PKay
FS: Rotel RA-1070 Integrated Amplifier
Item Condition: Excellent
Suburb or Town: Artarmon or Forestville
State: New South Wales
Payment Method: cash, EFT, Paypal as friend
Reason for selling: Not used
Further information:  I am selling this amp for my brother - it is in excellent codition with very little use. Postage is available as my brother has the original boxes but local pick up is preferred.  See 3rd picture for little mark which is hardly visible.
 Review from TNT
There has always been an inherent rightness about the idea of an integrated amplifier. The efficiencies are impressive, the compromises mostly imagined. With the modern additions of display and a properly implemented remote control the integrated becomes all the more appealing. Now there are integrated and then there are integrateds: The sometimes classic (Naim) and sometimes overrated (fill in the blank) British offerings are not what I have in mind. For some reason, the Brits just don't seem to get the fact that an integrated needs real world power to be of real world use. Rotel is a company that knows how build high powered amplifiers, so when I found out that their flagship RA-1070 was said to be happy driving a tough 4 ohm load, I was quick to request a sample.
The RA-1070 is the latest in a spate of offerings wherein the product's look and performance really threaten a redefining of the high end. There was a time when such a product would have cost well over $2000. While the old guard high end companies have product lines that continually reach higher and higher, the larger mid-level companies seem willing and able to supply more music for the dollar. It may be time to ask why...
rotel1070.jpgThis is a very attractive piece of gear. My review sample is silver and black, but the 1070 can also be had in the more traditional all black. The faceplate of the unit is cleverly designed to suggest a more hefty look through the use of substantial black aluminum handles. In fact, the silver center section of the face is quite thin (as is the top cover) yet the unit looks and feels quite solid. A large motor-driven volume pot dominates the face. When operational, there's an illuminated section that indicates its relative rotational position. In an interesting nod to the days of tone & loudness controls, there's a four position contour control which allows for accentuation and attenuation of bass and treble. I left that control in the off position for all of the evaluation period. The rear panel is well laid out with proper 5-way binding posts situated near the center of the panel making it easy to connect even the most unwieldy cables. The usual IEC 320 connector is used, but in an odd twist, this Rotel floats the ground: This is very likely of no concern in typical use, but could be an issue in systems requiring a specific grounding scheme or extensive use of truly balanced devices.
The RA-1070 uses a relay as a turn-on/off stabilization device and also as a protection device in case of overheating or shorted cables. The relay can be clearly heard when powering the unit up and down. With the exception of the speaker and contour control switches, all of the RA-1070's functions can be controlled by the superb remote. This is truly a wonderful remote...it can readily learn the remote codes for all of your other gear and allows you to use the Rotel remote to control an entire system. It is also possible to customize the unit's display to indicate associated equipment by specific name rather than type. The only negative that I should mention is that while it is possible to turn the somewhat bright display off, the unit isn't designed to remember that setting. So, the very next time the Rotel is turned on the display again needs to be turned off. This is a real shame as the display off setting is very well implemented. With the display in the off position, the display momentarily illuminates whenever a control is changed. Once the change is complete the display goes out. On a teeny-tiny but slightly tacky note: The motorized volume pot indicates that the RA-1070 is in mute by flashing its position indicator. While effective, I find this solution better suited to products of a lesser pedigree than Rotel.
Sound
The Rotel RA-1070 is a very suave sounding piece of gear. Right out of box it has a sound that is relaxed and assured. There are absolutely no hi-fi dramatics to this amp just a competent and musical presentation. The unit looks like it sounds like it functions...sensibly, controlled and without fanfare. The essential test of tone and timber that I like to use first is the Byron Janis. The piano is clear and open with a slightly soft presentation. It is less than muted but less authoritative than it should be. Overall tonality is quite good bordering on excellent. At well over 100 watts into 8 and 4 ohm loads, it sounds even more powerful in use than the ratings would indicate.
