Item: Sonance Sonamp 275se Power Amplifier
Price Range:$100-$150
Item Condition: New or Used
Extra Info:  I am looking for a second amp as I want to power separate speakers with a second unit in bridge mode
Edited by Audiofooled
    • By Mr.Anderson
      Item: ARCAM P777 Multi Channel Power Amplifier
      Price Range: $1700
      Extra Info: Looking for this amp in good condition.
    • By PG2019
      Item Condition: Very Good Shipping Options: Shipping is available at agreed cost. Suburb or Town: SE Suburbs State: Victoria Payment Method: EFT Reason for selling: NLR Further information:
      Selling my Bryston 4BSST2 + MPS2 + BP26, the complete set was brought from Carlton Audio Visual in 2016.  It still has 16 years warranty remaining on the units. Unfortunately, I do not have the original packaging, but can organise shipping.  The units are in very good condition, no remote is included as this was a factory option from Bryston.
      If you have questions please do not hesitate to contact me. Willing to separate, but preference given to those wanting to buy the complete set.
      PLEASE READ
    • By ikwong
      Item Condition: Mint Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Adelaide State: South Australia Payment Method: Paypal + fees, EFT, Cash on Pickup Reason for selling: NLR Further information:
       The Rotel RB-1582 MKII amp (RRP $2799) is in perfect working condition and is pristine in appearance.  The unit was purchased from a local dealer in late 2018. My job roles changed since the purchase and I barely have time with my gears since.
      The unit is extremely well taken care of and was covered with cloth while not in use (I tend to be away from home for weeks!).
      The amp is barely used for 120 hrs in total. So, make sure you allow more burn-in time.
      I have all the original boxes, manuals etc.
      Details:
      Rotel’s largest stereo amplifier at 200 watts per channel provides the massive current to drive the very largest hi-fi systems effortlessly. And like its smaller brother, the RB-1582 MKII has been designed to excel at resolving the subtle details in music as well as supplying the brawn required for extremely dynamic passages. It is able to achieve this difficult dual requirement because of the meticulous attention paid to circuit design and parts selection.
      The RB-1582 MKII ‘s high-end performance begins with an extremely large toroidal transformer combined with a total of 60,000uF storage capacity in special “slit foil” capacitors to provide completely stable power to the output stage. Slit foil capacitors have the ability to charge and discharge extremely quickly, thereby ensuring signal fidelity during orchestral crescendos or repetitive kick-drum impacts, for example. Both left and right channel construction are laid out in a mono block design (after the toroidal transformer) and all grounding is terminated in a star pattern on a copper grounding plate to ensure low signal to noise. The output stage is a discrete design that consists of 10 high current bipolar transistors per channel. Input options consist of both balanced XLR and unbalanced RCA connectors.
      The RB-1582 stereo power amplifier is yet another outstanding example of Rotel’s Balanced Design Concept and will form the heart of a very impressive stereo or home theater system for years to come.
      Specifications:
      Power Configurations: 2 x 200 watts (20Hz-20kHz, <0.03%, 8 Ohms)
      Watts/Channel: 200 watts, all channels driven, 8 ohm load, 20-20kHz
      THD (20-20,000Hz) 8 Ohms, all channels driven: < 0.03%
      IM Distortion: < 0.03%
      Damping Factor (8 Ohms): 1000
      Input Sensitivity / Impedance: 1.5V / 32kOhms
      Frequency Response (+/-1dB): 15-100kHz (+/-1dB)
      S/N Ratio (IHF A): 116dB
      Power Consumption: 550 watts
      Dimensions (W x H x D): 431 x 140 x 406 mm
      Front Panel Height: 3U (5.25”)
      Shipping Weight: 18.5 Kg
      Finish: Silver
    • By alex117
      I am looking to a power amp ( no controls requiring preamp to use) for  3 pairs of  Definitive Technology ceiling speakers for effect (4) and rear center (2)
      (Main R/L/C are Meridian  M60, and pair of M33)
    • By youngjimmy
      Item Condition: As New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Carlingford State: New South Wales Payment Method: EFT, Cash on pickup Reason for selling: no longer needed Further information: 2 x 20 watts RMS into 4 ohms. Sounds much bigger than its spec would suggest. This amp is as new, in original carton, with its under desk mounting bracket
      PLEASE READ
