bryansamui
Benefit of Vinyl Reproduction Question:
 Firstly, I get the idea of a complete analogue recording on a 'Master Tape' ( Pure unbroken Sound Wave)
and replay through an analogue device .
What though,  if i record something  in the 'Digital Domain' on my Digital Audio Workstation (DAW)
at say 24bit/96khz  ,  is there any  aural benefit  by transferring and listening to it on Vinyl?
Bear in mind it's already gone through Analogue to Digital Conversion going from my Guitar to the DAW and  not a pure sound wave.
The most pure  form of playback i am going to get  is 24/96  through my  DAW...    Clearly, there is no 'Tape Compression' which
makes  old recordings sound 'Fat and Organic'.. Will Vinyl restore or improve this cold clinical digital recording?
I'm interested in opinions as I am unsure.
My gut feeling is if it's recorded in the digital domain it's best played back in the digital domain..
Edited by bryansamui
Having had and compared old LPs converted to CD, I suspect the difference you may hear will come from the audible signature of the equipment used, rather than the format being played.
If the recording is cold and clinical then I suggest perhaps it wasn't mixed well in the first place.
Digital itself isn't inherently cold and clinical, just as vinyl isn't inherently warm and fat
This has been done many times by the record companies. Most "digitally recorded" vinyl records were of course done this way. There's a lot of vinyl recorded by the Sony Soundstream digital recorder for example.  The Telarc series of classical records is an example.
Completely  agree.
What you are saying is correct. There are thin sounding analogue recordings.  I was just wondering,  if issuing a digital recording  on a vinyl medium  gives  playback  some of the aural attributes that excite  vinyl enthusiasts .
My understanding is that there is more to making a record than simply transferring  the digital mix straight to vinyl. It’s an art that has to take into account a whole bunch of factors (eg the resonant frequency of the cutting lathe, the allowable groove width for deep bass or large dynamics etc).
So it’s hard to know whether difference are caused by the medium or by the process.
I would suggest a better way to tell if the “aural attributes” are due to the vinyl
itself would be to do a digital recording of a vinyl record and compare that way
The main benefit of vinyl over a digital file (or CD) for music that was originally recorded digitally is the fact that you cannot cut  an overlay compressed file to a lacquer  so the LP in theory should sound more dynamic as a result which is kinda ironic seeing that the CD format has much better specs in this regard but sadly due to the loudness wars is mostly not utilised to its full potential.
So, you are saying that the main benefit of vinyl is that the original recording as mastered by the artist cannot be transferred intact to a vinyl disc due to the physical limitations of the medium?:huh:
I read it as saying that borked overly compressed desired masters can't be cut to the lacquer (not sure why) and so they are forced to use a more 'normal' dynamic range, which is better from a hifi perspective.   Not sure I agree, as they could simply cut a compressed version at lower volume and still fit it on the record (like I suspect ktel and others did for those other 20 hit wonder LPs).  I guess they just would not want to lose the loudness wars, which btw still happened, even back in the days of 45 rpm singles.
When Michael Fremer reviewed Mobile Fidelity's 2LP release of Brothers In Arms, he addressed the topic of a digital recording on vinyl:
"Now while cynics might say "why not just get the CD"? It's not that simple. "Get the CD" and use what to decode the digits? Your CD player or DAC? Is it as good as the one Mobile Fidelity uses? Or do you think all DACs sound the same? When listening to this double 45 you are hearing a combination of Mo-Fi's D/A converter, the mastering engineer's EQ choices and what the analog cutting process does or does not do to the resulting analog signal, just as when you listen to the original CD or LP you are listening to the gear used for those back "in the day" and the EQ choices made by Bob Ludwig."
I'm really struggling to understand what on earth he is saying :)
Far be it from me to interpret Fremer, but what I understood is that the mastering process (and with respect to digital the choice and quality of DAC), and all it involves is a lot more complex than 'transfer the CD to vinyl'.
FWIW I remember doing a shootout between the CD of BIA and the MOFI LP at a friend's house. At that stage he'd invested around 13K in his digital rig and about 5k in his vinyl setup. We both thought the vinyl sounded better, but only just.
I wouldn't think so
agreed
mastering onto vinyl will add further limits
  1. reduced volume peaks (than could be supported by digital) to prevent the needle jumping out of the groove
  2. tracing distortion increasing from outer groove to inner groove, meaning treble needs to be wound back towards the inner grooves as the needle just can't track the accelerations required for higher frequencies towards the inner grooves
I see zero benefit in using vinyl as the playback medium, if the recording/mastering is digital.
Mike
I have a couple records that are made from the same master as the digital recording.
The cartridge and phono stage seem to add dynamics, weight and stage size, versus the digital, which may be more accurate.
The vinyl playback of Hugh Masekala,s Hope album is always more enjoyable,  to my ears, of my TT thru my dual mono Einstein Phono stage.
How do you know?
Genuine question, for the reasons stated by me and @Tubularbells above, I didn't think that it was ever possible (or at least its extremely rare) for the digital master to be cut directly to vinyl completely unchanged without any adjustments made for the different formats
Reading into his complex statement, i got this: Using Vinyl you had  A/D conversion and then D/A conversion done by the engineer ( stuck with those choices)  or using CD, adding a further DAC in your living room.
