NoCoder
Low Budget Bookshelf speaker option
Hi All,
Revisiting the vinyl scene after many years away and have started out with a Pioneer LP30 turntable and I already had a Yamaha HTR-6130 receiver. Down the track  I would like to upgrade eveything, but my budget will not allow that for a fair while.
I would like to add better speakers than the ones that came with the receiver and was looking at a few bookshelf speaker options. I have seen a few Edifier model and also a Pioneer SP-BS22-LR Bookshelf Speaker. I only have up to $300 to spend.
I know nothing will blow me away with my current set up and budget, but it's a start to listen to what I have.
Does anyone have any suggestions?
These are for sale in the classified’s. You won’t look back. And local
These will blow your mind for the money. I had a pair and wish I never sold them. Great bookshelf speaker on a budget.
yamaha ns20-t
I bought these for my small room
Although they are made in China
Yeah, I've looked at a few of the Edifier range and was looking more at passive speakers. The Edifier are all pretty cheap, so i was a little wary of their quality
They get good reviews and I've had no trouble with them. So far
Good to get some feedback other than that from the sights they are for sale on. Thanks
Keep a look out in the classifieds section. If you are patient, you can easily get your hands on something very good for your $350 budget.
Might also be worth looking for a used Ritcher Merlins. I've heard them (RRP of $900, but can usually be found on sale for less). They are fantastic little bookshelfs and if you are lucky, you may find a used one for just a bit more than your budget.
Also checkout the second hand options at Len Wallis Audio (https://lenwallisaudio.com/category/secondhand/). There are a couple of options in your budget. I've bought my speakers (used) from them and can highly recommend LWA. They also offer a 3 month warranty on all used items.
I picked up some Wharfedale Diamond 121s for $300 in the SNA classifieds in July 2019 and they have been excellent in this setup
Edited by KRSDarwin
Seek out some B & W - DM 602 S2's
S1's were good also but steer clear of the S3's
Edited by Powerglide
Mis quoted "602" not 601
Any reason why?
Yes, the Diamonds are great little speakers!
It's surprising how much good quality stuff you can get for very little money if you look around and are open to buying used.
Here you go mate........exactly on your budget, and these will blow you away!
16 minutes ago, Addicted to music said:
Any reason why?
Made in China?
Fantastic Speaker for the future but will sound dead with that Yammie Receiver.
These are my Yamaha NS144s that I’ve had for fourty years. They still sound amazing. I wouldn’t be in a hurry to change them. Starting at the ‘source’ I think your dollars would be better spent on a decent cartridge, such as an Ortofon 2M Blue or a Nagaoka M110. That would be a better upgrade IMHO...
Edited by markielinhart
Typo...
21 hours ago, Addicted to music said:
Any reason why?
Many moons ago I heavily researched the 600's prior to a purchase. Great reviews all round but one article stuck out, it included statements/interviews with several B&W technicians from the era, I tried to find it but no luck. Loosely put the 600's were the entry level, by the time the 602 S2 came along they blind tested so well against the CM1's that B&W had a problem. The techs that perfected them claimed them as their finest work but then as @Wimbo said they moved 600 assembly off shore. They still continued development but used cheaper products and labour, they also packaged them in surround sound sets and mass retailed them through non audiofile retailers.
Don't get me wrong the S3's "were" good speakers and got great reviews but their quality dropped and they fell into the hands of a different consumer so finding a good pair is a bit harder.
These are the reference low priced speakers for sure brand new at $549. If you can find a second-hand pair, they will fit your price range and absolutely blow all expectations you have of low budget speakers.
https://www.stereophonic.com.au/elac-debut-2-0-b5-2-bookshelf-speakers-pair/
$498 on special:
https://www.apollohifi.com.au/speakers/bookshelf-speakers/elac-debut-2-0-b5-2.html
Edited by Ittaku
Go and get these, Ive purchased speakers from @kelossus and he knows a thing or two about a thing or two, read his comments
@Powerglide
thansk for the detailed reply, very good to know......
Great thread too, as I’m looking for some nice bang for buck as I moved my Maggie 1.7 on.
Thanks for all the feedback. Certainly given me a bit to look into.
Is there much to be gained from new/better speaker wire if it’s only around 2 meters?
It all helps i find.
Apologies in advance for making a recommendation a smidge out of your range.   Wharfedale Dentons.  Stupidly good.  I only sold mine because someone of this parish had Spendor D1s for sale.  Not only do they sound fine that they look absolutely fabulous.
If you are looking at $300 speakers, don't even think of spending anything on special speaker cables. Spend more on the speakers.
