Just purchased my first high end cart and need help having it fitted to my PROJECT AUDIO RPM 9.1.
I'm in Albany  WA.
If there's no one on here locally I'm coming to Perth soon and looking for recommendations on where I can take it to get fitted. At nearly 2 grand I'm not game to do it myself. It's a Soundsmith Carmen.
Any help appreciated.
Come see me I’ll do it for ya (in Perth)
Should be a great sounding setup 👍
If you need help setting it up ... get in touch (in Perth).
    • By MAXXX
      Item:  Speaker cables (pair) , New Generation by Belden, 3m, terminated with banana plugs
      Price: $70  (Add $15 for postage)
      Item Condition: VGC
      Reason for selling: NLR
      Payment Method: Pickup - Cash, Paypal as friend , COD...
      Extra Info: Commercial Audio Cable, Rated-CL2, 2-10 AWG highly flexible stranded bare copper conductors with PVC insulation, PVC jacket with ripcord. Quality banana plugs on both ends, lockable.
      https://edesk.belden.com/rohs/rohs.cfm?code=PF_5T00UP&lang=EN
    • By cafe67
      Moved  from Mounts Bay Rd to Osborne Park (across from.WC hifi)
      New premises are bigger and getting more gear in. Impressed by their enthuiasm for the new store and range of gear.
      New M Levinson integrated amp playing  through M Logan speakers sounded good.
    • By MAXXX
      Item: NHT ST4 floor standers
      Price: SOLD
      Item Condition:
      Reason for selling: Upgraded, NLR
      Extra Info: Excellent condition, happy to demo. No original boxes, so local sale only. Matching center speaker available for $150 extra.
      The ST4 is designed for applications requiring greater dynamics combined with full frequency response. The slender tower features two separate chambers; the top portion, which replicates the highly acclaimed Super Audio SB3 bookshelf system, and the lower portion, which contains a vented, built-in 8" subwoofer. This unique design approach provides the sonic finesse of our finest 2-way bookshelf with the added dynamics, extended bass and high output more typical of 3-way systems.The ST4 is bi-ampable to permit tuning low frequency response in difficult room placements. Available in gloss black only, stabilizers included. Recommended NHT center channel SC2.   "...After listening to the ST-4s, you may wind up permanently dissatisfied with small speakers. Big speakers sound, well, bigger, with more and better bass, livelier dynamics, and a larger sonic image than any small model could possibly muster. No 7-inch-tall unit, even one bolstered with heavyweight subwoofers, can compete with the mighty ST-4..."
            Specs:
      System Type: 3-way system, upper chamber-acoustic suspension, subwoofer chamber vented
      Drivers: 1' Fluid cooled neodymium magnet structure tweeter with NHT's proprietary aluminum heat sink. Mid-Woofer 6.5" polypropylene, high excursion. Woofer 8" polypropylene, long throw.
      Magnetically Shielded: Yes, except 8" woofer.
      Frequency Response: 31Hz- 22kHz +/- 3dB
      Crossover Frequency: 2.6kHz, 135Hz
      Sensitivity: 86dB (2.83V at 1M)
      Impedance: 8 ohms nominal
      Inputs: 5-way binding posts
      Recommended Amplifier Power: Minimum 15 watts/ch Maximum 200 watts/ch
      Dimensions: 38"H x 8"W x 12"D
      Weight: 47.5 lbs. each
      Finish: Black high gloss piano lacquer
    • By Muzza71
      Item: Morel 3 Way Large Stand Mount DIY Loudspeaker System
      Price: $1800
      Item Condition: Very Good
      The system offered comprises of 2 large 3 way bi-wired stand mount speakers in a curved Cherry 21 litre cabinet. Also included is a Dual 31 band Graphic Equaliser and an Omnimic V2 Acoustic Measurement System & 2 sets of 700mm stands.
      To ensure a flat frequency response is achieved I have implemented a 31 band analogue graphic equaliser and Dayton Audio Omnimic V2 Acoustic Measurement System which runs sweeps from either a cd player or thumb drive. To achieve a flat frequency response, adjustments need to be made to the 31 band graphic equaliser in real time whilst running sweeps from the Omnimic measurement tool.
      These speakers will sound as good as speakers 3 x my asking price.
      I have Bryston Mini T 3 way Stand Mounts at RRP $6000.00  to demo against.
      I have attached photos of Frequency Response graphs taken 1 metre away from the speakers before and after applying EQ (In room response).
      Below is a breakdown of system component list and parts purchase prices including delivery in $AUD:
      2 x Dayton Audio MTMC-0.75CH 21l MTM Curved Cabinet Cherry                = $469.00
      4 x Morel TiW 634FT Titanium Series Ferrite 6” Woofer 4 Ohm                    = $900.00
      2 x Morel TM4055-8 2" Midrange and 1-1/8" Tweeter Speaker Plate             = $520.00
      4 x Dayton Audio BPP-SN Premium Binding Post Jack Pair                          = $110.00
      2 x Dayton 800-HPF-8 High Pass Crossover 800 Hz 12 dB/Octave               =  $ 34.00
      2 x Dayton  800-LPF-8 Low Pass Crossover 800 Hz 12 dB/Octave               =  $ 54.00
      2 x Dayton 3.5k-LPF-8 Low Pass Crossover 3,500 Hz 12 dB/Octave              =  $ 22.00
      2 x Dayton 3.5k-HPF-8 High Pass Crossover 3,500 Hz 12 dB/Octave           =  $ 22.00
       31 Band Graphic Equaliser        = $355.00
      Dayton Audio Omnimic V2 Acoustic measurement System                         = $389.00
      2 x pairs of Stand Mount Speaker Stands 1 x wood 1 x steel/Glass               = $275.00
      Baffle driver holes cut out by professional                                                        = $100.00
        TOTAL      $3205.00
      The speakers are 8 ohm, the 2 Morel 6” 4 0hm woofers are wired in series equalling 8 ohms.
      The Woofers crossover at 800hz to the midrange, then the midrange crosses over to the tweeter at 3500hz.
      Internal speaker wiring Van Den Hull Clearwater.
      Internal cabinet walls are lined with Response combination  Butyl/foam super sound deadener.
      Magnetic Grilles.
      Cabinets are very sturdy with a thud response when knocked on
      Both speaker stands can be filled with sand/filling.
      Dimensions H 508mm W 215mm D 342mm
      Each speaker weighs 14.5kg
      Local buyers only at this stage, however if there is no local interest I can ship interstate in 3 separate boxes, speaker stands will not be shipped therefore local buyers consider the speaker stands as a freebie.
      I will help setup for local buyers.
    • By AndreaB
      Item: SHUNYATA RESEARCH COBRA S/PDIF cable (1.0 m)
      Price: $300 + postage (if required)
      Item Condition: pristine
      Payment Method: Pickup - Cash, bank transfer
      Extra Info: Bought from Krispy Audio the 29th of April. Selling because I have now sold my streamer.
