FS: Kef Reference, Model Three - Two CLASSIC!
Item Condition: Amazing for their age
Shipping Options: Pickup available and you can audition.
Suburb or Town: 2257 - Central Coast
State: New South Wales
Payment Method: PP, EFT, Cash on pickup
Reason for selling: Change in direction
Further information: KEF's 'Reference' series are classics, and this model was from before KEF sold out to a company in China.      I believe they date from the late 90s, but this pair is in amazingly pristine condition.  I've even included a shot of the base....you'd expect some wear-and-tear - but clean as a whistle.    Also, shots of the interior show the coupled-captivity bass units seem pristine.
I've had these speakers for several years - and they really are awesome.   Supremely natural, and bass and slam from heaven.    Treble might be ever-so-slightly rolled off at the high end, but these speakers would be absolutely ideal if your system has a a hot high end.  And  note these have a Max output of 115db!!!     That's a powerful speaker!
Spec's below.    As each speaker weights about 35 Kgs, and as I have no boxes, I'm afraid this is almost certainly a local pickup job.    Talk to me of you have an alternative option.
Pricing.  These speakers are rare as hen's teeth, and these two are in amazingly good shape.    I believe in the late 90's they were maybe around the $15K mark (?) so $2K seems fair to me.     Some more info:
https://us.kef.com/explore-kef/kef-museum/1990s/reference-series-models-one-two-three-four
Specification: Model Three
System type: Four-way, floor standing
Enclosure type: Twin coupled cavity
Size: 1137 x 275 x 340mm (44.8 x 10.8 x 13.4 inches)
Weight: 35kg (77 lb)
Nominal Impedance: 4ohms
Amplifier requirements: 50-300W
Frequency response: 40Hz to 20kHz +/-3dB at 2m on reference axis
Sensitivity: 91dB at 1m/2.83V (anechoic conditions)
Maximum output: 115dB on programme peaks under typical listening conditions
System: SP3187
Drive units: 2 x B200 bass unit (SP1343), B160 lower midrange unit (SP1348), B160 midrange unit (SP1345), NT25 tweeter (SP1353)
Crossover: SP2225
System: SP3246 (with boundary compensation device)
Crossover: SP2256
  • Like 3
Absolutely superb speakers, give them a decent amplifier and they will leave you mesmerised.
Can you let me know why the original rubber surrounds of the Uni-Q drivers were replaced and the dust caps are now covering the high frequency drivers
Looks like there been reformed with foam instead of rubber and have covered the high frequency drivers
Should be a nice sounding speaker.
Up to about 4 weeks ago I had the KEF Reference Model One from the same era (only single driver on the front as opposed to 2) as overkill computer speakers.  Gave them to Parents in Law for music and HT purposes and they really do sound nice. These would have to be better!!
Timber finish looks great and these speakers can get chips on the black painted surround on the bottom. So these are in a nice condition.
GLWTS.
Those rubber surrounds don't often deteriorate (except for some extreme circumstances). The bass drivers still have the original surrounds however.
I can't comment on your claim that the "original rubber surrounds" on the midrange drivers "have been replaced".    However, I can ASSURE you that the tweeters have NOT been covered over with "dust caps".     The coaxial Uni-Q tweeters are protected by an dark acoustically transparent cloth.  Sadly the flash I used has meant that this make them look a little unusual.   However, in the top pic you can see some glints of the underlying drivers.     Also.....at least one of the others who commented on these has actually owned this model...and he dodn't see anything amiss.
Ok thanks replying
I could be completely wrong but I googled these something looks different with the top speaker cone?
nice looking though gwts
As I said before I owned these before... The uniQ was open on mine and I am not aware of any that were covered with a dust cap. The rubber surrounds Never deteriorate and these clearly have foam replacements.
I would hazard a guess one of them was repaired at some point and the other done for continuity or possibly both needed repairs, and probably before you came to own them.
I would still buy these in a heartbeat replace the rubber and remove the dust covers from the tweeters
The only concern I would have would be if the tweeters were replaced with something else but from memory if you need to replace the tweeters you need to replace the whole driver... Could be wrong though
Thanks Cambam.      I have owned these for several years, and they are exactly as I bought them.    As I said elsewhere, the top driver definitely doesn't have a "dust cap" over it - its a fabric protective dome.      And there is most definitely a tweeter under that cloth because I've (VERY carefully) placed something over that area when they are running - and you can immediately hear the high treble being cut out.    So there is absolutely a Uni-Q tweeter under their.      The cloth is there simly to protect the tweeter....much like newer KEF's have the tangerine wave guide over the tweeter.   So I have no evidence that the top driver pair was ever replaced or modified, and (most importantly) it sounds absolutely fine.