Iris DeMent's voice is possessed of its usual plaintive clarity if again just slightly softened. There was no aspect of the voice's fundamental or attack that was lacking but rather a subtle sense of shading toward the warm and dark. Now, on the period strings of the Corelli, the sound was quite open and pure with an excellent sense of space and air. The guitars of Krushevo were also recreated with an appropriate portrayal of acoustic speed and timbre.
It is sometimes possible to go too far in one direction and I felt that the Rotel RA-1070 was less prone to this softening when used with my usual digital reference rather than the also excellent RCD1070. It may be that my system's overall resolution requires just a bit more raw musical information that the Rotel combination can create. More than anything, this is likely to be a matter of personal preference and perhaps most importantly the room/system interface. In any event, I appreciate the RA-1070 more when using my reference digital rig and analog.
Ah, analog
I will rue the day that there are no more phono stages. One of the most appealing qualities of the Rotel RA-1070 is its lovely phono stage. It is really quite excellent. The Sonny Landreth pressing quickly reveals the essence of a phono stage. First of all, it is dead silent. A noisy phono stage will overlay a hum over the blackness of the virgin vinyl. The phono stage of the 1070 is fully capable of differentiating a good pressing from one made from old combs. The Landreth LP has some wild dynamic swings from cut to cut. The Rotel really handles the range with aplomb. In contrast to the linestage's less assertive style, the phono stage of the 1070 is incisive and full of verve.
As I got the Rotel RA-1070 ready for the return trip to Rotel, I had to make my system ready for some fairly large, typically high end separates. I was miserable. Not only was I going to miss the functional simplicity of the Rotel and its remote I was already missing the elegance of having all of the voltage gain and current swing in one box. Here I was on my hands and knees looking for interconnects and power cords while trying to fit the new separates into the swollen component rack. There, on the floor, the Rotel RA-1070 was staring at me as if to say, there is an easier way!
There's just no arguing the fact that using an integrated amplifier makes for a more simple system. What the Rotel RA-1070 proves is that such convenience does not have to come with an unbearable loss of musicality. The 1070 is comfortable with tough loads and very easy to listen to and there is just no way to complain about its design and functionality. Maybe someday I will retire from reviewing. When I do, it will hopefully be an easier and simpler time...a time, I hope, of music. When that day comes it would be a pleasure to spend my time listening to the Rotel RA-1070, the bother and hassle of separate components just a distant memory. Until then, I trust that you'll get out and try to hear the 1070. You may find that the simple life of the Rotel RA-1070 is for you. Highly recommended.
© Copyright 2003 M. L. Gneier - https://www.tnt-audio.com
HTML by: Andrea De Marco
SPECS
AUDIO
  • Response Bandwidth
    4 - 100000 Hz
  • Signal-To-Noise Ratio
    102 dB
  • Total Harmonic Distortion
    0.03 %
AUDIO SYSTEM
  • Type
    amplifier
  • Subcategory
    audio components
  • Functions
    amplifier
  • Sound Output Mode
    stereo
  • Additional Features
    A/B/A+B speaker switch
  • Tone Control
    Yes
POWER DEVICE
  • Power Consumption Operational
    400 Watt
HEADER
  • Brand
    Rotel
  • Product Line
    Rotel
  • Model
    RA-1070
  • Packaged Quantity
    1
BUILT-IN DISPLAY
  • Type
    fluorescent
MISCELLANEOUS
  • Color
    black
  • Color Category
    black
AMPLIFIER
  • Input Impedance
    33 KOhm
  • Input Sensitivity
    1.5 V
AMPLIFIER OUTPUT DETAILS
  • Output Power / Channel
    100 Watt
  • Output Impedance / Channel
    8 Ohm
  • Frequency Response
    20 - 20000 Hz
  • Total Harmonic Distortion (THD)
    0.03 %
  • Channel Type
    main
  • Channel Qty
    2
INPUTS & OUTPUTS
  • Headphone Jack
    Yes
REMOTE CONTROL
  • Type
    universal remote control
  • Remote Control Technology
    infrared
ACCESSORIES
  • Remote Control Type
    Universal remote control - infrared
  • Features
    LCD display, learning
AUDIO SPECIFICATIONS
  • Type
    Amplifier
    4 - 100000 Hz
    102 dB
POWER
  • Form Factor
    internal
BATTERY / POWER
  • Type
    power supply
CONNECTIONS
  • Qty
    1, 2, 3, 4, 7
  • Type
    audio line-in, audio line-out, headphones, network, phono input, preamplifier out, remote control, speakers output, trigger
  • Connector Type
    RCA x 2, RJ-45, banana/spade x 2, phone stereo 6.3 mm
  • Connector Location
    front, rear
DIMENSIONS & WEIGHT
  • Width
    16.9 in
  • Depth
    14.2 in
  • Height
    4.8 in
  • Weight
    22.71 lbs
GENERAL
  • Manufacturer
    Rotel of America
Edited by PKay
Hi there, how old is this machine?  Thanks, guillaume
2006. It has been hardly used for the last 10 years (around when he married). I used it for a week while my amp was away For a review and it was fine.
