vae
New home theatre pre wiring help 5.1.4 vs 7.1.2
Hi I am building new house theatre is 6m long and 4m wide. As per attached plan there will be front, Center, sub, 1 ceiling pair for atmos 1 side surrounds pair and 1 rear surround pairs for 7.1.2 . (all surrounds at 1.5m height).
I am seeking option whether to turn rear surrounds into rear ceiling atmos to 5.1.4 as some people suggests is better setup than 7.1.2, and will be less clutter in the wall,. However I am not sure if that suits my room, Alternatively this can be mounted as rear presence speaker but at what height?
If I am going 5.1.4 what should be the distance of side surround from rear wall/corner?
Thank
hmm you are sitting on the long wall so your seating will be close to the wall.. therefore forget 7.1.2, you need space behind you if using "rear" speakers.
follow the 5.1.4 dolby guide imo
https://www.dolby.com/us/en/guide/speaker-setup-guides/5.1.4-overhead-speaker-setup-guide.html
Any chance you can put seat on the other wall?rotate room 90 degrees?
You say that the room is 6 long x 4 wide?
but your floor plan shows seating and setup at 4 long x 6wide?
i would run the room configuration with the 6m being the length (not the width)!
if you ever upgrade to a projector the extra length will be handy
4 m is a good width (my room about 3.5 )and would love that extra .5 but still works a treat
Others thoughts?
Hi wife won't allow, as it is not ideal to rotate the seat as will block the window, and I can't move the window to other wall as it looks out to aircon unit and fence, not planning for multiple row, and limit the "multiple purpose" use of the room...
Shame you can't rotate.
My room is 5.2 by 8 with tv etc against 5.2 wall, no window.
I went with 5.1.4 as rear wall is a long way back from seating.
With couch nearly on wall having 4 atmos will be difficult, ideally they should be in front and behind you, yours would be licated clise to wall which would create unwanted reflections.
Mine isn't much of a cinema as such, its also our lounge but it is work in progress, paint lighting to come and no WAF
Any other thoughts? What if the rear speaker up high wall mount as presence speakers? But I suppose the atmos speakers will not match.
nope won't work....
forget the rear speakers as been said.... with wall to back of wall there really isn't room for the rears to work better off with 5.1.2 or 5.1.4 at a stretch if can get some room between you and rear wall
Okay I think best to go for 5.1.4, and get some room from wall to couch, in this case would it best to place the surround at corner pointing to listening position? The dolby guide is somewhat confusing with a 2 diagram showing slightly different surround position
My wife left!
now I have room running the right way👍😊
cheers Muriwai
in what way ? what 2 diagrams are you looking at ? can you post links/pics ? to those ?
A picture speaks a thousand words.. but if you are doing 4m by 6m,  5.1.4 will suit better. But why not wire up for 7.2.4?
I use a 7.2.4 system in a 3.9m by 4m room...
please see pictures in attachment. Picture 1 and Picture 2 is from current Dolby website.  the top down view has rear surround in front of rear atmos while the side view has rear surround at the back.
The picture 3 is from AVS forum and maybe different version of dolby guide having the surround in the corner and rear atmos much closer to the listening position. Considering my couch is closer to wall I am wondering if picture 3 setup is better (surround at corner and atmos closer to couch better) ,  or stick to the current guide in picture 1 where there is more separation in atmos front and rear speakers. ( I can put rear atmos 300mm from rear wall)
would stay away from 7.1.4 if possible,  as already suggested previous reply as it seems to not add much, adds clutter to wall and wife won't like it..
I dont see as a contradiction....  id go with the dolby guide, not sure where AVS one has come from,
ps the sides are not in the corner... they are also not at the rear. the angle is 110-120 in horizontal plane... so a very tight angle sides need to be in 5.1 setup for base surrounds.
the vertical side section shows speakers in front and rear I think just for illustration... so know front or rear. it doesn't mean the side surrounds are in the rear. still have to apply the angles in horizontal plane. they are just to show the in ceiling speakers and angles in vertical plane for those ....
main problem is your couch that sits so close to back wall and why i would suggest not going much more than 5.1.2
your side surroudns and overhears in side/rear are literally going to be on top of each other and pretty close to rear wall.