Edited by Ittaku
    • By rick-sub
      Item Condition: Very Good - small mark on one speaker Shipping Options: Pickup available and you can audition. Suburb or Town: Albury State: New South Wales Payment Method: EFT, Cash Reason for selling: Downsizing Further information:
      30th Anniversary Paradigm Tribute floorstanding speakers.
      Note small mark on one speaker(see photos) otherwise excellent condition.
      Specifications
      DESIGN:   5-driver, 3-way floorstanding
      FREQUENCY RESPONSE ON-AXIS:   ±2dB from 43 Hz - 45 kHz
      HIGH FREQUENCY DRIVER:   25-mm (1 in) P-Be™ pure-beryllium dome. Ferro-fluid damped and cooled. Neodymium magnet. IMS-SHOCK/MOUNT™ on cabinets
      MIDRANGE FREQUENCY DRIVER:   178-mm (7 in) black-anodized pure-aluminum cone, synthetic butyl surround, 38-mm (1-1/2 in) voice coil, AVS™ die-cast heatsink chassis. IMS-SHOCK/MOUNT™ on cabinets and baffle
      LOW FREQUENCY DRIVER:   Three 178-mm (7 in) mineral-filled polypropylene bass cones, patented overmolded NLC™ non-limiting corrugated Santoprene® thermoplastic vulcanizate (TPV) surround, 38-mm (1-1/2 in) voice coil, AVS™ die-cast heatsink chassis. IMS-SHOCK/ MOUNT™ on cabinets and baffle
      SENSITIVITY ROOM / ANECHOIC:   93 dB / 90 dB
      IMPEDANCE:   Compatible with 8 ohms
      FINISHES:   Hand-polished Dark Garnet Gloss
      WEIGHT:   41.8 kg
      DIMENSIONS HxWxD  113.0cm × 31.6cm × 40.6cm
      LOW FREQUENCY EXTENSION:   24 Hz (DIN)
      CROSSOVER:   3rd-order electro-acoustic at 2.2 kHz; 3rd-order electro-acoustic at 200 Hz (bass drivers).
      FREQUENCY RESPONSE 30° OFF-AXIS:   ±2dB from 43 Hz - 20 kHz
      SUITABLE AMPLIFIER POWER RANGE:   15 - 350 watts
      MAXIMUM INPUT POWER:   230 watts
    • By vunn
      Item Condition: Used but in excellent shape condition, no box Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Harrison State: Australian Capital Territory Payment Method: PayPal, cash, bank transfer etc Reason for selling: NLR. Clear out my collection Further information:
       Purchased few years back for original owner for my collection. All speakers has been replaced by new original Bose in 1998, so it’s working perfectly and decades to go without any problems. Regret to let them go due to no more space, will list some vintage amps later on SNA and Ebay. Will post with flat rate 100$. Even they are too heavy but will pack safely.
      PLEASE READ
    • By untca
      Item Condition: Great used condition Shipping Options: Pickup available and you can audition. Suburb or Town: Lake Macquarie State: New South Wales Payment Method: Cash Reason for selling: A bit big for the room Further information:
      nice set of paradigms in great condition. Sound great, drivers and tweeters working as expected. They are large so you will need to pick these up.
      PLEASE READ
    • By gavynz
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available. Suburb or Town: Caulfield South State: Victoria Payment Method: Paypal, Cash Reason for selling: Upgraded to 700's Price updated 1200.
      Reluctant sale of my 685 s2's and HTM61 S2 center, was going to hold onto the 685's after upgrading to the 700 series, but space is at a premium.
      I've had the 685's since 2015, and the center since 2018.
      No damage or any issues whatsover, an would make for an excellent starter home theatre system.
      A pair of stands thrown in if wanted (not B&W specific, generic)
    • By E-Gene
      Item Condition: Used but as new Shipping Options: Pickup available and you can audition. Suburb or Town: Maidstone State: Victoria Payment Method: Paypal, Cash on Pickup Reason for selling: Changed my set up Further information: I got these speakers 2 years ago when I wanted to set up a turntable in my room but didn't want the expense of an amp. Also didn't have the space for it. These speakers did the job and did them very well! They not only have phono inputs, they have optical, aux, USB and Bluetooth as well! Comes with a slick remote control, so you can adjust this all from the comfort of your chair! If you know what Klipsch speakers are capable of, then you know that these are awesome!
      I've since moved my turntable to my living room and it now runs off an AV amp and I don't need these anymore. Truly great speakers that will benefit someone who wants to connect to their turntable but still have the luxury of listening to Spotify off their phones using Bluetooth. Or connect to your computer using USB.
      Condition is as new. No dinks or scratches. They have never been moved from when I took them out of the box and placed them on my desk.
      Read about them here. I can't seem to find somewhere in Australia that sells them other than here and RRP is $1199.
      Pickup only from Maidstone VIC as I don't have the original box for them. Happy to audition them at pickup.
