Phatz 1 Posted June 4, 2020 Share Posted June 4, 2020 I have a Bluesound Node 2i connected to a Cyrus One HD via RCA interconnect cables. I stream music from both iTunes and Tidal from my iMac and iPhone wirelessly. Even though I’m fairly impressed with the sound output I’m wondering if I’ve connected and set everything up to best optimise sound quality? Much appreciated. Peter Link to post Share on other sites
cafe67 3,919 Posted June 4, 2020 Share Posted June 4, 2020 @Phatz These 2 articles might help https://darko.audio/2018/01/further-travels-with-the-bluesound-node-2/ 1 Link to post Share on other sites
Hi-Fi Whipped 1,138 Posted June 4, 2020 Share Posted June 4, 2020 1 hour ago, Phatz said: I have a Bluesound Node 2i connected to a Cyrus One HD via RCA interconnect cables. I stream music from both iTunes and Tidal from my iMac and iPhone wirelessly. Even though I’m fairly impressed with the sound output I’m wondering if I’ve connected and set everything up to best optimise sound quality? Much appreciated. Peter A very good start, also try sending a digital signal out of the node to the Cyrus using coaxial or toslink connection, then switch between inputs to determine which one you like best. 1 Link to post Share on other sites
Phatz 1 Posted June 5, 2020 Author Share Posted June 5, 2020 23 hours ago, cafe67 said: @Phatz These 2 articles might help https://darko.audio/2018/01/further-travels-with-the-bluesound-node-2/ Thanks Link to post Share on other sites
Phatz 1 Posted June 5, 2020 Author Share Posted June 5, 2020 23 hours ago, Hi-Fi Whipped said: A very good start, also try sending a digital signal out of the node to the Cyrus using coaxial or toslink connection, then switch between inputs to determine which one you like best. Thank you, I'll give your suggestion a try 1 Link to post Share on other sites
