MAXXX
SOLD: FS: HALCRO MC 50 power amplifier
Item Condition: Excellent, boxed
Shipping Options: Pickup available but audition is not available.,Shipping is included in price.
Suburb or Town: Kardinya
State: Western Australia
Payment Method: PayPal as friend, bank transfer, cash
Reason for selling: Change of mind
Further information:
Purchase here few days ago from Eagleeyes, planned to use it as stereo amp only (bi-amping) but decided to get some smaller mono blocs...I'll just copy description and photos of actual item from previous owner(s).
The only thing I added was few  new pads for amp feet (few were missing...).
Local sale preferred, but I can send it via couriers with tracking for $80  (Australia only).
Recently replaced 1 module from Magenta at about $500 (great that this is so easily repaired. 4 screws).  (You will get replaced module as well.)
RRP was about $7,000 USD when new
I have original double boxes to post, installation CD and manual.
Modules are very easy to turn on and off which is very handy to keep some spare if not being used
  • Power Output: 350W RMS continuous into 4 Ohms
  • Distortion THD: <0.007% at 1kHz at all powers up to 350W into 4 Ohms, <0.03% at 7kHz at all powers up to 350W
  • Unbalanced and Balanced Voltage Inputs
  • Thermally controlled forced air cooling
  • Mains Voltage: 190 – 250VAC
  • Remote trigger switch between On & Standby
  • Command Functions:
    • Switch between On & Standby
    • Ability to inhibit individual amplifier modules
    • Amplifier module will indicate Over Temperature condition
  • Halcro Reliability Assurance Service
SPECIFICATIONS:
Inputs, selectable
Unbalanced: RCA sockets
Balanced: XLR sockets
Outputs
Internally bridged: Binding Posts
Command Functions
Amplifier module will indicate Over Current condition
Gain
Unbalanced and balanced: 29x = 29dB
Power Supply
Universal switch mode
Power factor corrected
Fully protected
Compliant in all countries
Fault Indications
LED turns red if Heatsink temperature exceeds 78°C
LED flashes red if current limit exceeded
Distortion
THD:<0.005% at 1kHz at all powers up to 350W into 4ohms
0.02% at 7kHz at all powers up to 350W (typically <0.01% at 350W)
Noise: <30nV/sqrt(Hz) @ 1kHz referred to input
Impedance
Input
Unbalanced: 10k Ohms
Balanced: 10k Ohms
Output impedance at 7kHz
<80 milliohms
Power
Consumption
Idle: <14W
350W with 4 Ohm load: <22W heat (>94% efficient)
Mains Voltage
100-250 VAC
Dimensions
Weight: 25.0 kg
Height: 7 inches or 169mm
Width: 17 inches or 438mm
Depth: 16 inches or 410mm
Bargain!
Hi @MAXXX, I'm interested just a couple of questions.
How many previous owners?
The age of the unit?
And the likely hood of the caps needing to be done?
Marty
Hi Marty,
not sure about previous owners except Eagleeyes and Bunno77.
It seems that Bunno77 had it for a few years (you can check their recent posts).
He can provide more info about the unit.