This is it, it's all how they sound at the end of the day.
I would happily take these over almost anything 3 times the price.
The mid range and sound stage is unreal when properly driven
Actually I do remember mine had transparent dome over the tweets also but there was a distinct gold ring around the tweeters that yours seems to be covered. It's not unheard of for kef to change things up mid production and there were a couple of different versions of the 3.
I had a pair of 104 that came standard with rubber on the mids and foam on the bass drivers  so again, I wouldnt be surprised if it was stock standard but my pair had rubber both top and bottom
Edited by cambam007
So there we have it !
i would buy these is they were original !
i am sure they still sound great hope op sells them soon
OK - so let's maybe get to the bottom of this.    I just managed to take a picture of the Uni-Q tweeter.  It's maybe not the clearest, but I believe it show exactly what should be there - a centered tweeter with a steel ring around it.   I shone a torch through the fabric dome, and the tweeter is quite visible.      As CamBam said, often the manufacturing process can change over a unit's life.    It's likely KEF decided that adding an extra cloth dome gave the tweeter more protection.  And as CamBam also pointed out...its the sound that counts.  They sound wonderful.
  • Like 5
  • Love 2
I haven't heard the R900 but if you can get a pair for 2k I want your source
There is a direct lineage and the r3 was made during kefs hayday, also being top of the line.
In my opinion as far as kef goes the older stuff was top of class for its time and the new stuff is while very good is over priced
I had a r600c centre and it was very good, match for the r3, I would say side by side it would be hard to justify the price difference between the r3 and r900
Ive attached what my model one looked like..might help!?!?!.. just wish I cleaned them before this photo. It was just to quickly show my parents in law what they looked like before I took them over there.
Edited by 3dl3
    • By missmurphy
      Item Condition: Good Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Cronulla State: NSW Payment Method: Cash eft PayPal Reason for selling: No longer need Three genuine ef 86 telefunken input pentode valves
      these are the last of my ef86 tellys
      genuine tubes with diamonds on the base
      PLEASE READ
    • By Smp
      Item Condition: Excellent, as new - cosmetically and operationally perfect Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: WA Payment Method: Pick up - cash, bank transfer Reason for selling: Upgraded up the Lamm line Further information: Original purchaser of this great , all valve linestage - current set of valves have not seen too much use as the unit has been rotated with other pre-amplifiers. Operationally dead quiet. Comes in it's factory wooden crate with manual. Lamm doesn't do remote controls.
    • By Smp
      Item Condition: Cover VG+/Vinyl M- Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: WA Payment Method: Pick up - cash, bank transfer Reason for selling: NLR Further information: Mobile Fidelity #MFSL 2 - 013. Long since out of print. Recorded in 1978 and pressed in Japan on JVC Super Vinyl. Double live album with gatefold cover. Outer sleeve is showing a little wear which can be seen in the photos. Vinyl is in pretty well mint condition, but rated as mint minus as it is not a sealed copy. New plastic outer sleeve and cleaned in a KLA Audio Ultrasonic RCM KL200.
    • By Smp
      Item Condition: Excellent, as new - not a mark Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: WA Payment Method: Pick up - cash, bank transfer Reason for selling: Surplus to needs Further information: Purchased these from the Australian Distributor - 220/240 volts, Fifteen (15) W 300B single ended triode purity. Have the original boxes, packaging and manual. Replaced the the two pairs of stock 6SL7 valves with a matched pairs of NOS JAN RCA VT229 valves from Brent Jessee Recording and Supply ($375). Also will supply a new matched pair of unused EAT 300B valves (pictured in amps) which I had as spares - these are new valves which now have a RRP of in excess of $2,500. These are the last version of these amplifiers (series 3) designed by Dennis Had. The speaker terminals are switchable between 4 and 8 ohms (external switch). RRP at time of purchase $8,800.
    • By Smp
      Item Condition: Mint - / Mint - Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: WA Payment Method: Pick up - cash, bank transfer Reason for selling: NLR Further information: Mobile Fidelity # MFSL 1 - 031. long since out of print. Recorded 1972 and pressed in 1981 in Japan, with gatefold cover, Vinyl is pretty well mint condition, but as it is not sealed it must be rated Mint -. New plastic outer sleeve and cleaned in KLA Audio Ultrasonic RCM KL200.
