Power cable: British vs American vs Aussie
Hi guys,
When you are on the road of hi-end hi-fi equipment, power supply is one topic attracting a lot of discussions. We hear a lot of good power cable names like voodoo. However here's the problem: majority of these power cables gives only British three-square pin plugs or American two-flat-pin-plus-one-round-pin plugs. There is none for Aussie plug. Also for power conditioning bars they give British and American formats like the product below.
http://www.mshdpower.com/products_p.html?category=sockets&class=uk&oem=2&xml=MSUS06SRHKV2&model=MS-US06SRHK V2
While you are using these power bars, where do you find the cable from this bar to your wall socket? Or you simply do yourself a tradie and change the wall socket to British/ American?MSUS04SRHKV2_01.jpg
Definitely not!
If the powerboard is rated for 240V you could change the line plug to an AU one.
4 minutes ago, pwstereo said:
Definitely not!
Peter,
So you mean people can source good plugs to change instead of those from Bunnings.
Just now, Pallydou said:
Peter,
Middendorps, or AWM will have good line plugs.
SAFETY SAFETY SAFETY !  BEWARE!
Australian power = 240V.  Devices in Australia are required to meet the safety standards so they can manage this voltage safely.  This approval ensures safety for the end user.
UK power = 230V.  Similar to Australia.  There would be less concern in changing a UK power plug to an Australian power plug.  However, the device has still not been approved for use in Australia.
US power = 120V = less than half the voltage used in Australia!  Changing the socket on US devices is dangerous, because they have only been designed to use half the voltage.  Therefore, insulation may not work at the higher Aust voltage.  DO NOT use these with 240V!
A US power board can be used* in Aust. IF it is connected to a step-down transformer (that converts 240V to 115V) AND the current drawn by the power board does not exceed the max. current specified by the power board and the current rating of the step-down transformer.
* Although I said it can be used, it still may not meet the Aust. electrical standards.
yes, we are 230V NOT 240V
The problem I see, is there are all sorts of other regulations about insulation, spacing, earthing requirements, etc etc, that components sourced overseas may not comply with.  Same for unapproved locally made stuff.
Just changing the plug on the end to suit your wall socket won't fix those problems.
Edited by aussievintage
https://en.wikipedia.org/wiki/AS/NZS_3112
Do not change the wall socket!
At a glance the power conditioning bar in the link does not look like it is compliant with Australian Regulations. Someone can correct me but I would be worried about soldered joints on a mains bus bar unit where you could plug in multiple high current drawing devices.
My view would be to buy an Australian certified unit and at least have some hope of claiming insurance after the house burns down!
4 minutes ago, audiofeline said:
My error is noted, thanks for the clarification.
Ha, 240, 230, they say tomayto, we say tomarto, it's the distinction from the typical US 110 V we were both making  🤣
Edit:  PS, look at the voltage ratings on this page of plugs
https://www.awm.mmem.com.au/general-wiring-accessories/general-electrical-accessories/plugs-sockets-adaptors.html
Edited by pwstereo
Added link to mains plugs with 240 and 250 V ratings
443896915_ScreenShot2020-05-19at7_52_58pm.thumb.png.0886c49c1de4ec7dbad3f6b62007de42.png
Mains can range between 253 volts AC to 216 volts AC on a single phase circuit, hence the 250 volt rating of the sockets. The reasons for the the supply variance are varied and issues stabilising the voltage at 230 volts must be exceedingly difficult with the increased uptake of intermittent power generated by solar, wind etc distances of user from the generation site, time of day usage et al.
Thanks for all your replies. Much appreciated. Let me tweak my question a little bit. This is a Voodoo cable sold in Australia. Definitely it is America standard (plug). This means you need an American-look power bar (but run in 240V). The amps is running in 240V of course. My original question was how do you find a good cable connecting the power bar to the wall socket. Getting a Clipsal plug to change is an option, but many audiophiles would have bad feeling on Clipsal.
https://klappav.com.au/collections/voodoo-cable/products/x-ray
It’s “voodoo” alright. “Improves signal gain and colour saturation.”
That is just ridiculous, buy a proper, approved AU plug for it and get on with listening to music.
  • Like 3
  • Haha 1
... and shouldn't cost more than $15 from Bunnings.
Have you owned a Voodoo cable before? The ones I’ve bought locally all have AU plugs already on them. The plug used was a HPM D90WE. So if you are buying in Australia they are perfectly legal.
The models I’ve owned bought in Australia have an AU plug. They use the HPM finger grip plug D90WE. So all legal.
why would anybody have bad feelings about a Clipsal plug,just about every home/business  in Australia have either Clipsal or hpm wall outlets/light switches fitted througuout their homes,nothing wrong with the clipsal1439s.
  • Like 4
Don't get me wrong. I use a lot of Clipsals/HPMs/Jacksons on my appliances. Some may just say "oh the pins are not 24K gold plated" whatever. You know, sometimes audiophiles may strive for everything perfect from the wall plug on the wall to appliance.
For me, as long as that plug gives power I am fine with it. I am just curious.
I phoned my energy company and asked whether the ~20m cable from the power pole to my house was cryogenically treated. They said no.
  • Haha 4
Mine isn't shielded either : )
1 hour ago, ray4410 said:
why would anybody have bad feelings about a Clipsal plug,just about every home/business  in Australia have either Clipsal or hpm wall outlets/light switches fitted throughout their homes,nothing wrong with the clipsal1439s.