@Sebastian Long  this would work for you I think.
    • By lancer181
      Item Condition: Never been used like new Shipping Options: Shipping is available at agreed cost. Suburb or Town: Christchurch State: New Zealand Payment Method: Bank transfer Reason for selling: Further information:
      Duelund crossover parts . never been used. Not really wanting to split anything .
      6.8 uF cast pure copper foil VSF audio capacitor x 2
      2.2 uF cast pure copper foil VSF audio capacitor x 2
      3.3 uF cast pure copper foil VSF audio capacitor x 2
      4mH 12 awg premium air core audio inductor cast pio-cu x 2
      1 mH 12 awg premium air core audio inductor cast pio-cu x 2
      20 uF cast cast pure copper foil VSF audio capacitor x 2
      22R0 silver / graphite resistor cast x 2
      10R0 silver / graphite resistor cast x 2
      4R7 silver / graphite resistor cast x 2
      47R silver / graphite resistor cast x 2
      2R0 silver / graphite resistor cast x4
      0.01 uF ag 600vDc precision audio capacitor pure silver foil
      200uF cast Mylar x 2
    • By Island boy
      Item Condition: VGC Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Dalyston State: Victoria Payment Method: EFT Reason for selling: To many cartridges Further information:
      early original Decca maroon cartridge, very good condition,
      brought from a member a while ago
      low hours I would say no more than a 100, no box or paper work, but can supply a appropriate box for postage
      PLEASE READ
    • By Island boy
      Early original Decca gold with vdh stylus in very good condition, bought of original owner who bought it back from the uk.
      50 hours max.
      comes with box and paper work
      PLEASE READ
    • By dddesy
      Item Condition: GOOD Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: SYDNEY State: New South Wales Payment Method: paypal plus fees or as a friend,EFT,cash on pickup Reason for selling: not used Further information: Teac vrds7 is one of the genuine hi-end vintage cd players.These rarely come up for sale.Comes with the original remote control.Has some light scratches on the back plate as seen in pictures, apart from that it is in good condition.It has served me well with it's smooth,warmish sound and big open soundstage.New laser was fitted late last year and has hardly been used since.While I was waiting for the laser, I decided to try streaming and have been streaming ever since.I used the cd for about 50hrs with the new laser and since then it has been sitting on the shelf.Perhaps it's time to let it go(reluctantly)so someone else can enjoy it.
      Would prefer local pickup due to size and weight,however if no local interest will consider shipping at agreed cost
      PLEASE READ
    • By karmakat
      Item Condition: used very good Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Ashfield State: New South Wales Payment Method: PayPal, cash Reason for selling: NLR Further information:
      Audio Technica AT95E Elliptical Moving Magnet Cartridge.
      I bought these 2 cartridges from Thomas Thakkers shop in Germany in 2013.
      They haven't had much use, are in great condition and ready to add a stylus. They were made OEM so have no identification on them, apart from "made in Japan".
      Collect from Ashfield or can post.
      PLEASE READ
