repiet Posted June 2, 2020 Share Posted June 2, 2020 (edited) SOLD Item Condition: used but in as new condition Shipping Options: Pickup available and you can audition. Suburb or Town: Sydney State: New South Wales Payment Method: Cash, Paypal Reason for selling: upgraded to the big brother Further information: Sub is in great condition and has been purchased December last year. Selling due to upgrading to PB-16 Ultra. Subwoofer Specs: Premium Black Ash and Piano Gloss Black finish options Protective non-resonant steel mesh grille Front-firing 13.5" driver Rear-mounted amplifier Screw-in rubber feet Robust Medium Density Fiberboard(MDF) cabinet construction Cabinet Dimensions (without grille): 18.3” (465mm) H X 17.8” (453mm) W X 18.6” (471.3mm) D Cabinet Dimensions (with grille): 18.3” (465mm) H X 17.8” (453mm) W X 20.9” (530mm) D Shipped Dimensions: 23.5” (598mm) H X 23.5” (598mm) W X 28” (712mm) D Weight (unboxed): 102.3 lbs. (46.4 kg) Shipped Weight: 117.8lbs (53.45kg) Driver Specs: High-performance SVS 4000 Series Subwoofer Driver - optimized for sealed cabinet design. Proprietary 13.5” Driver with finely tuned Overhung Motor Configuration 43lb (19.5kg) pound Woofer with 37.7lb (17.1kg) pounds for the motor Overhung 52mm Xmax, 76.2mm Xmech precision aligned excursion 8-layer aluminum flat wire edge wound 3” voice coil for ultra-low distortion, efficient heat dissipation, exceptional linearity and nearly zero power compression. Two massive, dedicated toroidal ferrite magnets generate unparalleled levels of magnetic force to drive the highest levels of excursion, SPL, and start/go power for the deepest and most authoritative bass possible. All-new High density FEA-optimized cast aluminum basket provides unequaled levels of rigidity, tensile strength, and energy transference available from a subwoofer. Dual 24-strand copper and Nomex composite high-temperature leads woven through the suspension provide a pristine electrical connection from the amplifier to the voice coil. Premium glass fiber laminated dustcap and reinforced and vented paper-composite cone sub-structure ensure a light, rigid, and neutral radiating surface. Precision machined motor elements and narrow tolerance suspension parts produce unmatched linearity at full excursion for exceptionally tight and fast output, even at reference volumes. Extreme oversized low carbon vented steel U-yoke and top plate provide superior cooling and improved magnetics for maximum performance and efficiency. Copper ring shorting sleeve reduces gap induction and distortion, enhances thermal conductivity Nickel-plated high-tension spring terminals Proprietary injection molded gasket and parabolic SBR extreme-excursion surround maintains ideal pistonic motion for pinpoint accuracy and control Low carbon 1008 steel components with black electrophoresis plating Amplifier Specs: Massively powerful Sledge 1,200-watt continuous Class D design with 4,000+ watts of Peak Power. Unmatched intelligence from user adjustable low pass, phase, polarity and room gain compensation with three parametric EQs and port tuning (Ported models only) for absolute best alignment with speakers and optimized performance in any room. Groundbreaking SVS Bluetooth DSP control app for iOS and Android devices with three user presets allow custom tuning for every room and system. High efficiency cool-running Class D switching topology with massive 32 Amp 600 Volt MOSFET’s result in lower EMI and highest efficiency while providing effortless power to produce SPLs and low frequency output with pristine clarity well beyond reference listening levels. High resolution 50Mhz Analog Devices Audio DSP with double precision 56bit filtering is most advanced subwoofer processor available for perfect audio reproduction. 