ChesP Posted May 27, 2020 Share Posted May 27, 2020 Looking to BUY a Curious Cable USB 0.8M Link to comment Share on other sites More sharing options...
andyr Posted May 29, 2020 Share Posted May 29, 2020 On 28/05/2020 at 5:57 AM, ChesP said: Looking to BUY a Curious Cable USB 0.8M I don't think you should buy a 0.8m digital cable. I received a reply from the head of a US cable company (when I enquired about one of their cables) which said that digital cables need to be no shorter than 1m, for good performance. (So I've followed his advice. ) Andy 1 Link to comment Share on other sites More sharing options...
Ittaku Posted May 29, 2020 Share Posted May 29, 2020 2 minutes ago, andyr said: I don't think you should buy a 0.8m digital cable. I received a reply from the head of a US cable company (when I enquired about one of their cables) which said that digital cables need to be no shorter than 1m, for good performance. (So I've followed his advice. ) Andy's point is that there is actually a theoretical technical reason that you can get reflections in digital coaxial cables which can have subtle effects on digital integrity and noise when under 1 metre. I'm not sure this applies to USB though. Link to comment Share on other sites More sharing options...
andyr Posted May 29, 2020 Share Posted May 29, 2020 46 minutes ago, Ittaku said: Andy's point is that there is actually a theoretical technical reason that you can get reflections in digital coaxial cables which can have subtle effects on digital integrity and noise when under 1 metre. I'm not sure this applies to USB though. X'ackly, Con! But how can a USB cable not be a 'digital' cable? Andy Link to comment Share on other sites More sharing options...
awayward Posted May 29, 2020 Share Posted May 29, 2020 5 minutes ago, andyr said: X'ackly, Con! But how can a USB cable not be a 'digital' cable? Andy I have experienced this with using Ethernet cables shorter than 1m between active components, the high SQ went missing, went back 1m cables and all good. I’m not sure this applies to usb though. I use a 0.8 Curious cable and there is no evidence of sound deterioration, compared SQ with USB cables 1m long. Link to comment Share on other sites More sharing options...
ikhuong Posted May 29, 2020 Share Posted May 29, 2020 https://curiouscables.com/faq From the maker: “Cable Length All cables – from the Curious Regen Link (200mm) and Hugo Link (280mm) – to the 2 metre Curious usb are exactly the same cable, the same design. The same great sound. The only difference is length. Does usb length matter? First up, usb is different from spdif 75 Ohm digital cables. Remember the argument about 1.5m being the ideal length for spdif cables? This doesn’t apply to usb cables. When it comes to usb, shorter is better i.e. any length under 2 metres is ideal. Some audiophiles with high resolution systems may notice a slight difference between a 200mm and 2 metre Curious cable. However – this is very slight. Some may say miniscule! “ 2 Link to comment Share on other sites More sharing options...
ikhuong Posted May 29, 2020 Share Posted May 29, 2020 He is clearly not BS about cable length here to sell more, it is clear and honest. Link to comment Share on other sites More sharing options...
Ittaku Posted May 29, 2020 Share Posted May 29, 2020 47 minutes ago, awayward said: I have experienced this with using Ethernet cables shorter than 1m between active components, the high SQ went missing, went back 1m cables and all good. I’m not sure this applies to usb though. I use a 0.8 Curious cable and there is no evidence of sound deterioration, compared SQ with USB cables 1m long. It's specific to coaxial spdif and shouldn't affect ethernet either, but your experience is all that matters. Link to comment Share on other sites More sharing options...
awayward Posted May 29, 2020 Share Posted May 29, 2020 31 minutes ago, Ittaku said: It's specific to coaxial spdif and shouldn't affect ethernet either, but your experience is all that matters. Wow, that’s a bit condescending, Con 1 Link to comment Share on other sites More sharing options...
Ittaku Posted May 29, 2020 Share Posted May 29, 2020 2 minutes ago, awayward said: Wow, that’s a bit condescending, Con Actually I thought I was being open minded? Link to comment Share on other sites More sharing options...