Hi Ray - the Clipsal 1439s is a 20a plug, right?
So it has a wider earth pin than a normal 10a plug and will only fit into a 20a wall socket (which has a wider earth-pin slot)?
Thanks,
no andy the 1439s is a standard 10amp wall plug
the Clipsal plug with the wider earth blade is 1439s15
ray.
It's legal if the whole cord has Australian standards approval, otherwise only the plug is legal. Talk about it with your insurance company, I'm sure they can give you the details.
Just had a quick look at the Klapp site mentioned above, and at the end of the description it says that it's available with the AC plugs listed below, and then fails to give a list of available options. Probably a fair bet to say that the only available option is an Australian plug. I would have thought that selling a power cord of whatever price with anything else would be prohibited. Might not be, but it would be a bit iffy.
Clipsal, HPM, etc. plugs are sold in Australia and meet the Australian electrical safety regulations.
The transparent Clipsal 1439SHD = "HD" 10A version, takes up to 11mm cord entry size, this is what to get if you have a shielded cable.  The version without "HD" in the product code accepts standard 3-core flex cable, but nothing more.  The Delta plug at Bunnings is very similar, and the entry hole at the back can be enlarged if rewquired.
More discussion on Australian plugs here:
    • By Tumpom
      Item Condition: 8/10 Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: 2095 State: NSW Payment Method: Cash on pick up or EFT Reason for selling: Upgrade I ordered this pair of Van Den Hull CSS 122 from Audio Fidelity (associated to SGR Audio) custom made to the length of 5m for the RPP of $526 in October 2013 (invoice attached). They served me very well for a pair of Vivid Audio 1.5V loudspeakers.
      Still in production today with plenty of excellent reviews online for this high value-for-money cable and one of the sweet spots in the VDH range.
      https://www.vandenhul.com/what-hi-fi-magazine-2000-cs-122-hybrid/
      The 2 conductors are made of 147 strands of 0.16 mm. diameter high purity Matched Crystal OFC with a very dense pure silver coating.
      Each conductor exhibits a cross-section area of 2.96 mm², equaling AWG 12.5.
      Covering the two conductors you find an extra Linear Structured Carbon ® saturated layer to improve the sonic performance and to transform the radiated magnetic field into an audio-signal again.
      The resistance per lead is: 0.58 Ohm/100 meter.
      The capacitance between the 2 leads is: 32 pF/meter.
      The cable jacket is made of our HULLIFLEX ® 3, a very flexible and mechanically superb insulation material.
      The insulation of the plus and minus leads is different in shape with printing in the flat middle section. Both properties are easy polarity finders. Type printing on every 25 cm. (10″) makes cutting of specified lengths very easy.
      The banana plugs are the original VDH gold plated ones I ordered with the cable, hence they do have some signs of wear commensurate to their age.
      As a bonus if interested I am adding a free set of 4 pairs of EGM gold plated banana plugs with heatshrink sleeves, all brand new and mint, should you want to change them.
      Any question please PM me.
      Thanks for watching
    • By AussieMick
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Bendigo State: VIC Payment Method: EFT, cash Reason for selling: NLR Further information:
       1m Cardas Clear M power cord with US plug. Made a substantial difference to my CD transport, reducing background noise significantly. Transport is sold, I no longer require this power cable. Price includes postage.
    • By BobbieBeat
      Item Condition: As new Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Malvern State: VIC Payment Method: PayPal (fees on buyer), Cash on pick up, Direct transfer Reason for selling: Further information:
      Selling an as new Focal Clear balanced 3m 4pin xlr cable. Bought this during lockdown to try with my Woo Audio WA11 (also for sale in seperate ad). Am selling as I am rotating my gear and just don’t need it (actually never really used it).
      PLEASE READ
    • By VinylChef
      Item Condition: Excellent Shipping Options: Pickup available and you can audition. Suburb or Town: Edgecliff State: NSW Payment Method: PayPal, EFT, Cash on Pickup Reason for selling: Upgraditis PRICE DROP!
      Why Buy?
      Built in 1999, with one main owner since then, this is a great example of a fantastically capable Rotel power amplifier.
      Featuring an inhouse-built, oversized toroidal transformer and easily configured for bridged mono mode, it has plenty of power for any speaker down to 4 ohms, and a lovely warm detailed sound to boot.
      Recently serviced and given a clean bill of health by Rage Audio (with only minor repairs needed), it is immaculate mechanically and electronically, with the only blemish being pitting and roughness on the top cover.
      Specifications
      Power output: 130 watts per channel into 8ohms (stereo), 360W into 8ohms (mono)
      Frequency response: 10Hz to 100kH
      Damping factor: 500
      Input sensitivity: 1V
      Signal to noise ratio: 120dB
      Speaker load impedance: 4ohms (minimum)
      Dimensions: 440 x 121 x 327mm
      Weight: 10.3kg
      Photos
    • By hiphile
      Item Condition: Used Shipping Options: Pickup available but audition is not available. Suburb or Town: Oakleigh State: VIC Payment Method: EFT, Cash Reason for selling: No longer needed Further information:
      QED Profile audio cable in 2M length in excellent condition.
      No longer needed as my new amplifier requires a different connection.
      Cheers!
      PLEASE READ