100v-240v full range input active Power Factor Correction (PFC) pre-regulates mains to solid 360V DC regardless of mains voltage or quality so the sound quality never falters no matter what’s coming out of the wall Active PFC lowers average current and smooths mains input current allowing for 1200W output from a standard 15A mains circuit. XLR and RCA stereo input/output with ultra-wide input voltage for consumer and professional audio applications. Convenient front-mounted display featuring new Intelligent Feature Control (IFC) with bright blue dimmable/defeatable 8-digit LED front display. Custom EQ and DSP limiter settings tuned specifically for the SB-4000 sealed cabinet design. Auto/On and 3-30V AC/DC trigger for Maximum Installation Convenience. Input impedance 22kohm (unbalanced RCA)/ 22kohm (balanced XLR). Green 0.5-watt low standby power consumption RoHS compliant, lead-free construction, world-wide safety certifications SVS App Specs: The most powerful and flexible Bluetooth controlled subwoofer DSP app, works with both iOS and Android operating systems. Easiest and most convenient way to adjust crossover frequencies, parametric EQ, polarity, room gain and all other bass management functions. Three convenient custom presets allow for perfect tuning in any room or system, from your favorite seat. Single tap adjustment for controlling variable port tuning with standard, extended and sealed modes. Unique bidirectional feedback shows adjustments in real time on both app and subwoofer interface. Easy-to-follow tutorial provides clear guidance for all functions. Photos: Advertisements without photos of the actual item will not be approved. Edited June 2, 2020 by repiet Link to comment Share on other sites More sharing options...
tim_tam87 Posted June 2, 2020 Share Posted June 2, 2020 Any idea how much postage would be to Melbourne, Victoria...I presume an arm and a leg based on the size and weight? Link to comment Share on other sites More sharing options...
repiet Posted June 2, 2020 Author Share Posted June 2, 2020 7 hours ago, tim_tam87 said: Any idea how much postage would be to Melbourne, Victoria...I presume an arm and a leg based on the size and weight? I'm not sure but I could imagine it would be too expensive to make it worth it. I would suggest to inquire with a courier service to get a rough idea. FYI I did not keep the original box but still have the packaging material (foam) so I should be able to pack it up safely. Link to comment Share on other sites More sharing options...
kamielcat Posted June 2, 2020 Share Posted June 2, 2020 Try E-go - depot to depot. Should be affordable if both parties are happy to drop and pick off at depots. I think you can save 40 percent on shipping cost this way. 2 Link to comment Share on other sites More sharing options...
hopefullguy Posted June 2, 2020 Share Posted June 2, 2020 i have used ego depot to depot to ship 30 odd kg gear but that sub is going around 50kgs packed. i would not be dropping it into any depot before confirming they will take it. the depots are drop off's so no one checks the item.. some depots are not depots at all and are just mail centres. you risk it not being sent unless prior enquiries are made. Link to comment Share on other sites More sharing options...
Snoopy8 Posted June 2, 2020 Share Posted June 2, 2020 It is possible to ship it, pricing is only approximate. e-go will do it but their service has gone from bad to worse, about $90. Will require some one to assist driver to load and unload. Am reluctant to recommend them. https://www.transdirect.com.au can do this using TNT about $100 but it needs a pallet. Quote Items that exceed 25kgs. must be securely packaged on a forklift able Skid, Pallet or Crate. The dimensions and weights entered MUST include the packaging materials and all contents. Or request a personalised quote from Pack and Send https://online.packsend.com.au/PersonalisedQuote/Frt Link to comment Share on other sites More sharing options...
waynef73 Posted June 4, 2020 Share Posted June 4, 2020 I used Couriers Please to ship a Cerwin Vega 12inch sub from Brisbane to Perth a couple of years ago. Nowhere near the weight of the SVS sub though. Not sure what their prices are like these days but it may be worth getting another quote from them to compare. Good luck with the sale! Link to comment Share on other sites More sharing options...
Comput3rSaysNo Posted June 4, 2020 Share Posted June 4, 2020 I sold a PB2000 in original box a while ago, weights 35KG and big box. Buyer arranged door to door courier service via interparcel (melb to sydney), but I have seen the invoice, the cost was very very reasonable, below $50 from memory. Link to comment Share on other sites More sharing options...
