works perfectly.
      Pickup or I could deliver in ACT. Not interested in posting.