What Betty said
follow the angles
couch needs to come off the back wall or your sound will just be a muddle
+1 on shifting the couch
wiring up for 7 channels  doesn’t mean you use them initially
fixing them is costly when done in isolation so since you’re doing some work, my suggestion was do add the points first then decide later
It’s a very decent space 👍
Thanks all for feedback.  This is my attempt to follow this version of Dolby guide for 5.1.4 (relocated speaker location in blue color).  i remove the speaker from side wall as they do not fit into right angle at all.
    • By zakblue
      Item Condition: Excellent (small mark on top as pictured) Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Balwyn State: Victoria Payment Method: Paypal, Bank Deposit Reason for selling: No Longer Required Comes with box and all accessories (remote, calibration mic, manual)
      Happy to courier Australia wide through Interparcel.
      PM for further details.
    • By VinodS
      Item Condition: Used Shipping Options: Pickup available and you can audition. Suburb or Town: Carlingford State: New South Wales Payment Method: EFT, Cash on pickup Reason for selling: upgrading to 11.2 Further information:
      Pioneer VSX 1130K (US Version) receiver in great working condition. No packaging, but comes with physical remote, MACCPro Calibration mic, Transformer to convert 220V to 110V
      Does nearly every format you throw at it, including ATMOS. Upgrading to 11.2 setup hence selling. 2 years old and in immaculate condition. Supports MultiZone audio.
      The back photo is stock photo, too many wires to take a proper photo
      https://www.digitalcinema.com.au/pioneer-vsx-1130-7-2-channel-av-receiver.html
      PLEASE READ
    • By mfroes
      Hi guys,
      I would really appreciate any guidance.
      I have front right/left speakers which are 6ohm 250w (nominal)
      central, rear left and rear right are 8ohm 150w (nominal)
      My amp is at the moment struggling to push all those speakers so i was wanting to upgrade.
      budget wise i think up to about 1k would be something for a 5 channel (just guessing here), if more how much more would be needed ?
      would there be one the would be HDCP 2.2-compliant ?
      if some that have atmos capability so i can buy some speakers and add in the future would be great.
      so would be 5.1.2 i'm guessing here?
      would a 7.1.2/7.2.4 be better ? havent seen a lot of bluray that comes with 7channel capability like that.
      the 7 i see usually are counting the atmos speakers.
      Thanks in advance for reading and for any suggestions that comes my way.
      Current Setup
      Receiver: Yamaha HTR-3066
      Front: NHT C4
      Centre: Gale 20
      Rear: Axis LS28
      Subwoofer: Sound Dynamics THS-10
    • By Eugene.cho
      Item Condition: near New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Bella Vista State: New South Wales Payment Method: cash Reason for selling: Need pre-outs
      Near new Sony STR DN1080, purchased from JB hifi hornsby 2 weeks ago on 20 May  for $1749. receipt available,
      What Hi-Fi? Awards 2019 winner.
      https://www.whathifi.com/au/sony/str-dn1080/review
      Reason for sell: set up then realized I should buy  a AV receiver with preouts so I can use my stereo system for the front channels. so I bought a Yamaha instead. This Sony was only set up for the test then back to the box.
      This is a very well reviewed and highly praised 7.2 or 5.2.2 Dolby Atmos, DTS-X AVR and comes with all the latest technologies, including 4K HDR, Dolby Vision, DSD play back and DSEE HX upscaling. built in audio Chromecast, Apple Airplay and multiroom audio.
      Manufacturer's website: https://www.sony.com.au/electronics/av-receivers/str-dn1080
      Reviews: https://www.whathifi.com/au/sony/str-dn1080/review
      https://www.cnet.com/reviews/sony-str-dn1080-review/
      https://www.avforums.com/reviews/sony-str-dn1080-7-2-channel-av-receiver-review.14623
      https://addictedtoaudio.com.au/products/sony-str-dn1080-7-2-channel-home-theater-av-receiver
    • By Kso
      Price: $800 Item Condition: As new Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition. Suburb or Town: Chatswood State: New South Wales Payment Method: Cash on Pickup Reason for selling: Downsizing Further information:
      KEF T301 speakers - have 6 pieces. Used for about 2 years in a 5.1.4 Atmos system. Comes with all (unused) mounting gear/stand. Note 2 speakers are center channel versions that can be used horizontally.
      Selling in pairs - Can offer a discount if purchasing multiple pairs
