Item Condition: Excellent
Shipping Options: Pickup available but audition is not available.,Pickup available and you can audition.,Shipping is included in price.
Suburb or Town: Figtree (Wollongong)
State: New South Wales
Payment Method: Paypal, Cash on Pick Up, Direct Bank Deposit
Reason for selling: too much stuff
Further information:
The REL T9i (Gloss Black) is the top of the range Ti-Series subwoofer.  It has had little use.
·       Drivers: 254mm long-throw front-firing drive unit & down-firing 254mm passive radiator
·       Amplifier Output: 300 Watt Class A/B power amplifier
·       Controls: 3 x Rotary Controls for (1) Hi/Low Level (2) .1/LFE Level (3) Crossover Frequency
·       Inputs: Dedicated inputs for Hi Level (Speakon), Low Level (RCA) and .1 (RCA)
·       Crossover: Extremely low crossover points that allow seamless “blending” with any loudspeaker
·       Proprietary REL-D™ digital amplifier input provides the impedance and grounding for most Class D amplifiers.
·       Lower Frequency Response: 28Hz at -6 dB in room
·       Input Connectors: Hi Level Neutrik Speakon, Lo Level single phono, LFE phono
·       Input Impedance: High Level: 150k, Low Level: 10k, .1/LFE: 10k ohms
·       Gain Control: Range: 80 dB
·       Phase Switch: Yes, 0 or 180 degrees
·       Protective System: Fully Electronic SET-SAFE
·       Mains Input Voltage: 220-240V 50Hz
·       Detachable Power Cord: Allows for upgrade to better quality cord.
·       Dimensions Inc. Feet (WxHxD): 330 x 387 x 407mm
·       Nett Weight: 18.7kg
·       Feet: Milled aluminium feet
·       Neutrik Speakon Interconnect: Yes (10 Metres)
Buyer to pay freight.  I can assist by taking the unit to Australia Post or other courier in Wollongong.
Edited by peterr
How is this still here????
I would buy it myself but not sure the Rel connections will suit what I have in mind.
GLWTS.
Regards Cazzesman
GLWTS.
Regards Cazzesman
Was thinking the same...I’m in the same position...only have L/R pre-out outs from my stereo amp.
FWIW and IIRC, the Neutrik Speakon cable’s recommended config is to wire it to the same posts as the stereo speakers.