What will help, is to know about methods the recording industry has used to preserve dynamic range in music.   Where you say "The most pure  form of playback I am going to get  is 24/96  through my  DAW... "  then misses out on using what the recording industry has used since 1965  which is companding.
An outline of Type 4 DBX , gives some historical view of analog recording drawbacks, and more so digital recording drawbacks, and gives insight where companding has answered the preservation of dynamic range.    https://www.manualslib.com/manual/560757/Dbx-Type-Iv-Conversion-System.html
Can you also use companding ?... Yes Type 1 DBX gives possibly the best opportunity , and two vintage devices the 150 x and 180a enable real time processing. CD reproduction IMO benefits greatly from Type 1 , and is outlined in the 150x manual. There may also be plugins you can use, however you need to carefully follow the mathematical relationship and emphasis curves to get close to what Type 1 offers.  I am unsure if a type 1 software plug in is available.  Vangelis as example used type 1 companding in the recordings Antartica , and China to name two
Ironically LP production uses a partial outline form of companding, namely the work Murray Crosby provided, in a failed patent where the  emphasis and de-emphasis methods are used at the time of cutting the LP, and then restored for flat reproduction when you use a phono stage , and is seen in the RIAA curve. Presently CD players do not exploit enough, the advantages of emphasis and de-emphasis  - although they have the capacity. What is needed is agreement on a companding method, and i would put my hand up for type 1 DBX
so when we buy a CD it contains the ability to compand at playback.
Edited by stereo coffee
What (I think) im saying is that if an album is mastered too hot on CD then generally it will sound better on vinyl ironically due to the cutting lathe limitations. Im no expert but the way I understand this is overly compressed music means all those musical peaks have been sliced off and you end up with a brick walled looking file. This is basically clipping (the same thing occurs when driving an amp too hard). As the cutting lathe is in continuous motion it is unable to physically cut what is essentially a square wave onto the lacquer and thus the  vinyl master cannot be clipped or brick walled otherwise you'll end up with is an unplayable record.
2 hours ago, sir sanders zingmore said:
How do you know?
It is impossible to use the exact same master for CD and vinyl for the simple fact that vinyl cannot handle the large swings in bass as the modulation would consume too much space as at a minimum a vinyl master will have the RIAA inverse curve applied decreasing the bass level before being cut.
Edited by Tubularbells
I get that vinyl has limitations.  Most vinyl versions now will not exactly be what was the artists vision as it needs to be modified to fit the format. Records will always sound like records as they have certain limitations, which is good if you like the sound of records.
For me the biggest advantage of vinyl is that the temporal information in the music is set at the lathe unlike digital which needs to put it all together again which is where a lot of problems arise.  Both mediums have their issues.
Actually it isn't.  Those musical peaks are removed by lowering the gain for the duration of the peak,  so it does not clip, it's just made the same height as the surrounding content.  What is removed is the dynamics of the music - only the difference in loudness between different parts of the music.
Any mastering of a digital source for record production can be done well or it can be done poorly.  There can be brickwall compression, bad eq, and other decisions that result in a horrible record.  Or it can be mastered to bring out the best in the original recordings, retaining dynamic range and optimised for phono reproduction.
Probably correct but if thats the case why do overly compressed "loud" recording sound terribly distorted.
Two examples I have are Rush -Vapour Trails & Metallica - Death Magnetic. Horrendous distortion on both which to my ears sounds a awful lot like clipping where as the vinyl versions are much better in this regard.
Yes vinyl is my preferred format however im also well aware of its limitations and dont pretend for a second that it the perfect medium. In fact it's amazing it sounds halfway decent at all given all the limitations imposed on the format.
If other people hear this distortion on their different equipment, then I think you can blame but workmanship in the studio.
Both formats are capable of great music reproduction- that is pretty clear. I am currently listening to my FM tuner and getting great music reproduction. They all have their idiosyncracies, which producers, along with manufacturers of gear  plan for, in the effort to achieve good music coming out at the speakers. The difference between FM stations is indicative of some of the issues- some assume you are going to be listening in your car, and compress the hell out of it, whereas some, like ABC classical assume you are sitting at home and provide uncompressed signal (less compressed?)-   so it is possible to get good reproduction, though you often don't.
I love my record player, though I think it is mostly the trimmings- putting it on, cueing the record up, sitting down and watching it spin which is the sweetener. It is making love, rather than sex in isolation, if you like. That said, within the constraints of playing vinyl at all, there is a lot of improvement to be had with equipment, and I would say, the quantum of improvement is greater than that seen in digital gear.
Your ears may differ.
Just had a listen to this on Tidal. Interestingly there are 2 versions of this (both MQA mastered). They sound very different. The original one is pretty awful sounding and there is a 2013 remaster which is much more civilised and in many ways very different.  The first one sounds like they told the engineer to make it sound like it had been turned to 11.
In the end regardless of if we like it or not distortion is a valid artistic choice still used widely (just listen to the chorus of Adele's "Hello").
