Hey folks,
I'd be grateful for a little guidance in pinpointing a voltage problem with my AU-4900 please.
Having read dozens of forums here on SNA and on AK, I've tried all of the known weak points (I think). It seems my issue is not uncommon so I hope I'm just missing something simple. I'm especially thankful for the knowledge shared by @skippy124  - I thoroughly enjoy your work John!
I'm handy with a soldering iron and have all the common test equipment and my trusty DBT.
Problem: Amp won't come out of protection mode due to high voltages on Left output devices.
Initially, I was able to adjust the VRs to get the bias set correctly but then protection kicked in.
As the voltages to the Right amp section seem good and the PS section is sending the correct voltages out, my first thoughts was that this is a protection circuit issue. I've basically replaced all components in the protection circuit, to no avail.  I've also replaced all of the transistors on the tone board and 90% on the amp board and all diodes on the amp board bar the Zener (on order). Replacing components has not fixed the issue, nor made is worse.
I've attached a circuit diagram of the protection circuit with some voltages (via a DBT).
Here are the components I've replaced:
Amp Board
D01, 02 -> 1N4148
D605, 607-615 -> 1N4007G
TR601, 602 (SDC1364) -> KSC1945CGTA
TR15, 16 (2SC711) -> KSC945CGTA
C602 -> 1uF 63V WIMA MKS2
C604 -> 470uF 25V Panasonic FM
C605 -> 100uF 50V Panasonic FM
TR601, 602, 602 (2SC1364) -> KSC945CGTA
TR03, 04 (2SC1951) unchanged and tried swapping from a working 4900
TR05, 06 (2SC711) unchanged and tried swapping from a working 4900
TR07, 08 (2SD438) -> KSC2690AYS
TR09, 10 (2SB560) -> KSA1220AYS
TR11, 12 (2SD188A) unchanged
TR13, 14 (2SB545A) unchanged
IC1, 2 (dual 2SA798) -> paired KSA992FTA with matching Hfe
Fusable resistors R37,38,39,40
I've also swapped out the 4 germanium diodes from a working 4900.
Tone Board
All (2SA726) -> KSA992FTA
All (2SC1313) -> KSC1845FTA
Voltages on output devices:
TR14 E= -29.5mV, B= -629mV, C= -29.6V
TR13 E= 24.75V, B= 24.75V, C= -29.62V
TR12 E= 20mV, B= 600mV, C= 29.68V
TR11 E= 24.78V, B= 24.95V, C= 29.68V
I've even tried removing the output devices but that has no effect on the Left voltages.
Any other measurements that would be helpful for diagnosis, please shout.
Thanks in advance.
Brad
Edited by ampaddict
Check R35, 6.8ohms, these are known to stress out/appear somewhat chalky. Replace with higher wattage unit. Diode test TR09(amp powered off) and also measure Vdc at TR09 b and e to GND/chassis.
Edited by mbz
b and e to GND
thanks Mike.
R35 checked spot on 6.8. I don't have a replacement to hand but I do have a 6.2ohm .5W carbon.
TR09 diode tested fine when removed and here are the gnd Vdc readings:
E = 23.98V - 24.15V fluctuating
C = 23.95V - 24.55V fluctuating
B = -29.35V stable
I'm recapping as I go, so perhaps the fluctuation is the caps settling in?
Edited by ampaddict
B = -29.35V stable
Double check those voltages. TR09c is connected to the negative B3 "rail", nominally -35Vdc. c=e points to a short but probably a sucker bet. You can always compare with the working channel TR10. TR09b should be about -1.5Vdc
Nah... failed silicon...
Also measure TR03 and TR05 b,c,e to GND voltages, trying to find a "normal" voltage then work forward...
Edited by mbz
TR03, TR05
Double checked and same. Using a DBT so may explain the lower voltages?
TR10 looks a little more normal e= -.063V b= -1.2V c= -29.35V
TR03 e= -29.33V b= -29.35V c= 24.85V
TR05 e= 24.90V b= 24.96V c= 25.05V
TR03 looks suspect Vbe, it's not conduction which stuffs up TR05 Vbe and also TR07b, no current flow/volt drop across R15, R17. You could diode test TR03 but I'd replace it. SM has it as 2SC1951, is that what's installed. Will do a search for subs...
AK suggests ZTX694B as a good replacement for 2SC1951. KSC1815, KSC1845 would probably melt, you could try them as a test but prefer to chase the ZTX...
I swapped out the 2SC1951 with same from a working unit as I thought they looked sus. I have ZTX694B on order from E14. There's something else causing all these discretes to appear shorted I think. Pulled the Zener ZD601 (EQA01-13R) and diode tested OL one direction and 0.67V the other - that seems ok.
Edited by ampaddict
That would leave IC1, correct pinout on KSA992's? Check emitter voltage
pickle me Grandma! I swapped out IC1 and 2 from the working unit and all is fine. You were right, it must have been my poor pairing of the KSA992's. I'll go back and redo the KSA992 pairs carefully, as the 2SA798's in the ICs are noise prone. Thanks for all you help Mike, you're a legend!
to confirm I stuffed up one of the KSA992 pairs, I had the bases connected, instead of the emitters. Thanks again!
    • By Gurcharan
      I have rotel rb-981 power amplifier..However it powers up and protection light goes off.
    • By blacktopspirit
      Item: Sansui AU-4900 Amplifier
      Price: SOLD
      Item Condition: Used, requires repairs
      Reason for selling: Not required
      Payment Method: Pickup - Cash, Paypal.
      Extra Info: Cleaned it up to use after pulling it out of the cupboard, but it has static on both channels, otherwise everything else seems to work. Repairing circuit boards isn't my forte, so hopefully someone else can find a better use for it. I may be persuaded to post it, but freight will be around $30 via Direct Freight.
